So folks Here is a question I've not seen. On the ride up to The Bun Cooler I stopped for fuel in Alamo NV. Put the 14 hunney on the center stand and saw a dribble of coolant dripping. A few table spoons. Aww Man! Filled up and rode her over to a shady spot. Put her back on the center stand and peeled some plastic back trying to find the culprit. No Joy. Ran the bike at idle to temp, fans kicked in and she cooled right back down. Rode her the rest of the weekend up to Kamiah watching the temp and checking at each stop for dribbles. Temp was rock solid and no spit. On the way home she did it again in Northern ID. Again just a few tablespoons. Rode home through traffic in Vegas at 90 deg temps. No overheating. Again cooling was rock solid. Pulled into the garagio and no spitting. Will be pulling plastic this weekend trying to find the issue. Fiche shows 2 o rings. Getting ready for 6 k to the nat. Anybody else ever seen this?
Check all the coolant line clamps that attach to the water pump, may be a mini leaker at one of them, I can't say that the waterpump itself should be needing replaced this early on, put anything is possible... even tho it is not a common happening by the reports both here and on the other site (probably only 3 iirc since '07). Also, look closely at the front of the cylinder block, by cylinder #1, down low, above the oil cooler... the coolant runs into the oil cooler, and there is a rectangular shaped "housing" on the block, where coolant is combined/devided, for flow to both areas.. there is a rectangular rubber o ring sealing that housing to the block, which is attached using 2 bolts... recently someone had a leaker there, which was easily fixed, but a bit tough to find/analyze in verbal conversation Here..
Good news is that seal, and all the others for the waterpump, are available from Kaw, unlike the old C10 issues...
I noted all of those seal part numbers in my response to that fellow, and will try to find it for you, do a quick search tho in the meantime..
I have all the p/n's written down here, but see if you can find where I already noted them..
Here's one...
http://forum.cog-online.org/concours-14-zg1400-general-chat-and-tech/another-coolant-leak-could-this-be-normal/msg632007/#msg632007Also note, the microfiche was updated on the most recent models, to actually show all the seals in that waterpump...
Check the 2017 page for parts grouping on "water pipe"
It shows them, and also that rectangular one for the housing up front (92055-1402)
https://www.kawasaki.com/Parts/PartsDiagram/203135/2017/ZG1400EHF
