Author Topic: Gas cap corrosion....do you suppose?  (Read 1061 times)
Offline Dirtwiz
  • COG#: 12372
« on: December 13, 2017, 08:52:31 pm »
My 2011 has absolutely no corrosion on the gas cap mechanism. Shines like it was brand new. I run ethanol gas 99% of the time in Utah since its the common fuel here. I see people with problems with this corrosion but I over fill mine at the end of each ride so the locking parts are sitting in fuel when parked. My cap looks shiny and like new with not a speck of corrosion. I'm guessing the fact that there is no air in my tank makes the difference on this problem. Anybody else do this?
Offline Bob H
  • COG#: 788
Re: Gas cap corrosion....do you suppose?
« Reply #1 on: December 13, 2017, 10:07:46 pm »
I suspect the lack of humidity in Utah may have something to do with it.
Ethanol is an issue mostly because it attracts water vapor.
I live in Iowa where humidity gets very high, quite often. Ethanol is a continuing problem for me.  Since I've started to run straight gas whenever I can, I've had no problems.  When I was using ethanol blend, carbs would clog up about every two years, and moisture in the tank was a constant battle.
 '88 one owner:
Offline Dirtwiz
  • COG#: 12372
« Reply #2 on: December 13, 2017, 10:57:54 pm »
Bobs H did you ever try over filling when parked? I can't imagine water problems if there is no room for condensation. You are right about the lack of humidity here for sure so maybe that's it.
Offline Bob H
  • COG#: 788
« Reply #3 on: December 13, 2017, 11:11:00 pm »
You're right, keeping the tank as full as possible reduces the air exposure and thus the moisture. If humid air can't get in, it can't cause trouble.
 '88 one owner:
Offline 4Bikes
« Reply #4 on: December 14, 2017, 12:03:11 am »
Every time I see reports of gas cap corrosion, I figure I better check mine. I have a 2011 and it looks like New, with no signs of corrosion. I do not fill up after every ride, and live in PA which means humidity and ethanol. Makes you wonder if something else is going on.  :-[
Offline Fred_Wa2gzw
  • COG#: 10400
« Reply #5 on: December 14, 2017, 01:10:38 am »
I overfill at the end of most rides and no corrosion.
Offline Jorge
  • COG#: 9297
« Reply #6 on: December 14, 2017, 01:22:42 am »
I don't think it's the lack of humidity...
My 2012 has been in Florida all it's life. I bought it 14 months ago, and the PO also lives in FL.
Unless he did something to protect it, it's holding up quite well; looks nice and shiny. I fill the tank, ride until it's low, fill it, ride, and repeat.
I know he didn't top it off all the time because he told me about the time he coasted in to a station with 1 mile of range on the display.
I suppose there may be good production lots, and bad ones...
Online Old Man on a Connie
  • South West Area Director
  • COG#: 9932
« Reply #7 on: December 14, 2017, 01:43:48 am »
But which direction was your bike facing when parked? Really. Facing N,S,E or W. The sunrise, sunset. Moon tidal pull. Fung Shwei. (Not trying to be a smart a$$. Just trying to make you grin  :) ) 2011 60k miles mostly ethanol additive. Henderson NV. Low humidity. Parked on center stand facing east in the Garagio, usually never topped off ;)
"I don't always ride street bikes, but when I do, It's a Concours. A C14 '11 silver to be precise." OTP 2017 Traveler. It was a Blast Baby.
Offline Bob H
  • COG#: 788
« Reply #8 on: December 14, 2017, 01:56:01 am »
 '88 one owner:
Offline Dirtwiz
  • COG#: 12372
« Reply #9 on: December 14, 2017, 07:43:49 pm »
Mark.....you are killing me man....but I too park facing the East. Hmmm? :-\
Offline rcannon409
  • COG#: 9616
« Reply #10 on: December 14, 2017, 09:10:23 pm »
I have an 08, and am in Utah.   No corrosion issues and I can't say I ever paid much attention to the fuel level.
There are several Maverik stores, here in Utah, that have the non-ethanol fuel and I do try to run that , if possible.
Offline Syxxphive
  • COG#: 12672
« Reply #11 on: December 17, 2017, 01:27:58 am »
Utah guy here too. My ‘08 did originally come from Florida. I had to take the cap apart completely just a month after I bought it this summer. Was totally covered in oxidation. Washed it up and coated everything was some antisieze. Doubtful I’ll ever have to do it again.
