Author Topic: Installing new Speed Bleeders...which ones go where?  (Read 498 times)
Offline ddialogue
  • Boise, Idaho
  • I have C14 perma grin!
« on: September 16, 2017, 07:11:06 pm »
I just received my Speed Bleeders kit Murph.  The kit comes with five of the long model (SB8125L) and two of the short model (SB8125.)  It seems to me the short ones install at the master cylinders on the bars and the longer ones are for the calipers and clutch.  Is that correct?
Thanks!
Dave
2010 ABS Neptune Blue
2003 FZ1 Silver
2008 KTM 530EXC
Offline JTX
  • TEXAS 2015 ZG14
    • 2015
Re: Installing new Speed Bleeders...which ones go where?
« Reply #1 on: September 16, 2017, 08:42:42 pm »
Thanks!
YUP.  I did the same thing a couple of months ago.
They are shorter for 'aesthetics '
ALSO ETA, dont forget there are two bleeders on the back caliper.  I had one 'extra' and was puzzled for a few minutes until I took a good look at the rear caliper!
Offline ddialogue
  • Boise, Idaho
« Reply #2 on: September 16, 2017, 08:47:09 pm »
Thanks for the info!  :beerchug:
I measured the short model and they are the exact same length as the stock bleeders in the front calipers so I wondered.
Dave
2003 FZ1 Silver
2008 KTM 530EXC
Offline JTX
  • TEXAS 2015 ZG14
    • 2015
« Reply #3 on: September 16, 2017, 08:49:06 pm »
Yeah KAW uses short ones on the front calipers.  And as you said, it made me wonder if I should put the short ones there.
But the idea is that if you put those long ones on the master cylinders on the bars, they stick up like nipples through a wet T shirt.
Very distracting!
A bit of searching revealed they are just shorter and less noticeable.
Offline flashback50
« Reply #4 on: September 20, 2017, 05:30:47 pm »
I put the short ones on the masters too   :great:
Offline JTX
  • TEXAS 2015 ZG14
    • 2015
« Reply #5 on: September 20, 2017, 05:36:07 pm »
I really had a hard time getting the clutch line bled out.  For some reason it took forever to get it primed.
After doing this, and only a two year old bike with 10K on it, makes you realize how fast brake fluid degrades.  It was already discolored enough to make it noticeable when the new fluid arrived at the bleed valve.  I flushed through a lot more than I needed, but I Wanted to get the crud out.
Offline Jerdurr
« Reply #6 on: September 22, 2017, 01:22:08 am »
What do you mean a long time to get it "primed"?
Best,
JD
Offline JTX
  • TEXAS 2015 ZG14
    • 2015
« Reply #7 on: September 22, 2017, 09:07:58 am »
I pumped it 1000 times before it started pushing fluid out.  Not sure why.
Offline Syxxphive
  • COG#: 12672
« Reply #8 on: September 22, 2017, 01:13:57 pm »
It’s because the valving inside the master cylinder is tiny. It can let more air in than the fluid it pushes out. If that makes sense. If you are replacing the clutch line, it can help to prefill the line before you install it. Or just use a mighty vac.
Offline JTX
  • TEXAS 2015 ZG14
    • 2015
« Reply #9 on: September 22, 2017, 06:15:35 pm »
Thats probably why it took a while.  My hand hurt after that.  But it was odd because I pumped the hell out of it and I got nowhere fast.  Then suddenly, it began to push fluid...
