Author Topic: Excessive Play in Windscreen  (Read 9455 times)
Offline elektra
  • COG#: 9508
« on: September 06, 2013, 04:48:09 pm »
So, I have had this problem with my motorcycle that has bugged me for weeks. My windshield and dashboard have been flopping around, especially when I go over bumps. Im thinkin this ain't right, and I don't remember this happening before. So I stopped by both Las Vegas Kawasaki dealership's service departments and showed it to the techs. They all said nothing wrong, just your oversized windshield is a bit too top heavy. Ok, that's a bunch of bull... and exactly why I do all my own service work. I know this isn't right and they just don't have a clue.
The past week I have taken the windshield off several times and removed the front panel to have a look inside to see what might be loose. All seemed ok. All the bolts are tight. What could it be? The parts department at the  the Kawasaki  dealership  was not even showing any replaceable bushings that might have worn out. The dash instrumentation, electric windshield motor, cables, arms and brace are all one unit. It is stabilized on the front side by bolting to the fairing. How it is stabilized on the back side I don't have a clue because you can't see it.
So last night Im getting really frustrated and Im looking down below the handle bars where the back side should bolt to something. However, I can't see anything wrong or loose. I go down to Ride Now, where I bought my Concours, to look at a new one. Maybe there is something I missed. Well there was. The back side of this rather heavy unit does, in fact, bolt directly to the frame. I can easily see the two bolts on a new one. Have the bolts on my bike loosened and vibrated off? Check with parts dept and of course they don't have the replacement bolts, but I did get the description 8mm X 53mm standard thread pitch.
Ok, stop at Ace Hardware and pick up two stainless bolts, nuts, washers and lock washers and head home. Sure enough, now it was so obvious that the bolts, 8mm is pretty stout, had worked loose and fallen off and were missing from where it mounts to the frame just forward and below the triple tree. The microfish did not show lock washers, just cap nuts, but I thought them appropriate, along with some locktite. A little tricky to get the bolts in, had to wiggle the dash unit so the holes would line up, and very difficult to get a wrench down in there to tighten things up, but it was eventually doable.
Took it out for a test ride and perfectomundo. All the slop was gone, the windshield was tight even going over bumps, just like when brand new.
Just goes to show you that the service mechanics aren't all that bright. With a little know how and skill you can figure it out and fix most things yourself. I don't know what would have happened eventually, but Im guessing it would not be good, as something would have cracked or broken. My 2011 just passed 50K so I will blame it on time and vibration.
'70 Honda 305 Dream, '79 Triumph 750 Bonneville, '85 BMW K100 Turbocharged, '95 HD Heritage, '97 HD Dresser, '97 HD Road King, 2001 HD Dyna, 2009 Kawi C14, 2011 Kawi C14 ABS
Offline Old Man on a Connie
  • COG#: 9932
Re: Excessive Play in Windscreen
« Reply #1 on: September 06, 2013, 10:45:12 pm »
Friend, You and me have got to hook up. I'm about ready to carry a picket sign in front of these dealers here. Heading down to Carter tomorrow for a weepy fork seal. Expect them to have the bike for 3 weeks and still screw it up. I know I know. Do your own work. And I agree. But why pay for a warranty then?
Offline mattchewn
  • COG#: 10993
« Reply #2 on: September 07, 2013, 12:33:48 am »
Mark,
Just move over this way. You'll be closer to the upcoming national and there are some great service dealers you can get to.  And we have a couple decent areas to ride  too!
2018 H2 SXSE.  (FAT SXSE)
2011 GSX1250 FA
2009 Ninja 500R. (wifes')
2001 Bandit 650  (kids')
  • COG#: 9932
« Reply #3 on: September 07, 2013, 01:12:58 am »
Mark,
It's that whole work paycheck thang.
Offline Cougr67
« Reply #4 on: September 07, 2013, 09:16:21 pm »
I have always felt that my windscreen was a bit loose also but kinda figured it was just the design. Your post got me to looking and this is what I found! :-\
I assume these are the bolts you were talking about. One of mine is missing and the other is barely holding on!
Thanks for posting Elektra! This was a great help!
Offline mattchewn
  • COG#: 10993
« Reply #5 on: September 08, 2013, 02:18:53 am »
[/quote]
Mark,
You're in luck, I checked and we have those paycheck thingies over here too! From what I have found out you can even do some paperwork and get one for free for as many years as you like. Obama said so! So come and get yours and get the connie fixed!
