Author Topic: Deactivate the low tps battery message?  (Read 1112 times)
Offline TC
  • COG#: 9521
« on: December 22, 2011, 03:38:03 pm »
It would be convenient to be able to get rid of the message until tire changing time. To be able to reactivate would be important.
Re: Deactivate the low tps battery message?
« Reply #1 on: December 22, 2011, 04:06:06 pm »
You can get rid of the warning each time you ride by resetting the dash. But every time you turn the key off and back on, it must be done again. Not the best way to go. But better than looking at the warning flash.
Offline joe in calif
« Reply #2 on: December 23, 2011, 09:12:05 pm »
When mine started doing it it would go away after a period of time, it would return but then go away again on it's own, but as stated by cap-n'Bob push the button on the dash to reset it.
