Author Topic: Evitek LED Lighting Question  (Read 2335 times)
Offline bschulz
  • COG#: 10128
« on: March 02, 2017, 12:43:14 am »
I just installed the Evitek lights.  When the lights "click" into the mount they are not vertically oriented.  The first picture below shows a light right out of the box.
However, when I installed the lights, it seems to me they should be vertically aligned as in the 2nd picture.  Its easy enough to rotate them in this position past the "click".  I just want to check with others to see how you oriented your lights?
Offline mattchewn
Re: Evitek LED Lighting Question
« Reply #1 on: March 02, 2017, 02:17:08 am »
If the lights are not oriented vertically the effectiveness of the "hood" on the LED chip will be reduced a good bit. This hood is what gives the clean and sharp cutoff line in the light pattern so you aren't blinding oncoming traffic. If you can get them vertical and they will stay securely in that position go for it.
2018 H2 SXSE.  (FAT SXSE)
2011 GSX1250 FA
2009 Ninja 500R. (wifes')
2001 Bandit 650  (kids')
Offline Tommy
« Reply #2 on: March 02, 2017, 01:36:47 pm »
Mine were indexed and I didn't have a problem with alignment.
You will have to make sure they rotate fully into the locked position. The rubber boot can make this difficult.
The holder is also indexed and should only fit one way. The tabs are different widths.
Offline bschulz
  • COG#: 10128
« Reply #3 on: March 02, 2017, 07:49:20 pm »
That's what I was thinking too, but I checked before installing.  The first picture is with them rotated into the locked position.  You can see that they are not in the vertical orientation.  The tabs are different widths on mine also, but regardless seems obvious which way they should be inserted.
When I over rotated them into the vertical orientation, the black cable is pointed straight down at 90-degrees to the ground.
Offline TFly
  • CDA #414
  • COG#: 10339
« Reply #4 on: March 03, 2017, 07:48:55 pm »
i just installed a set and found that it was easy to over rotate past the index stop. just be gentle when locking in position and they should line up- like your picture but at 12:00/vertical
Todd Flynn
Narragansett, Rhode Island
2011 C-14 Black
V&H CS1
Offline turbojoe78_MA
  • COG#: 8645
« Reply #5 on: March 04, 2017, 10:50:06 am »
It may be that the Evitek sets are sold for cars and there is a left bulb and a right bulb.
I have the Evitek's in my bike and I think I remember something about there being a difference in orientation for the left and right sides.
Offline Deanc
  • COG#: 10429
« Reply #6 on: April 02, 2017, 05:21:12 pm »
Raining in DFW today, so decided to install the Eviteks.  Was able to figure out how to remove the stock bulb and replace with the Evitek, no problem.  Now, reinstalling the bulb back in is tricky.   I was able to fold the rubber lip back to fit the bulb into place and gain access to the retainer, but I could not get the retainer back into position because the lip of the rubber boot keeps flipping back.
Seems like I need two hands to get in there to hold the rubber boot back, hold the bulb, and push the retainer into place but there is hardly any space, even with the top inner cowlings out.
Is there a certain technique to getting the retainer back into place?  Does it take two people?
2011 C14 Silver, Canyon Cages, Leo Vince SBK exhaust, Sargent seat, SISF Evolution Flash, etc.
Offline mattchewn
« Reply #7 on: April 02, 2017, 06:45:39 pm »
Dean,
First, remove the rubber boot completely. Once you separate the bulb from the base it should be relatively easy to install the retainer clip. After that you can install the boot and then the bulb.
2011 GSX1250 FA
Offline Jorge
  • COG#: 9297
« Reply #8 on: April 03, 2017, 08:53:30 am »
+1 on Matt.
The rubber boot fits around the base the same as on a regular H4 bulb. Place the base, then re-install the boot and push it round the base to the boot's normal position. Then insert the bulb.
Offline Tommy
« Reply #9 on: April 03, 2017, 11:14:12 am »
As I recall, the hoods should be aligned horizontally not vertically.
I'm at work so I can't look at mine right now but I'm pretty sure the hood is horizontal and the cup side is facing up (reflects the light upward for low beam).
The tabs do align the bulb correctly but they can be over-rotated easily and it's difficult to feel the detent.
Offline curt1480
« Reply #10 on: April 03, 2017, 08:15:58 pm »
Kind of a side question on the lighting of the Concours 14.  Most have said the light on projects about 10 to 20 feet in front of the bike in stock configuration.  Does anyone have an idea of how many turns it takes to get the light projected at least another 20 feet down the road.  I know I gave mine another 2 or 3 turns and it does not seem like it has done anything.
Offline Deanc
  • COG#: 10429
« Reply #11 on: April 06, 2017, 07:41:58 pm »
Thanks for your replies Matt and Jorge.  I'll try to get the rubber boot over but it seems to be a tight fit.  Thought that way to install the rubber boot was to remove that sleeve (with the tabs) over the bulb, install the rubber boot, then put the sleeve back on to keep the boot in place.  Then bend the lip of the rubber boot back to get access to the retainer.  I'll give it a shot again.
Offline mattchewn
« Reply #12 on: April 06, 2017, 08:43:02 pm »
DeanC,
Much easier to install each piece individually. Install the adapter plate and then retainer wire. Install rubber boot and then install bulb. Easy peezy.
2011 GSX1250 FA
Offline Jerdurr
« Reply #13 on: September 29, 2017, 06:26:35 pm »
DeanC,
Matt, I received my Evitek's today, gonna install them tomorrow; If I install the rubber boot before installing the bulb, how will I be able to install the bulb? Wouldn't the boot be covering the hole where the bulb goes in?
What's the concensus? In the 12-6 orientation (vertical), or 3-9 (horizontal)? If horizontal, the cover of the bulb aiming up or down? If vertical, the cover on the inside, or on the outside?
Thanks man!
Best,
JD
Offline gpd323
« Reply #14 on: September 29, 2017, 07:06:10 pm »
12/6 is the correct orientation. But, when viewed from the front the LED is just slightly rotated clockwise a degree or two when its twisted into the H4 adapter. Cut a hole in the rubber boot in the center is what I did.
Offline Fred_Wa2gzw
  • COG#: 10400
« Reply #15 on: September 29, 2017, 11:00:12 pm »
Its been a while since I installed these but I DID NOT have to cut the rubber boots!!!  I found that if I tried to get them exactly vertical the vibration on the bike will cause the bulbs to eventually come out of their sockets on their own.  I would suggest that you do not turn past the detents and they will work fine.
Fred
« Last Edit: September 29, 2017, 11:04:51 pm by Fred_Wa2gzw »
Offline gpd323
« Reply #16 on: September 29, 2017, 11:20:07 pm »
Fred
Yes, not sure but I don't think I cut them either. Just looked at them. Thanks Fred
Offline Jerdurr
« Reply #17 on: October 02, 2017, 02:17:35 pm »
So guys, I mounted the Evitek LED lights on Friday night (I know, my social life is WILD!), but to be frank, unless I didn't install them properly, I'm not a fan of the pattern.
This is what I did. Removed the old bulb, installed the tabbed circle, put the metal holder back in place, re-installed the rubber boot, and put lastly installed the LED bulb and turned it so it clicked. The bulb is currently in the vertical position (I will add some pics later). I'm not seeing the "nice cutoff" everyone is talking about.
On low beams, it is bright, there's a big patch of light about 6 feet from the bike, and that patch moves closed or further if I play with the "up-down" dial. However, the pattern itself does not change.
It gets even worse when I put it on high beams; the pattern is totally off and basically it's not illuminating the road. What did I do wrong? HELP! :??: >:(
Best,
JD
Offline sfsokc
  • COG#: 10667
« Reply #18 on: January 08, 2019, 06:16:50 am »
Finally installed these LEDs (Evitek H4 6500K).  I had them laying around for a couple years now.  lol.  Here's the deal-- they are NOT designed properly to match up in the correct orientation upon installation!  CLOSE, but not quite.  After comparing to my halogens, it's obvious they do not match up.  And after a test drive at night, it was also obvious-- no clear cut-off; just light all over the place!  :(
So here's the deal.  The yellow LEDs should be facing EXACTLY horizontal (3 and 9 o'clock).  And the little reflector cup should be facing exactly straight up (12 o'clock).
From the first picture, you can see how it deviates clockwise from the upside down "Y".  It should do this a LITTLE, but the Eviteks are like double the inclination that they should be.  Second and third pictures show them properly mounted.  As you can see, they are off, and need to be further rotated counterclockwise when looking into the headlight.
Want to fix them?  Here's what I did...  Take the lights out of the housing.  With a small sharp knife (or other instrument) make three little cuts to extend the plastic race (4th picture) and then gouge out a little bit of plastic to extend the "stop" another 2-3 millimeters.  This was all I needed to rotate them a bit further so they were all squared up.  The difference was quite significant!  Well worth the effort...     :)
« Reply #19 on: January 08, 2019, 05:22:53 pm »
Yeah, it takes a number of turns before you will see any noticeable movement in the head light beam. Keep turning and you'll get there. I would have the head lights aimed at a wall or something so you can see the beam movement.
