Author Topic: Lines under tank cover  (Read 760 times)
Offline Tjnoma99
  • COG#: 12686
« on: December 22, 2017, 12:36:37 am »
What are the thin metal lines under the tank cover ( the black cover at the front of the tank)? I added a tank compartment from a 09 to my 13. I just want to make sure that the pressure from the compartment being bolted down wont affect these lines?
Offline jwh20
Re: Lines under tank cover
« Reply #1 on: December 22, 2017, 02:51:25 pm »
If I understand what you're talking about, those are brake (ABS) lines from the ABS pump.
2012 Concours 14 Arabian Red
Offline Tjnoma99
  • COG#: 12686
« Reply #2 on: December 22, 2017, 08:58:56 pm »
I looked through the manual amd i think you're right! Just want to be sure the tray isn't going to cause these lines any stress when i tighten it down.
Offline jwh20
« Reply #3 on: December 23, 2017, 01:01:48 am »
I would check to make sure there is clearance between the bottom of the tray and the lines.  They are relatively soft metal and you can pinch them fairly easily.
Offline Tjnoma99
  • COG#: 12686
« Reply #4 on: December 23, 2017, 01:04:45 am »
Good to know. I will check them.
