Here ya go. Make sure not to over fill. Do NOT spin the rear wheel while filling. HTH
C14 Final Drive Oil Change
up the oil by running the motorcycle so that the
• Warm
oil will pick up any sediment and drain easily. Stop the
motorcycle and turn the key knob to OFF.
Place an oil pan beneath the final gear case, and remove
the filler cap [A] and drain plug .
WARNING
When draining or filling the final gear case, be care-
ful that no oil gets on the tire, spoke, or rim. Clean
off any oil that inadvertently gets on them with a
high-flash point solvent.
the oil has completely drained out, install the drain
• After
plug with a new gasket.
Torque - Final Gear Case Drain Plug: 8.8 N·m (0.90 kgf·m,
78 in·lb)
Maintenance Procedure
the final gear case with the specified oil and quantity.
• ○ Fill
The oil level [A] should come to the top of the filler open-
ing.
Final Gear Case Oil:
Amount:
about 160 mL (5.41 US oz)
Grade:
API GL-5 hypoid gear oil
Viscosity:
When above 5°C (41°F) SAE 90
When below 5°C (41°F) SAE 80
NOTE
○ The term “GL-5” indicates a quality and additive rating.
A “GL-6” rated hypoid gear oil can also be used.
• Be sure the O-ring is in place, and install the filler plug.
