Author Topic: Lowering the C14?  (Read 1738 times)
Re: Lowering the C14?
« Reply #25 on: July 03, 2018, 07:00:31 pm »
Great idea!
   err, Is that what you did??
Offline Harry Martin
  • ☺ Cartoonist ☺
  • Fear is not boring
    • Harry Martin Cartoons
  • COG#: 4090
« Reply #26 on: July 03, 2018, 07:09:26 pm »
Great idea!
No, that wood be stupid.  :(
I use these:
« Reply #27 on: July 03, 2018, 07:27:24 pm »
I use these:
"Enuff sed" !!   :rotflmao:
« Reply #28 on: October 21, 2018, 06:50:03 pm »
I decided to build my own Lowering Links as the Muzzy's I had lowered the bike more than I wanted.
We shortened a set of ZX-14 Links to built mine.
While I was installing the new Links, I took some time to check some dimensions.
Decided to post it in case it helps someone else...
NOTE: All measurement's were done with the bike on the center stand and the rear wheel NOT touching the ground.
          Measurement's were taken from the axle to the frame.
           This is the only way to see the actual dimensional change with each Link.
Stock Links     Stock height
My Links         Lowered the rear     3/4"
Muzzy Links    Lowered the rear  1 3/16"
ZX-14 Links    Lowered the rear  2 9/16"
Hope this helps someone?
