Author Topic: Does cleaning the gear position sensor ever work?  (Read 1119 times)
Offline Kreton'sLC
  • COG#: 13013
« on: June 13, 2019, 11:32:07 am »
My gear position indicator has been acting up recently - slow to respond to gear changes and sometimes not indicating the right gear.  I did the sensor test of pulling the clutch lever in while the bike is in OD but the indicator still shows 5, and the indicator changed to OD.  So it appears the sensor is the problem.
Has anyone restored sensor functionality just cleaning it?  If so, what did you use to clean it, and were you able to do so without completely disconnecting it and the two wiring harnesses?
2012 C14
Offline Freddy
Re: Does cleaning the gear position sensor ever work?
« Reply #1 on: June 14, 2019, 10:47:56 pm »
Yes - mine was similar some time ago.  I cleaned the contacts with very fine emery.  2 screws to remove from contacts on the end of selector drum.
Offline Kreton'sLC
  • COG#: 13013
« Reply #2 on: June 14, 2019, 11:30:19 pm »
Freddy - Just saw your post.  I hadn't heard back from anyone so went ahead and just removed the sensor (but not the other two connections) and wiped it and the the two pins in the shifter drum real good with a soft cloth.  Took it for a 50 mile ride and all is well!  It showed the correct gear with every shift and there was no latency.
If the problem returns though I'll try cleaning with a very fine emery cloth or very fine steel wool.
2012 C14
Offline KnoxSwift
  • COG#: 11037
« Reply #3 on: October 13, 2019, 11:54:59 am »
Bumping this old thread. I was having the indicator issue...I cleaned out the sensor and all is well.
However question, is a small amount of oil in the sensor area normal? Did you guys also find some engine oil in there?
When I cleaned out it wasn't an active leak nothing further dripping. Just not sure how it gets in there and if it is normal or should I be worried about some worn seal somewhere?
Offline Just Cliff
  • COG#: 9547
« Reply #4 on: October 13, 2019, 12:38:16 pm »
I've just noticed mine being slow to respond also. Guess I need to get the manual & find that sensor.
Sounds like an easy fix though!  :)
Cliff
2014 1000 V Strom
Offline gpd323
« Reply #5 on: October 13, 2019, 10:02:06 pm »
Where is the sensor? Mine is acting up too.
I found it!
« Last Edit: October 14, 2019, 03:29:55 pm by gpd323 »
Offline Derek
  • COG#: 11636
« Reply #6 on: October 15, 2019, 12:13:07 am »
Mine to... guess I will add it to my winter project list
2010 C14 Concours
1983 Honda V45 Sabre (sold)
Ottawa, Ontario
Offline Freddy
« Reply #7 on: October 15, 2019, 06:40:35 am »
KS, a small amount of oil there is normal.
Offline KnoxSwift
  • COG#: 11037
« Reply #8 on: October 15, 2019, 02:41:10 pm »
Thanks for the Confirmation!
 :beerchug:
Offline Just Cliff
  • COG#: 9547
« Reply #9 on: October 15, 2019, 10:40:48 pm »
I just cleaned mine, a simple 15 minute job. Don't do like me & spend a bunch of time looking in the transmission section of manual for location.  :-[ It's in the electrical section.
I used long handled needle nose pliers to pull it out. The 2 brass pins in the bike are spring loaded & will jump out. I didn't realize there was supposed to be one in the center hole until I reassembled it & saw it on the floor. So watch for it.
I see Greg has found it, but here are some pictures anyway.
Last picture is after cleaning.
Cliff
2014 1000 V Strom
« Reply #10 on: October 15, 2019, 10:59:13 pm »
thanks for posting that Cliff, would you place a link in the C14 tech area of the tech zone, just to show it, it may prove helpful for future use.
some where in here:
http://forum.cog-online.org/2008-present-zg1400-and-gtr1400/
thanks in advance, if and when mine starts acting up, I know now It is an easy and quick fix.
 :great: :great: :great: :great: :great: :great: :great: :beerchug:
Offline Diz
  • COG#: 12056
« Reply #11 on: October 15, 2019, 11:03:14 pm »
Great info! Thanks!  :great:
Offline gpd323
« Reply #12 on: October 15, 2019, 11:12:17 pm »
I have not taken mine apart yet, but thanks for the brass pins and the spring loaded part. Good to know.
Good pics, thanks!
Offline Kreton'sLC
  • COG#: 13013
« Reply #13 on: October 17, 2019, 01:14:40 am »
Regarding the small oil leak when cleaning, I learned to clean mine while changing the oil.  Any oil that might come out has most likely already drained by that point, but if not you'll catch it in the drain pan.  Also gives me something to do while waiting for the oil to drain completely.
2012 C14