Offline ZXtasy
  • COG#: 12569
« Reply #12 on: December 17, 2017, 01:59:25 am »
Good one OMOAC, my corrosionless cap of gasage stays just so a long as I sacrifice a cat to Shaitan every full moon.
Offline Locomotiveman
  • COG#: 12297
« Reply #13 on: December 17, 2017, 04:54:37 am »
My vote: A WHITE motorcycle facing South. Final answer. We all agree, Hot air expands, Colder...contracts. After Hot/Cold. Hot/Cold for several weeks, a Dark, unshaded tank's air in a hot Humid place will inhale more outside air moisture before it condenses, usually every evening. I have seen 2" of water in a Dark colored no-leak 300/Gal. tank that sat in bright sunlight. That's sorta why almost ALL huge fuel tanks are WHITE and rarely RED anymore. Also, they never, ever fill a Propane/LP tank near full in cold weather. Ever.
  • COG#: 12297
« Reply #14 on: December 17, 2017, 06:01:44 am »
But then there's THIS: I KNOW of long fuel tanks that were Spec'd to face North to South. Really.http://digitalcommons.unl.edu/cgi/viewcontent.cgi?article=4118&context=extensionhist
Offline 4Bikes
« Reply #15 on: December 17, 2017, 11:25:08 am »
It also says.  :-\
- Do not smoke or light matches around fuel.
Offline rcannon409
  • COG#: 9616
« Reply #16 on: December 17, 2017, 03:12:33 pm »
I always make sure my bike is parked facing Mecca? Maybe thats the difference?
Locomotiveman, I like your ideas, but want to ask a follow up ...
I think several of us have California emissions equipped bikes, or at least Ii THINK we do. Might that charcoal canister we have, for vapor recovery, help/hurt moisture being drawn up into the tank?
« Reply #17 on: December 17, 2017, 05:05:29 pm »
My 09's gas cap has remained corrosion free. It is normally always parked facing North when in the garage.  I have pure 92 gas about 30 miles away. So I run a mix of alcohol contaminated fuel with pure fuel. We do have 87 pure gas which I run the 900 one here in town. Down side is they are proud of it.
  • COG#: 12297
« Reply #18 on: December 17, 2017, 09:44:54 pm »
The EPA and their captive Test Guinea Pigs, military equipment, acknowledge that, yes, Activated Charcoal canisters hold some moisture (water) after the more volatile Hydro-carbons were already removed after each Absorb/Purge cycle when an engine stops and starts. As a biker, I think it would be a stretch to imagine THAT moisture would get back to the tank. I think us bikers need to think far more about the Tank's air cycling in/out, becuz the 'light molecules', especially Butane, cook off first when a near-empty tank sits for days and days; but the WATER vapor condenses on the inner walls, settles to the bottom and NEVER cooks off like the Butane etc. But canister moisture?? Eh... probably not cuz there's so little of it anyway??  But back to the Original Post: It's quite amazing how much water vapor is pulled into a fuel tank if it's near empty; luckily most of it gets burned along with the shloshing gasoline. Anybody remember 'Water Injection' kits from the JC Whitney catalog? I do.
  • COG#: 9932
« Reply #19 on: December 17, 2017, 11:42:38 pm »
Me 2. All the rage during the gas crunch. "Technology bought out and hushed up by Big Oil"  :??: Now JC Whitney is a whole new thread  :beerchug:. Now ya got me thinking if we take all those do not eat silica bags we get from Amazon and suspend them in a tea bag in our tanks...................Hmmmmmmmmmmmmmmmm :beerchug: Hey Murph, got an idea for ya!  :)) :)) :))
Offline Deepsea
  • COG#: 10376
« Reply #20 on: December 18, 2017, 04:29:52 pm »
Me 2. All the rage during the gas crunch. "Technology bought out and hushed up by Big Oil"  :??: Now JC Whitney is a whole new thread  :beerchug: . Now ya got me thinking if we take all those do not eat silica bags we get from Amazon and suspend them in a tea bag in our tanks...................Hmmmmmmmmmmmmmmmm :beerchug: Hey Murph, got an idea for ya!  :)) :)) :))
Water injection is how I control detonation on the LSR Turbo bike. At 10psi boost the check valve begins to open supplying the water up until 18psi then goes to a water alcohol mix.
Retired Navy Saturation Diver
  • COG#: 12297
« Reply #21 on: December 19, 2017, 03:00:54 am »
The Spin-on filter (5Micron) between my boat's tank and outboard motor sucks so much water n crud outa the fuel it's ridiculous.
