Author Topic: Cutting Center stand w/ Muzzy links  (Read 1683 times)
Offline ABureau
  • COG#: 7579
« on: February 25, 2011, 10:16:01 pm »
 pretty much decided Muzzys links and  drop front too How much should I cut stand ? looks like clean cut off both stanchions remove about 3/4 to -1"  whose done it
Thanx
ronnielyons
  • Guest
Re: Cutting Center stand w/ Muzzy links
« Reply #1 on: February 27, 2011, 03:09:13 pm »
I added Muzzy's and pushed the forks up one inch. It does make it a little tougher to get up on the stand but I decided to pull a little harder instead of cutting the c-stand. I have about 3 inches of back tire clearance now when it's up on the stand and it'll make it easier to pull the back tire off that way. If you want to cut your stand, I'd start by cutting off the wrapped flat metal that's welded to the legs on the bottom and remove about half an inch from the legs of the stand. Bear in mind though you'll want to put these metal shoes back on or your c-stand will have a tendency to punch thru the ground.
Offline Nick
    • Super X Owners
  • COG#: 8891
« Reply #2 on: February 28, 2011, 04:59:43 am »
I didn't change my center stand either. It just takes a little more grunt to get it up on the stand.
Iron Butt Assn - Saddle Sore 1000, Bun Burner Gold (1500 miles/22 hrs) and 50CC (Coast to Coast-2481 miles/46 hrs)
Offline joe in calif
« Reply #3 on: February 28, 2011, 01:34:39 pm »
Are there any mods needed to the side stand?
« Reply #4 on: February 28, 2011, 08:06:45 pm »
If you lower the bike, the side stand will make it stand more upright. Then it may not be as stable on the side stand. That could result in the bike falling over. So I would figure that you should probably shorten the side stand.
Offline rlyons
  • COG#: 4150
« Reply #5 on: May 11, 2011, 08:25:59 pm »
I did take an inch out of the side stand and welded a foot plate on while I was at it. The center stand is still stock and hasn't been an issue.
Offline Gildaguz
« Reply #6 on: May 14, 2011, 01:28:22 am »
I did gring where the side stand stop and to de side stand itself to  make it go frward about 1" mesured at the end and now  bik is more stable and  when i need to put it in the center stand at home only just put rar tire over a 2x4 block
Gilberto
