You are really getting on my nerves Roland.
To say I have not acknowledged fuel cut is a blatant lie. In fact, I posted about it in response 23 of this thread, and that's a re-post from 2 years ago. So as far back as 2 years ago I was posting about it. Let me repost again for you.
The concept of decel braking and fuel cut may be getting interchanged here. Pretty much the stock bike just dumps power as soon as you back off the throttle even a little bit. Some call it engine braking. some call it fuel cut. When it's excessive, I call it annoying. I can't stand it. I am working with the map now to try to get a smoother version of decel. I might be onto something. no promises... But IF i can pull it off, and anyone I've flashed already wants the upgrade I'll do it for the cost of shipping. "
So here's the bottom line on that... I have a different way of dealing with fuel cut than Ivan does. I will say this, from a tuning perspective Ivan's method is easier for the tuner. He didn't have to do all the learning and experimenting I did, But along with all my work came some revelations and results that riders like... results that Ivan wouldn't have found, because he didn't have to look.
I have already addressed the dyno chart stuff very clearly. Again, the stock run in 4th gear actually had the advantage of gearing, and my stock run is 5HP HIGHER than Ivan's... so where is the effort to lie on my part? It doesn't exist. I have posted this previously, but you keep it up. Here's my final word on your allegations... My charts are the exact same charts. I don't care if you don't like them. Stop trying to obfuscate and lie.
And did you notice that guys who had loose throttle cables adjusted them, and all was good? How about the guys that have low idle settings, think it's ok to tell them to get the idles where it should be, or valves adjusted in spec?
I actually share information with everyone here. I shared the datalog info about the slow TPS response, and a no cost fix. And somehow that's wrong of me?
At this point, we all see that you are clearly Ivan's shill. Your sales technique is one of tearing down another product that you have no knowledge of, and taking a clear opportunity to make personal attacks as you go.
If you notice, I have not attacked anyone else's work. I have not first hand knowledge to do so, therefor I can't make a judgement. We are very different in that, Roland. I deal in honesty and facts... you deal in obfuscation and lies.
Steve
