Author Topic: Fun with TPMS  (Read 422 times)
Offline arjay2
  • COG#: 8317
Fun with TPMS
« on: June 12, 2019, 09:08:14 pm »
Just had my rear tire sensor replaced under the extended warranty by a local dealer.
On the way home the previous low battery warning light was gone.
But no reading from the rear at all - just 3 dashes ---
Looks like another trip to the dealer.
Any opinions on this - not programmed correctly?
Front sensor works normally as before.
Bob  Arjay 2   2012 Concours
Offline Freddy
Re: Fun with TPMS
« Reply #1 on: June 12, 2019, 10:19:46 pm »
not registered to bike's KIPASS ECU.
Offline arjay2
  • COG#: 8317
Re: Fun with TPMS
« Reply #2 on: June 12, 2019, 10:25:07 pm »
Is this a dealer procedure or can it be done by owner?
Offline Freddy
Re: Fun with TPMS
« Reply #3 on: June 12, 2019, 10:53:12 pm »
Dealer must use KDS to register it to bike using the ID number that came with the new sensor.  If you/he doesn't have the number the tyre will have to be removed to read it from the sticker on the sensor.
Re: Fun with TPMS
« Reply #4 on: June 12, 2019, 10:53:53 pm »
The dealer that did the install UNDER Warranty, should be well aware of the whole process... and no, you can't do it yourself, did you get the number off the bag the sensor came in, or the paper tag with the number on it? If not, ...well... return trip to dealer, peel off tire... write the code number from the sensor on paper, re install tire... and then they program the bike to see it... wow... that is a real sorry feeling man.
Offline JerBear
  • COG#: 12777
Re: Fun with TPMS
« Reply #5 on: June 12, 2019, 10:54:52 pm »
Dealer only or a KDS system
Basically a Dealer
2008 Silverdammit C14
Offline arjay2
  • COG#: 8317
Re: Fun with TPMS
« Reply #6 on: June 12, 2019, 10:57:37 pm »
Thanks for the info - looks like the fun is just starting …….
