Author Topic: Grounding issue on rear subframe  (Read 1226 times)
Offline Fred_Harmon_TX
  • COG Technical Editor
    • Angel Ride Videos
  • COG#: 2170
« on: November 24, 2009, 12:24:00 am »
I was doing some electrical work on my bike tonight and noticed a problem with my brake relay I added for my cruise control. I had it grounded (or so I thought) to the bolt on the subframe as seen in the photo below . After doing some checks, I discovered almost 14K ohms of resistance between my ground point and the battery ground connection. So just beware, the entire rear of the bike may not be at ground. I added a new permanent ground lead between the battery and rear subframe to fix this problem.
« Last Edit: November 24, 2009, 02:25:00 am by Fred_Harmon_TX »
Fred H.
Offline Bobby's Boy
  • COG#: 8933
« Reply #1 on: January 27, 2010, 01:25:00 am »
Fred:  I'm new to the COG.  Sold my R1100RT and I'm really enjoying the C14.  Very warm bike compared to RT but I'll deal with that later.  Now, I'm looking for some simple instructions on hardwiring a 5 volt power adapter for my XM portable unit.  From looking at the forums for the last few months, you seem to be the guru, particularly on electrics.  I know enough to be dangerous and I'd like some advice or a link to a good site for instructions.  I see that there are adapters that might be available, but I want a ignition on only power source.  By the way, I know the C14 is relatively new, but isn't there a shop manual yet?  I had a Haynes manual for my BMW and it was great.  Sorry for so many questions, some of which I suspect really reveal my ignorance.  Any help you could offer would be appreciated.
« Reply #2 on: January 27, 2010, 12:20:00 pm »
I just used a ground lug that I took off the battery. It's a lug on the end of a wire connected to the negative battery. I use that for all the farkels.    Bionic Bob  COG & AMA member  First C14 CDA member #0220  2008 C14 & 2003 Mean Streak
Offline The Wanderer
  • COG#: 8863
« Reply #3 on: January 27, 2010, 01:17:00 pm »
Howdy,  As far as a manual goes I bought an electronic copy right after I got my Connie 14 in Aug. on line.  I believe I just did a google search to find it.  If I remember correctly it was about $20.  When I need to do some work on the bike I just print the pages I need.  This way you're always assured of having a clean readable copy.  Later,  Norm
