Author Topic: Speed Bleeder Install Help  (Read 587 times)
Offline Haring_Araw
  • Sun King
  • COG#: 12677
« on: May 31, 2018, 01:34:36 am »
I just picked up the speed bleeders from Murph's to help me change out my brake and clutch fluids. I've never changed out a bleed valve before, how should I go about changing them out? Does anyone have a link to a how to or can provide some instructions?
I apologize if this has already been beat to death. I searched all over and couldn't find the answer to my question.
2016 Concours 14
2015 Harley Davidson V-Rod Muscle
2011 Harley Davidson Road King Classic - SOLD
2010 Harley Davidson Sportster XR1200 - SOLD
Offline G-Mazz
  • COG#: 9048
Re: Speed Bleeder Install Help
« Reply #1 on: May 31, 2018, 02:53:09 am »
Try this video.  It explains everything you need to know to install and how to bleed your lines.
https://youtu.be/QVjPVhoPHow
Offline gsun
  • CDA #560
  • COG#: 9127
« Reply #2 on: May 31, 2018, 11:04:28 pm »
I did mine like the video. Just unscrew the original ones and screw in the speed bleeders. Then bleed the lines. I don't think I got any air in. Leave the cap on the reservoir.
« Reply #3 on: June 01, 2018, 12:09:27 am »
umm.... :-\ :-[
toss a big plastic garbage bag, and an old towel over the tank, and fairings near the master cylinders... before removing the screws... then, pull each cap off, and make sure the reservoir is full, and set the cap back on, without the screws.... don't leave the cap off.... it will spritz B/F out... and make a mess... just set the cap back on... and keep an eye on the level, refilling before it is empty....
Offline gsun
  • CDA #560
  • COG#: 9127
« Reply #4 on: June 01, 2018, 02:45:55 am »
Yes, of course you protect the paint. That should be understood. But I left the caps in place and there was very little leakage. Just don't touch the brakes. And I didn't need to refill the reservoir until bleeding because very little leaked out. YMMV.
Offline Haring_Araw
  • Sun King
  • COG#: 12677
« Reply #5 on: June 01, 2018, 11:41:25 am »
Thanks for all the info. I’ll give it a try this weekend hopefully.
2016 Concours 14
« Reply #6 on: June 01, 2018, 08:44:14 pm »
sorry... :-[ :-[ :-[ :truce: :truce:
misread your post, and transposed "off" for "on"...
carry on... :great:
