Author Topic: Glove compartment auto-lock  (Read 2119 times)
Offline Goldenhornplayer
  • COG#: 12530
« on: July 28, 2017, 05:03:53 pm »
On later models with the glove compartment on the left side, does anyone know how to defeat the auto-lock? My preference is to be able to open and close that lid without the ignition on.
2014 C14 RED, EVO Flash
COG Member 12530
Offline TicTac
  • COG#: 11256
Re: Glove compartment auto-lock
« Reply #1 on: July 28, 2017, 05:11:56 pm »
Pull the glove compartment out and disconnected the wire clip. :great:
Offline turbojoe78_MA
  • COG#: 8645
« Reply #2 on: July 28, 2017, 05:18:48 pm »
Wire in a small momentary switch in a hidden spot and it will still lock, until you push the hidden switch.
Worked for me.
  • COG#: 12530
« Reply #3 on: July 28, 2017, 05:30:30 pm »
OK...putting these 2 responses together, it sounds like, with the ignition off, there is still power supplied to the solenoid which prevents the lid from opening. By either removing the power wire OR installing a N/C momentary switch, I can open and close the lid with ignition off or on. Is that about right?
COG Member 12530
« Reply #4 on: July 28, 2017, 05:37:13 pm »
You might be right.
But, it doesn't sound correct that power is being used to hold the compartment closed (with the key off)?
I suspect the momentary contact is in the ground side of the circuit.
I suspect the solenoid (fails closed)
    ie; holds the latch locked when power is off.
    Power energizes the solenoid {to unlock} when the key is turned on.
If correct, A momentary switch {from battery power} will do the trick.
But, {in the back of my feeble mind)} I think I recall another member doing exactly what Roman sed to do.
  Or he might have, just removed the solenoid.. :-[
Ted
NOTE: I like the idea of it staying locked if I'm not around.
         So, your momentary switch idea appeals to me the most.
« Last Edit: July 28, 2017, 06:39:42 pm by connie_rider »
  • COG#: 12530
« Reply #5 on: July 28, 2017, 05:54:46 pm »
Yeah, Ted, maybe you're right. So, thinking that thru a bit more...with ignition off, the solenoid plunger prevents opening the lid. When the ignition is turned on, the plunger retracts and that allows manual operation of the lid button. But, if that's the case, how can removing the power wire allow this to work? That's why I made the unusual assumption that power was present to the solenoid with the ignition off. I really do like the idea of installing a hidden momentary switch but I need to understand this correctly to know whether to get a N/C or N/O switch.
COG Member 12530
Offline jwh20
« Reply #6 on: July 28, 2017, 06:12:17 pm »
The lock is active when there is NO power applied to it.  So taking the connector off will permanently lock the box.  Not what you want.  I think you'll want to disassemble the mechanism and remove or disable the locking, but not the latching portion.  I've not had one apart but I can't imagine it's all that complex.
2012 Concours 14 Arabian Red
  • COG#: 12530
« Reply #7 on: July 28, 2017, 06:19:49 pm »
I just did some troubleshooting and you are 100% correct. With the ignition off, no power is supplied and the lid is locked. Removing the power wire does NOT unlock the lid. What does allow unlocking is supplying 12VDC to the solenoid. Considering that, I could find a good constant-on 12VDC supply and wire in a N/O momentary switch. Then, with the ignition off, I could momentarily press the switch which will allow the lid to open. Or, as you mention, I could just mechanically defeat the locking mechanism.
COG Member 12530
« Reply #8 on: July 28, 2017, 06:41:06 pm »
Offline old n slow
« Reply #9 on: July 28, 2017, 09:27:22 pm »
You can modify ( cut away a little bit ) the outer box, down low, near the fork tubes.out of site, which allows you to push the solenoid up with yourfinger and then open the box. Discrete, and no one will ever know its there. I did it, and love it! Took anout 20 minutes to do it.
Mike D.
old n slow...it's my way of life☺
Offline walter
« Reply #10 on: July 29, 2017, 01:15:53 am »
I like this idea, I see its a spring on the lever that keeps it locked not the plunger.
Offline Harry Martin
  • ☺ Cartoonist ☺
  • Fear is not boring
    • Harry Martin Cartoons
  • COG#: 4090
« Reply #11 on: July 29, 2017, 05:38:50 pm »
That's more frugal than dung beetles eating elephant poo.  :)
Harry in Wild and Windy Casper, WY - 1986 Vintage "Silverdammit" - 2015 "Greendammit"
Freelance Cartoonist & Illustrator: Road Rash Motorcycle Cartoon Book
Offline Jorge
  • COG#: 9297
« Reply #12 on: July 29, 2017, 08:13:52 pm »
No need to do any cutting.