2011 GSX1250 FA
Offline irishal
« Reply #6 on: September 08, 2013, 12:35:00 pm »
Cougr67....did you have to remove anything to get to that area in your pic?
Offline Cougr67
« Reply #7 on: September 08, 2013, 03:19:33 pm »
Irishal;
nope, leave the handle bars straight and look down below the triple tree from the left side. Those bolts are orientated side to side.
Offline RS
  • COG#: 9763
« Reply #8 on: September 09, 2013, 09:24:58 am »
I checked these on my 09 with 22000 miles. I found the top bolt a bit loose, and the bottom nut was missing with the bolt backed out about 2 inches. I installed a new nut nd all is well. Thanks for the tip.
Offline RS
  • COG#: 9763
« Reply #9 on: September 09, 2013, 09:29:20 am »
I forgot to mention that I had installed the MRA Vario windscreen and tested it going down to Deals Gap in July. This shield works great in reducing buffeting and allows you to enjoy full wind blast when it's hot out.
Offline Brass
« Reply #10 on: September 09, 2013, 11:06:34 am »
If your having trouble finding them on my 2012 the bolts are gold in color
Shaun - Collegeville PA
2017 Yamaha FZ-07
Offline gasman5.0
  • Ride it like you stole it
« Reply #11 on: September 10, 2013, 07:54:17 pm »
I went thru this same deal a few years ago... looked at the whole assembly and never found nothing worn or faulty so after looking around I found the same missing bolt
 and loose top bolt just like the OP. new bolt and a generous dose of blue loctite for both mount bolts and the issue was cured.
Offline elektra
  • COG#: 9508
« Reply #12 on: October 05, 2013, 03:17:34 am »
Many of us, it appears, have experienced this issue. Some have not discovered this yet but may be living with the symptoms. I barely noticed it enough to take action only after months of riding with the windscreen flopping around. That they used cap nuts instead of lock washers is the faulty design. Coincidentally my bottom bolt was gone, and the top bolt was loose and backed way out. The only thing preventing the top bolt from falling out completely was the brake line. They changed the specs on the bolts due to this issue from 50mm to 53mm M8. It appears that the bolt was not extending inside the cap nut deep enough to self tighten. If every owner checked their bike for this issue I would expect there would be many more surprises. Should be a recall item.
Offline LouSpag
« Reply #13 on: January 29, 2015, 04:36:32 pm »
I know this post is old, but thank god i found it.  It seems that I can be added to the list of missing these bolts.
When I first test rode the bike I noticed the shield and part of the nose seemed a bit lose over bumps.  I was assured by the owner that the dealer had just gone through the bike and didn't find anything that wrong.  Well, I was searching this forum for this specific problem and came across this thread.  After checking the bike I am missing both bottom bolts and the top left was lose.  Needless to say I order replacements.  I couldn't find 53mm M8 so I opted for the 50mm M8 but will be using Loctite on the bolts and check them every other oil change until I'm comfortable they wont move again.
Thanks for this forum & this post  :great:
louspag
~~~~~~~One Day At a Time~~~~~~~~~
2000 ZX12r
2009 Concours 14
2012 ZX14R
Offline JC
  • El Paso, TX USA
« Reply #14 on: January 29, 2015, 08:51:48 pm »
May I ask where are those bolts? Not clear to me from the picture. Want to check them on the new bike to avoid losing them. Thx.
2015 Candy Lime Green Concours14
MODS: TBR black-series slip-on w/P1 insert, black/heavy Throttlemeister, Grip Puppies, FendaExtenda, radiator grille with fiberglass screening, billet black oil-filler/final-drive caps, CB MiniEuro tinted screen, LED city-lights/rear turn-signals/license-plate lights, no stickers, no reflectors, no badges.
Offline mattchewn
  • COG#: 10993
« Reply #15 on: January 29, 2015, 08:57:30 pm »
JC,
They are on the front of the frame at the steering head. They attach the fairing stay to the front of the steering stem. Look in the front below your ignition switch assembly tucked in between the brake lines.
2011 GSX1250 FA
Offline JC
  • El Paso, TX USA
« Reply #16 on: January 29, 2015, 09:09:32 pm »
Thanks Matt. That's probably where I was looking at from under the bike... but there's a plastic cover and can't see anything other than the 2 brake lines coming out of there. Will have to remove the horn, and then that plastic cover. Does your bike have that too? Want to make sure that's the right place before removing anything in vain. Thanks a lot again for your great help :great:.
Offline LouSpag
« Reply #17 on: January 29, 2015, 09:44:14 pm »
JC, you don't have to remove anything.  Look from the top down on both sides.  Start at the ignition and look downward.  You will see them. Put a wrench on them to see if any are loose, replace any missing and use Loctite.
louspag
2000 ZX12r
2009 Concours 14
2012 ZX14R
Offline JC
  • El Paso, TX USA
« Reply #18 on: January 30, 2015, 01:24:20 am »
Got it Lou; thanks a lot. I actually checked the nuts on the other side, and seem tight (couldn't apply much torque, but are not loose). Kawasaki should have used locking nuts there. My screen has some play, but must be normal. When I remove it to replace it with the CopperDawg, will check things better. Thank you again.
« Reply #19 on: January 30, 2015, 05:31:03 am »
 i really have to ask why you would have to remove, and replace, a seemingly far superior OEM screen to what has been installed for the first 8 editions, with an aftermarket replacement?
and if and when you do, you will need the OEM old style plastic external runners to go along with it, as you will need to send the ones that came with yours along with the screen..if indeed the bolt pattern IS exactly the same..
some things need proving out before changing. just saying..... :-[
call me stupid if you deem so, but I just don't understand the mindset here....
feel free to put me on your ignore list here also. I'm not going anywhere soon. :beerchug:
edited, and apology to Copperdawg  :truce:
« Last Edit: January 30, 2015, 10:08:03 pm by MAN OF BLUES »
Offline EZ
  • COG#: 11785
« Reply #20 on: January 30, 2015, 04:04:56 pm »
Amazing coincidence!! Thanks LouSpag ever so much for the bump... Washing the old gal night before last due to rain and noticed that the windscreen seemed a bit loose?? I didn't investigate to much cause I was trying to get done before dark. Long story short, saw this post, checked to see if this was the case and now I love this forum even more. :sign0098:  Caught it really early and addressed without issue!! What a fantastic pool of resources..  :beerchug:
Offline Flat-spot
  • COG#: 11111
« Reply #21 on: January 30, 2015, 06:53:00 pm »
Went to garage to check.  50k on '08 and still tight.  Makes ya wonder what else gets missed in assembly.
'08 C14
Offline stevewfl
  • COG# 9334
  • COG#: 9334
« Reply #22 on: January 30, 2015, 07:44:52 pm »
>92,000 miles with a Cee baily's Ultra screen.  Maybe I should check those bolts one day too, you guys got me worried
KiPass!
Offline Copperdawg
  • Copperdawg Specialties
  • COG#: 11150
« Reply #23 on: January 30, 2015, 09:58:56 pm »
i really have to ask why you would have to remove, and replace, a seemingly far superior OEM screen, with a definitely inferior aftermarket replacement?
Wow. I think it would be real hard to determine that without actually riding with both. But okay - thats your opinion. I'm betting my screen is still cooler and quieter with less disturbance from air than the new screen but time will tell. I know for guys that ride in hot temps, they say there is nothing else that compares. YMMV
When the 2015 appeared, I looked into the matter because I would need to know if my screen would fit the new models. I was in the process of doing this when contacted by JC. I have cross checked parts and I know the spacing of the three posts that the bolts secure to that hold the windshield on each side are the same.
I have also looked into the parts that will be needed to install a C14 Sportscreen and they are:
14091 @13.95
14091A @ 13.95
92161A @ 6.85
92172 @ 2.95
92153 @ 2.95
92200 @ 2.95
Total  43.60
In any case I also told him that if the screen did not fit I would offer a 100% refund.
Patrick
« Reply #24 on: January 30, 2015, 10:06:00 pm »
14091 @13.95
14091A @ 13.95
92161A @ 6.85
92172 @ 2.95
92153 @ 2.95
92200 @ 2.95
Total  43.60
Patrick
sorry Patrick, I should not have used the word "inferior", I apologize, and will change my posting... I gues it would have been better worded as "why change something that sets the new model apart from the past models, that everyone complained about, without seeing if Kaws new mod was worth it..."
 :truce:
