Author Topic: Does this look familiar?  (Read 1032 times)
Offline JerBear
  • COG#: 12777
« on: May 06, 2018, 10:10:30 pm »
I found this on the driveway near my Bike (C14).  It does look familiar but I have not been wrenching on her lately other than putting the battery back in from winter storage.  Does it look familiar to any of you? or is it some random spacer from one of my other projects? :confuse:
« Last Edit: May 06, 2018, 11:22:45 pm by JerBear »
2008 Silverdammit C14
Offline Vic
Re: Does this look familiar?
« Reply #1 on: May 06, 2018, 11:12:38 pm »
I'd put in my two cents, but not when I have to download a zip file to see the evidence!
Offline JerBear
  • COG#: 12777
« Reply #2 on: May 06, 2018, 11:23:33 pm »
I understand, I'm not sure how else to get the photos I have attached to the posting?
It's a small metal disk with two diameters and a hole that goes through it about 6mm the flange is about .100 thick and the smaller one is twice as long and about .300 in diameter.
« Last Edit: May 06, 2018, 11:26:35 pm by JerBear »
Offline Harry Martin
  • ☺ Cartoonist ☺
  • Fear is not boring
    • Harry Martin Cartoons
  • COG#: 4090
« Reply #3 on: May 06, 2018, 11:33:20 pm »
Here...I put them both on one image.
Looks like a brass bushing.
Offline SpeedyCoop
  • COG#: 12609
« Reply #4 on: May 06, 2018, 11:38:20 pm »
Looks like one of the bushings that go on the battery cover or body panel bolts that Kawasaki charges too much for!
Offline JerBear
  • COG#: 12777
« Reply #5 on: May 06, 2018, 11:45:04 pm »
It's steel, magnetic.  The large diameter is a bit more than 5/8ths the small is 3/8 the large is a bit thicker than a 1/16th of an inch the smaller diameter one is 5/32nds long
 the center through hole is 1/4dia.
Online AmphibSailor
  • Hooligan
  • COG#: 12210
« Reply #6 on: May 07, 2018, 03:21:17 am »
Were you working on the luggage rack?
Offline sam_uk
« Reply #7 on: May 07, 2018, 04:16:05 am »
 Could they be Exhaust mounting bushes
Offline Deepsea
« Reply #8 on: May 07, 2018, 05:47:19 am »
I know you've said you only installed the battery, but did you remove Any of the plastic body panels?
Retired Navy Saturation Diver
« Reply #9 on: May 07, 2018, 05:08:33 pm »
Got lost when fuel tank was removed...
92152-0364 collar
2 of them, installed in the bottom of the rear rubber bushings that the gastank hold down bolts pass thru, to the frame mount...
Send money...  :great: :rotflmao: :beerchug:
Offline Deepsea
« Reply #10 on: May 07, 2018, 05:22:43 pm »
Darn MOB. How do you keep all this minutia in your head? I can hardly remember what day it is when I wake up in the morning/night/afternoon. Maybe that's my problem, each day starts at a different time. :-[
« Reply #11 on: May 07, 2018, 05:46:50 pm »
Easy, I have a very large head..... :)) :))
I killed off all of the defective brain cells at an early age, so the left over ones are like a sponge....
That, and I've turned a few bolts on these bikes, and know the parts... oh, and I have no job...... :rotflmao: :nananana: :rotflmao:
But I have stayed in a Holiday Inn Express a couple times.... :rotflmao: :motonoises: :great:
That's my story, and I'm sticking to it..... :truce:
Offline Deepsea
« Reply #12 on: May 07, 2018, 05:54:52 pm »
BIG head indeed ! :rotflmao: :rotflmao: :rotflmao:
This "That's my story, and I'm sticking to it." has saved my butt more than once :))
« Reply #13 on: May 07, 2018, 06:26:46 pm »
Insaid LARGE... not big... :rotflmao: :great:
Offline CRocker
  • '02 C10 CDA # 416
« Reply #14 on: May 07, 2018, 06:28:45 pm »
Yeah...it probably was that Holiday Inn Express thing...after all...
Offline Deepsea
« Reply #15 on: May 07, 2018, 06:33:55 pm »
It's all about perception. :beerchug: Large, big, tiny, small, what did she call it. :nananana:
Cheers
« Reply #16 on: May 08, 2018, 08:54:41 pm »
After thinking a bit more, knowing there are a bunch of various length collars with the same diameters, I do think its the fuel tank rear mount ones... the others vary in length.. and are longer..
11mm lg, -0445 mounting gage cover to cowl brkt
12.1mm lg, black, -1651 mounting relay bracket to cowling tube bracket
?mm lg. -0666 mounting tail light bracket to tail section frame
13.1mm lg (3 pcs) -251 mounting raer inner fender plastic from bottom to frame bottom..
Those are all for M6 screws, and used in pairs, except one,  I'm sure I missed a couple somewhere.
Offline JerBear
  • COG#: 12777
« Reply #17 on: May 12, 2018, 09:39:58 pm »
Didn't want to just leave this hanging out there.  I checked the gas tank bolts even removing them to be sure and the bushings are still in the rubber but they are very close in thickness and size unless it is an extra that fell out after ten years and 40K miles while in my driveway I have no idea what it is.  The only fairing panel that I removed was the small battery access panel and I don't think that the one bolt had anything odd behind it, the bolt has a plastic washer and a shoulder on it to line up the panel to the hole/bolt.  I'll hang on to it, perhaps to will become more obvious to me at some point later.  Thank you all for your help/suggestions.   ;D
You know, come to think of it I did remove all of the stuff in the battery tray area while cleaning the electrical connections.   I removed the plastic tray and adjusted the wires several times before I got it right.  Maybe there was one of those babies extra laying in there all this time and my cleaning/messing with that area dislodged it?
 :67:
« Last Edit: May 12, 2018, 09:46:57 pm by JerBear »
« Reply #18 on: May 12, 2018, 10:20:40 pm »
There are a couple that are used to mount the ABS pump in there(which I missed...doh), but its not unlikely that during assembly,nwhen the stuff is being assembled at lightening speed... :rotflmao:  Yoko Sockytumi may have dropped one, and simply carried on..
No big deal... if you start finding bolts on the ground... well,  I ain't gonn go there... :rotflmao: :rotflmao:
Ride safe man,
