Author Topic: Delkevic Full System for $550 ?  (Read 8769 times)
Offline Rob
Re: Delkevic Full System for $550 ?
« Reply #100 on: December 01, 2019, 09:44:18 pm »
Which one are you referring too?
Their all shown with bags on.
I was referring to this one in particular:  https://delkevic.com/complete-de-cat-4-2-exhaust-concours-14-2008-2019-with-mini-8-carbon-fiber-round-muffler-and-stainless-steel-headers/
I realize that on the site they show a pic with the bags on, but surely the heat will feed right into the bag.
Even this guy had a meltdown issue and he is/was running a much longer can: https://delkevic.com/complete-de-cat-4-2-exhaust-concours-14-2008-2019-with-mini-8-carbon-fiber-round-muffler-and-stainless-steel-headers/
2017 C14
2005 Z1000
« Reply #101 on: December 02, 2019, 01:53:57 pm »
I'll agree that a turned down tip would be better but,,,,
  If your posting the picture of the guy that melted his rear bag hinge {??}
    http://forum.cog-online.org/concours-14-zg1400-general-chat-and-tech/damaged-bag-from-delkevic/msg668607/#msg668607
    Go back and look at his photo. Look at his muffler angle.
      He didn't adjust the outlet of his Muffler so that it didn't point directly at the hinge.
        Result was the melt down.
NOTE: Before you tighten the muffler/mid pipe clamps, you can rotate the mid pipe for optimum clearance.
          {Because of the bends in the mid pipe} it sort-of has a cam action that allows the muffler angle to be adjustable.
             You would be surprised by how much it can be adjusted. It just takes a bit of planning...
PS: Before Delk offered this; I built my system from a ZX-14 header and modified the mid pipes to get the angles/clearance I wanted.
       Believe me, anything is possible... Here is 2 versions of mine.
        http://forum.cog-online.org/concours-14-zg1400-general-chat-and-tech/zx-14-or-zx-14r-exhaust-for-a-c-14/msg638303/#msg638303
       http://forum.cog-online.org/concours-14-zg1400-general-chat-and-tech/zx-14-or-zx-14r-exhaust-for-a-c-14/msg650239/#msg650239
« Last Edit: December 02, 2019, 02:10:54 pm by connie_rider »
Offline strum
  • COG#: 12307
« Reply #102 on: December 02, 2019, 07:10:40 pm »
 I know we are talking Delkevic now but while on the subject of pipe angle burnt bags ect. here is where I am.  yall see any issues here?
  I have right at an inch clearance to the bag and 2 3/8" from the top of the hole to the bottom of the bag.
2016 C-14
« Reply #103 on: December 03, 2019, 02:52:48 pm »
about normal, but the stainless steel isn't going to help like carbon fiber does.
Steve
Offline strum
  • COG#: 12307
« Reply #104 on: December 04, 2019, 02:14:58 am »
 I actually took teds( thanks Ted) advice today and rolled the mid pipe to get a tick more clearance. By rolling the mid just a smidge it uses the muffler strap as a pivot point and  lowers the rear of the Muffler as it raises the front. This gave me about a 1/4 inch more clearance . May not sound like much but Ill take all I can get .
2016 C-14
56taskforce
  • Guest
« Reply #105 on: December 04, 2019, 07:35:03 am »
Also note that you not only gained 1/4" the exhaust exit is now directed more away from the bag. I have run A 14" carbon slash cut Delkalvic for about 20,000 miles without issue. Like Ted mentioned, in the post about the melted bag the cans exit was point directly at the bag it was caused more from where the can was pointed than its clearance.
Offline strum
  • COG#: 12307
« Reply #106 on: December 04, 2019, 11:52:59 am »
 You are correct. Before It was ever so slightly pointed up now its where it should be.  May have been fine anyway but I feel better .
2016 C-14
« Reply #107 on: December 04, 2019, 12:34:03 pm »
You did what I suggested?!?!  :-\
  No one "ever" does what I suggest. {Prolly because I'm normally wrong  :-[}
        I are amazed!!   :great:
While I'm on a roll;
     You can also loosen the hangar bolts and push down on the rear of the muffler while retightening.
     Will give you a bit more clearance and the mid pipe will normalize after several heat cycles and stay there..
56taskforce
  • Guest
« Reply #108 on: December 04, 2019, 02:13:45 pm »
Oh s*** you done it now Ted's head's so big now it'll never fit through his door. Don't worry Ted I have called the fire department  :))
« Reply #109 on: December 04, 2019, 11:48:29 pm »
Thanx Grant.
   I feel sooo much better knowing your lookin' out for me.
Offline MtnRider
  • COG#: 12840
« Reply #110 on: December 05, 2019, 02:25:42 pm »
Got that new larger size helmet ordered yet, Ted? I like the Shoei GT-Air.
2015 Black C14
Offline Rob
« Reply #111 on: December 05, 2019, 03:59:15 pm »
Only $390 at motorcyclegear.com right now.  :great:
2017 C14
2005 Z1000
