Author Topic: Engine not starting  (Read 876 times)
Offline arieux
Engine not starting
« on: January 12, 2018, 08:58:50 pm »
I tried to start my c14 2012 this morning and it would not and sounded like it was out of gas but the tank is almost full.
This afternoon, i tried again:  the engine does not even try to start this time and i hear knocking in the head.
I am not getting any error message.
The engine was working fine after i changed the oil in December and i have not used it since because it is winter with a lot of snow and very cold.
If someone has an idea  i would appreciate.
Regards.
« Last Edit: January 12, 2018, 10:21:29 pm by ron203, Reason: typo in title when moved -rs »
Offline gPink
  • MMVIII C XIV
Re: Engine not starting
« Reply #1 on: January 12, 2018, 09:14:30 pm »
Did you ever replace the battery and abrasively clean all the ground connections?
« Last Edit: January 12, 2018, 10:22:11 pm by ron203, Reason: typo in title when moved - rs »
Offline Diz
  • COG#: 12056
« Reply #2 on: January 13, 2018, 10:00:11 am »
A bit more info might be helpful. Is the starter running when you hit ignition button? You say it sounded as if it were out of gas; does this mean the engine was turning over, but no sounds of ignition?
Offline seagiant1
  • COG#: 11323
« Reply #3 on: January 13, 2018, 11:25:00 am »
Hi,
      Check the "KILL" switch!
Don't ask me how I know this!
Kids love to play with things! ;D
Offline gpd323
« Reply #4 on: January 13, 2018, 12:46:03 pm »
I call dead battery lacking any additional info.
Offline jwh20
« Reply #5 on: January 13, 2018, 05:41:33 pm »
The most common problem with the C14 not starting is with the electrical system, specifically the battery (-) to frame connection and the battery itself.  Start, as already noted, with the frame connection.  This is the #1 trouble spot.  You get corrosion built up and it prevents a good electrical connection.  The corrosion is Aluminum Oxide which looks exactly like Aluminum so you cannot see it but it is a good INSULATOR.  Remove the connection, clean the frame connection point with abrasive, put a tiny bit of dielectric grease (or just plain axle grease if that's all you have), and re-install the connection.  If that doesn't solve the problem, then pull the battery and take it to a shop and have it load tested.  A voltmeter check WILL NOT suffice here.  Many bad batteries show good voltage but will not produce enough power to start the bike.  Only a load test will show.
If both of these look good, then it's more complicated.  Report back and I'm sure there will be more advice...
2012 Concours 14 Arabian Red
« Reply #6 on: January 13, 2018, 07:06:40 pm »
When you tried to start, did the motor turn over sluggishly or with vigor?
During the non riding season, I put a Battery tender on about every week and a half to keep the battery healthy. I also put a tender on the 900 to top off it's battery. When the tender goes to the float mode I pull it off and move on. During the riding weather I don't worry about it because the bikes get ridden often enough to keep the batteries up.
I have the ability to heat the garage but only heat it when necessary so the bikes have been sitting in a very cold garage. It cost a lot to just heat the house.
I lost the battery on the 09 in 2010 because I went too long without giving it a charge during the winter. Kawasaki replaced the battery under warranty.
Offline JTX
  • TEXAS 2015 ZG14
    • 2015
« Reply #7 on: January 13, 2018, 08:21:30 pm »
Theres not enough info known to make a suggestion...
Offline walter
« Reply #8 on: January 13, 2018, 08:24:35 pm »
Hi,
 :iagree:
