Author Topic: Vacuum Hose  (Read 1239 times)
Offline turbojoe78_MA
  • COG#: 8645
Vacuum Hose
« on: March 24, 2018, 01:33:10 pm »
I'll be doing a valve check and throttle body sync on my bike soon, and was wondering if anyone knows what size I.D. vacuum hose I need to run lines from the throttle body's for checking?
Will this work?   https://www.amazon.com/Pico-5161PT-Vacuum-Tubing-Package/dp/B00030CZMS/ref=sr_1_1?s=automotive&ie=UTF8&qid=1521901318&sr=1-1&keywords=rubber+vacuum+hose
The hose is the last thing I need to get, except for shims and I'll get them when I find out which ones I need.
Thanks,  Joe C
Re: Vacuum Hose
« Reply #1 on: March 24, 2018, 06:49:55 pm »
I can't remember exactly which I used when I did mine, I don't think it was 1/4", probably 3/16", but you won't be installing it until you finish up the valves, prior to putting the valve conver back on, and I got mine at Autozone, Advance automotive or PepBoyz also carries it, as well as NAPA...  for like $4 for a 6 ft section, so do a walk in after you pull one of the rubber caps off, and match it up.. and don't forget to pick up 4 babrbed "splice" pieces, so you can use them at the side and re cap then by using the original caps...
Number the hoses when you do this, and clip them into a plastic spark plug wire "loom/holder" which can be taped or tiewrapped to the left side removable upper frame brace... its a handy spot.
Offline Guest
Re: Vacuum Hose
« Reply #2 on: March 25, 2018, 12:54:38 am »
I used the hose that came with my Carbtune.  Their website indicates 5mm ID for the hoses, so that would fall between 3/16 - 1/4".  I imagine both would work.
  • COG#: 8645
Re: Vacuum Hose
« Reply #3 on: March 25, 2018, 12:16:45 pm »
Thanks MOB,  that sounds like the way to go.  I'll make sure to get the I.D. spec and report back to this thread for future references.
Joe C
Re: Vacuum Hose
« Reply #4 on: March 25, 2018, 06:30:31 pm »
I think that 5mm dimension is what I measured, so try the 3/16" as it will fit tightly, and stay on the nipple, 1/4" may be loose, and a hiddin and unseen hose loss deep in there in the "cave" would be troublesome to see, or re attach.
Best of luck on you task, let us know how it all works out, and don't forget those splice nipples, you need them to attach your gauges to, and to re plug after.
Offline Steiny
