Author Topic: K-ACT WORKING FINE?  (Read 461 times)
Offline osvaldo
K-ACT WORKING FINE?
« on: April 12, 2018, 10:37:49 pm »
HELLO!!!
can someone help with the function of the K-ACT ?
THE BRAKES ON THE BIKE ACTING A LITTLE WIERD WHEN YOU GET TO STOP THE BRAKE  TEND TO BLOCK THE WHEEL
THAT IS SCARRY !!!
THANKS
Offline osvaldo
K-ACT WORKING FINE?
« Reply #1 on: April 12, 2018, 11:11:38 pm »
HELLO!!!
THAT IS SCARRY !!!
THANKS
Re: K-ACT WORKING FINE?
« Reply #2 on: April 12, 2018, 11:13:03 pm »
This should be posted in the C14 BIKE section
http://forum.cog-online.org/concours-14-zg1400-general-chat-and-tech/
Someone/moderator, should be along shortly, and move it for you, so please don't double post as a new forum user.
Offline jwh20
« Reply #3 on: April 13, 2018, 10:09:41 am »
K-ACT is Kawasaki's marketing name for the anti-lock braking system (ABS) installed on the C14 as well as some other Kawasaki models.  Here is what THEY say it is:
https://www.kawasaki-cp.khi.co.jp/technology/chassis/tech_k-act_abs_e.html
On the C14 you can often feel the K-ACT activating as you brake, especially if you are using only the front or rear vs. both at the same time.  The system make also apply more braking force to one wheel or the other in order to do what it thinks needs to be done.  If you apply the brakes firmly enough on a slippery surface  you will also feel that much the same as an automotive ABS system as pulses in the braking force as it tries to prevent the wheel from locking up.
2012 Concours 14 Arabian Red
Offline RWulf
  • COG#: 7122
« Reply #4 on: April 13, 2018, 02:50:11 pm »
What happens when the ECU runs out of all those one's and zero's??
Offline jwh20
« Reply #5 on: April 13, 2018, 05:31:21 pm »
Basically the entire universe comes to a screeching halt!  Not pretty!
