Author Topic: Fork Seal Life Expectancy on C14?  (Read 804 times)
Offline Claude aka MotorcycleClaude
  • COG#: 9011
« on: May 30, 2018, 11:53:47 pm »
I'm getting near the 30,00 mile mark on my C14, I'm hearing some early failures but I'm also hearing high mileage.  Just trying to see what the average would be.
I understand there are a lot of factors involved but i'm curious.
Thanks all!
MotorcycleClaude
Offline Roger B
Re: Fork Seal Life Expectancy on C14?
« Reply #1 on: May 31, 2018, 11:49:03 am »
I have 20k on my 2010 and seals are fine..   I expect seal life to be very good, the forks are completely protected from bugs, rocks, etc.
Offline Gscott
  • 09 C14
  • COG#: 12413
« Reply #2 on: May 31, 2018, 12:47:31 pm »
Mine were replaced at just over 25,000 only one side leaking but dealership did both sides under extended warranty.
« Reply #3 on: May 31, 2018, 05:12:53 pm »
I'm at just over 50K and the fork seals are fine.
Offline SpeedyCoop
  • COG#: 12609
« Reply #4 on: May 31, 2018, 11:10:20 pm »
Just replaced mine at 96,000 mi. only one side leaking but I did both forks. All those miles were put on by the original purchaser.
Offline C. Moore
  • COG#: 6662
« Reply #5 on: June 01, 2018, 09:47:24 am »
I have 34K plus on my '10. I noticed the seals leaking a few thousand miles ago. I used a seal mate to clean out the crud and see if that would stop the leak. Worked like a charm. I imagine I will be doing this job at some point.
'10 C14  Dallas, Texas
CDA #523
COG# 6662
Offline Texas Concours14
  • COG#: 9760
« Reply #6 on: June 01, 2018, 01:56:15 pm »
When Fred Harmon installed Traxxion AK-20 cartridges and springs on my bike at 35,000 miles he mentioned the fork seals were beginning to leak.
2010 Concours 14
Offline Red Fox
  • COG#: 11691
« Reply #7 on: June 02, 2018, 05:02:50 pm »
have 53,000 on original seals, 2011 model year
  • COG#: 9011
« Reply #8 on: June 02, 2018, 10:10:25 pm »
So far it's encouraging, hopefully mine will be on the higher mileage side but before my warranty runs out  :)
Claude
MotorcycleClaude
Offline gpd323
« Reply #9 on: June 03, 2018, 06:58:03 pm »
Did you remove the dust seal first? My ZX14 left fork has developed a leak and I have the Motion Pro thing on its way to me now.
I have 35K miles on my C14, no leaks.
Offline 4Bikes
« Reply #10 on: June 03, 2018, 11:16:46 pm »
My forks still worked fine after 50k miles. I knew they needed serviced, with as a minimum a fork oil change. So I did the overkill thing and sent them off to Traxxion for the AK20/Penske upgrade. I expect these new fork seals to last the same amount of time. It was like getting a new motorcycle.    :motonoises:
Offline C. Moore
  • COG#: 6662
« Reply #11 on: June 05, 2018, 09:27:28 am »
Yes, remove the dust seal. You can just slide it down. You can push the seal mate in and slide it around the fork tube. I did it a couple of times on each fork and so far no leaks.
CDA #523
COG# 6662
Offline gpd323
« Reply #12 on: June 05, 2018, 10:59:30 am »
Thanks for the info!!!!!!
Offline MrSkydriver
  • When all else fails, read the instructions!
  • Gregg Hackett
  • COG#: 10363
« Reply #13 on: June 05, 2018, 12:09:21 pm »
2008  112,000 miles....need to change fork oil and possibly springs.   :-\
Gregg Hackett
'08 Concours C14 ABS
Boerne, TX
COG #10363
Growing old is mandatory...Growing up is optional