PO of my 2012 simply unplugged and removed the whole solenoid assembly and it worked perfectly well.
I prefer to have it locked, so I replaced all the parts and all works fine.
His reasoning (not flawed) was that is someone wants in the compartment, they'll simply tear it apart if it's locked. He kept almost nothing in there at all.
My reasoning is that I want to discourage the pass-by-thief that might press the button to see if it opens. I do keep registration and other items in there.
Jorge
Offline C14lvr
« Reply #13 on: July 29, 2017, 08:22:36 pm »
You might be right.
Ted
This is true, Ted... but that lock also re-locks once the bike starts moving at over 5 mph.
So, not being able to look at my manual right now, it might pay to look at the schematic and see what controls that power wire... may go to one of the bikes speed sensors?
Then again, it may not matter. I just know it unlocks when you turn the key on parked, then relocks as the bike starts moving again. (Kawi didn't want us to be rummaging around in there while riding.)
2011 C14 ABS (current bike)
1982 Yamaha XJ1100J (sold)
  • COG#: 12530
« Reply #14 on: July 29, 2017, 09:15:06 pm »
After considering the responses, my plan will be to install a N/O momentary switch. What I'll probably do is to disconnect the existing connector and substitute my own 12VDC and ground with the switch installed on the + side. That way, anytime I want to open the box, I can do so with or without the ignition on and regardless of whether the bike is moving or not.
COG Member 12530
« Reply #15 on: July 30, 2017, 01:03:08 am »
I think I see one small problem with your idea..
While riding it would require 1 finger for the Momentary switch, and 1 finger to push the button and open the box...
I think you sed you planned to hide that momentary button? So it wouldn't be handy?
If so, how would you push both buttons,, while riding?
Old and Slow's idea is starting to appeal to me.
Offline Bruiser
  • Bruiser
  • COG#: 10410
« Reply #16 on: July 30, 2017, 01:15:00 am »
That's what I did 2 days after I bought mine
Bruiser
2012 Kawasaki C14
93 Kawasaki C10
1982 Honda CX500 Turbo
1980 Kawasaki KZ1000ST
1978 Honda CB750F
1976 Kawasaki KZ400
1976 Honda 750K
1973 Honda CB500K
1973 Honda SL175
1972 Honda SL125
« Reply #17 on: July 30, 2017, 01:18:53 am »
What wire clip? What does the wire clip do?
I thought he meant the power plug to the solenoid?
  • COG#: 12530
« Reply #18 on: July 30, 2017, 09:36:56 am »
I see no need ever to open the box while I'm riding.
COG Member 12530
  • COG#: 12530
« Reply #19 on: July 30, 2017, 09:40:10 am »
That's odd...on my bike, disconnecting that plug does nothing except to permanently leave the box locked with no way to open it.
COG Member 12530
« Reply #20 on: July 30, 2017, 10:46:28 am »
He said wire clip, not plug. That is what is confusing me.
NOTE: I'm easily confused...
Ted
« Last Edit: August 01, 2017, 03:39:36 pm by connie_rider »
  • COG#: 12530
« Reply #21 on: July 31, 2017, 06:43:13 pm »
Ted
Yeah, that description confused me too. So, what I did today (instead of installing the momentary switch) was to mechanically disable the locking mechanism. Turns out this is easy to do and can be undone just as easily. The part I removed I will describe as a "pivoting link".
The first pic shows the link undisturbed:
This next one shows the link removed:
With this link removed, you can open and close the glove box regardless of whether or not the ignition is on or off. Of course, the box is NOT locked.
COG Member 12530
Offline TicTac
  • COG#: 11256
« Reply #22 on: July 31, 2017, 11:12:18 pm »
Sorry. I meant "PLUG"   :'(
The power to the solenoid.  :great:
Must be my British accent. ;)
« Reply #23 on: August 01, 2017, 01:29:30 pm »
Yea, yea,,, that was it.
You talk/type with an accent.. {Ya prolly did it, to confuse us Colonists}
Obviously; My confusion was all your fault.    :-[
Gee, I feel better...   :rotflmao:
Bye the bye;  {I think} we've been told that unplugging the wire clip/plug won't allow the Glove Compartment to open.
                      In fact, {they sed} it will prevent it from opening.
{Did I get that right, ya'll)??
  • COG#: 12530
« Reply #24 on: August 01, 2017, 01:50:40 pm »
Ted, as far as I'm concerned, you got it exactly right!
COG Member 12530
