Author Topic: Front brake disk bobbins...  (Read 656 times)
Offline RoadKillHeaven
  • How hard can it be? 。◕‿◕。
« on: October 08, 2017, 12:31:11 am »
Front brake rotor bobbins cleaning, freeing up.
Does anyone here practice this?
Offline gsun
  • CDA #560
  • COG#: 9127
Re: Front brake disk bobbins...
« Reply #1 on: October 08, 2017, 02:08:13 am »
Several threads including bobbins. Do a search in C14 chat. I tried doing mine but could not get them to rotate.
Offline Kman
  • COG#: 10569
« Reply #2 on: October 08, 2017, 07:54:12 am »
You can make a simple tool with washers, bolt & nut. The first time you try to rotate them its difficult but after that its a piece of cake. I do mine every year during winter layover.
2012 Black, PR4GTs, Guhl Flash, CS1 Slip-on, Blaster X Brake Flasher, Cree 10W Lights, H4 Extreme Bulbs, Baldwin Heated Seat, Screaming Banshee Horn, MRA VarioTouring Screen, Throttlemeister, Crampbuster, ProjectD Radiator Guard, Front & Rear Fender Extenders, Techspec Snakeskin Saddlebag Protectors, Techmount GPS Bracket, OEM Tank Guard, 47L Top Bag, Helmet Locks, ProjectD Kickstand Bigfoot
Offline rcannon409
  • COG#: 9616
« Reply #3 on: October 08, 2017, 10:13:03 am »
On this specific bike, and brake caliper, I think there are a few things going on.
1 is we ride a lot.   2 is, the front caliper gets dirty.  That 4 pad design is a difficult one to keep clean.  When it's not clean, the pads won't retract, properly, and I think that's what ruins the rotors.
I do clean the bobbins, yearly, and at the same time, I also clean the caliper with a toothbrush and brake cleaner.  So far, so good.
Also, if you start looking at oem kawasaki rotors, they aĺ look the same, but have way different pricing.   I'm not 100% sure ours are the ones from the top of the quality pile.
« Reply #4 on: October 08, 2017, 10:21:38 am »
I wasn't sure guys on here practiced this so I asked.
I've done this on every bike I owned.
C14 seems to have the tightest fitted bobbins compared to other bikes I had.
Cheers...
Offline SteveJ.
  • COG#: 5603
« Reply #5 on: October 08, 2017, 11:12:06 am »
I just got(yesterday) a fresh disc under warranty for my Versys. The bobbins do not rotate by hand.
Some interesting measurements. New disc is 5.39 mm, the other is 4.95, the removed one was 4.85, minimum thickness is 4.80. Bike has 32k miles on it and still has half of the original pads left. Will probably need a new disc when the pads are done. 😟
Tick Tock, baby (Ironbuttal)
Offline Skiee
  • COG#: 11459
« Reply #6 on: October 08, 2017, 11:26:02 am »
+1.
I do mine while I change my oil. The time spent waiting for the oil to finally come to a slow drip and the bobbins are done.
Norm
2009 Concours 14 (Francis)
AMA# 3044870
CDA# 510
