Concours 14 Discussion (C14 / ZG1400 / 1400GTR) => Concours 14 / ZG1400 General Chat and Tech => Topic started by: Gregg on April 05, 2018, 03:51:10 pm
Title: direction lights all flash when turn signal is used
Post by: Gregg on April 05, 2018, 03:51:10 pm
My 2010 Concours directions all flash when I either switch left or right?
Title: Re: direction lights all flash when turn signal is used
Post by: Jeff on April 05, 2018, 04:33:27 pm
My guess would be a bad ground somewhere, if not that switch could be bad?
Post by: MAN OF BLUES on April 05, 2018, 08:03:39 pm
Did someone replace the incandescent lamps with LED style?
Have you recently ridden the bike in extremely hard rain for a long period?
Have you washed the bike, and unknowingly subjected that switch pod or the lamp covers to high pressure water, during the process?
Have you added ANY aftermarket lighting devices or electrical devices to the bike?
Post by: Just Cliff on April 08, 2018, 11:27:35 am
I find very doubtful this is a water problem.
I think it's a ground problem of some sort. Somewhat similar to the ground problem in my 08. That was one of the ground blocks in the harness. Not a hard problem to fix, just a bear to chase down.
Good luck!
Cliff   :beerchug:
Post by: Derek on April 08, 2018, 04:49:09 pm
The ground problem they refer to could be a bad bulb.  I have found that if a incandescent bulb breaks its filament it can light through the other filament and travel through the circuit.  I'm betting all the bulbs that are flashing are really the parking filament flashing... thus not as bright.
Start by pulling the bulbs one at a time, with each bulb pulled if problem persist put bulb back and move to the next one.  If problem stops... replace that bulb!
Likely the easiest but maybe not the cheapest... bad ground wire could be hard to track down but $0 cost to fix, if its a bulb... it will cost you a new bulb.... $2 maybe!
Post by: gpd323 on April 08, 2018, 06:22:19 pm
The signals are single filament. There are no parking or running lights in the signal housings
