Author Topic: Front brake lever is not activating brake light, rear lever is working  (Read 192 times)
Offline Chris_MI
I noticed today that my front brake lever is not activating the brake light.  The rear brake does properly activate it.  I did install a "BackOff" brake light flasher 2 years ago, but the rear brake activates this properly as well.   When I squeeze the front brake lever, I do hear a clicking sound from near the right side panel under the handle bars, so I am guessing that the switch itself is working. Is there a relay involved that would cause this?  I am going to look at the service manual, but wondering if anyone else has had this problem.
I should have just taken it apart first.  Looks like the switch is bad.  Messing with the switch I was able to trigger the light, but not by pressing the plunger, by squeezing the switch.
« Last Edit: July 24, 2019, 09:57:52 pm by Chris_MI »
2011 Concours 14, Black
"Kage Ryuu"  影龍 or Shadow Dragon
"That which does not kill you, will make you stronger."
Offline C. Moore
  • COG#: 6662
I had a backoff on my old C10 that did the same thing. Take the backoff off and see if your brake light works with the front lever. Mine did and I threw the back off away. I started running hyper lights back there with no issues.
'10 C14  Dallas, Texas
CDA #523
COG# 6662
