Author Topic: How I pinned my bags  (Read 2725 times)
Online Harry Martin
  • ☺ Cartoonist ☺
  • Fear is not boring
    • Harry Martin Cartoons
  • COG#: 4090
« on: April 12, 2016, 09:20:17 pm »
1/16" pilot hole in aft end of tab that hangs down below the slot.
3/32" hole.
2 spring loaded safety pins from local big box hardware store. About $2 bucks.  :)
 :103:
Harry in Wild and Windy Casper, WY - 1986 Vintage "Silverdammit" - 2015 "Greendammit"
Freelance Cartoonist & Illustrator: Road Rash Motorcycle Cartoon Book
Offline Bruiser
  • Bruiser
  • COG#: 10410
Re: How I pinned my bags
« Reply #1 on: April 13, 2016, 12:03:39 am »
Those must be a bugger to snap closed and open.
Bruiser
2012 Kawasaki C14
93 Kawasaki C10
1982 Honda CX500 Turbo
1980 Kawasaki KZ1000ST
1978 Honda CB750F
1976 Kawasaki KZ400
1976 Honda 750K
1973 Honda CB500K
1973 Honda SL175
1972 Honda SL125
Online Harry Martin
  • ☺ Cartoonist ☺
  • COG#: 4090
« Reply #2 on: April 13, 2016, 12:39:37 am »
Easy.
Offline The Pope
  • North Carolina AAD
  • COG#: 9994
« Reply #3 on: April 13, 2016, 01:22:28 pm »
Thanks for the idea!  :great: :beerchug:
The Pope
Offline flashback50
« Reply #4 on: April 13, 2016, 09:02:10 pm »
Looks like it would be hard to get your hands in there to close them
Online Harry Martin
  • ☺ Cartoonist ☺
  • COG#: 4090
« Reply #5 on: April 13, 2016, 10:02:02 pm »
My hands are not that big. Not as big as Trump's.  :rotflmao:
Actually, it looks tough, but it's not. I can get one hand in there and flip the safety pin loose using one finger.
The pin goes in either way. This is what works for me and it may not work for everyone else.
I suppose you could spend more money and use a ball locking pin and not mess with a safety pin.
I have other ideas to do the same thing, but they cost a lot more money.
Offline flashback50
« Reply #6 on: August 03, 2017, 12:14:21 am »
Well I decided to try this way of pinning the bags on my 2013 and discovered that I can't do it. The part that you drilled to put the pin does not come below the mount it fits in. It is flush with the bottom of the mount. Looks like your bike is the newer model being green. I wonder if Kawi extended those engagement tabs on newer bikes?
Well after looking closer it is definitely true that they extended those tabs.  Look at pics attached.
« Last Edit: August 03, 2017, 12:23:26 am by flashback50 »
Online Harry Martin
  • ☺ Cartoonist ☺
  • COG#: 4090
« Reply #7 on: August 03, 2017, 12:48:36 am »
Flashback,
That is interesting. Yes, it looks like my bags have longer tabs hanging down. I think you are correct that big K made those longer so they stay put. When I first started looking into this, I figured that this is where the bags would start jumping out from vibration. With my pins in place, the bags don't even try to lift up.
One of my other ideas was to drill down thru the top of the tab so I could insert long clevis pins, thus extending the tabs even further. After that, just run a locking safety pin thru the clevis pin hole.
I'll post a drawing so you can see what I mean.
You could still do that and fill any gaps around the metal pins using JB Weld Epoxy. It would cost a little more but you would get the same results.
Either way, pin in the tabs, or what others have done by installing the lower pins, achieve the same results.
Online Harry Martin
  • ☺ Cartoonist ☺
  • COG#: 4090
« Reply #8 on: August 03, 2017, 01:00:56 am »
So, here was my alternate solution. Note that the pins hang below the slots.
My local tractor store carries gobs of clevis pins in all sizes and lengths with predrilled holes.
Just another idea to consider and I see no issues with the pins weakening the plastic tabs.
Note the blue areas are filled in with the JB Weld to hold pins in place and add strength.
Offline flashback50
« Reply #9 on: August 03, 2017, 01:06:39 am »
Looks good. Thanks for the ideas and suggestions Harry  :beerchug:
Offline Jorge
  • COG#: 9297
« Reply #10 on: August 05, 2017, 02:22:38 pm »
Harry, nicely done, taking advantage of the longer tabs on newer bikes... I wonder when they made the change.
For those who have older bags with the shorter tabs, remember the old method of pinning them through the front alignment tab works quite well. The pins are visible (not like Harry's), but they don't look bad.
« Last Edit: August 06, 2017, 08:50:10 pm by Jorge »
Offline seagiant1
  • COG#: 11323
« Reply #11 on: August 05, 2017, 02:38:44 pm »
Harry, nicely done, taking advantage of the longer tabs on newer bikes... I winder when they made the change.
Hi,
       Jorge, the pins I use on my 2012, with the "bales" for security....
Look almost OEM, and you really have to look for them to notice! ;D
No matter how you do it... :motonoises:
Peace of mind, is worth it! :great:
« Last Edit: August 05, 2017, 02:41:53 pm by seagiant1 »
