Author Topic: mirror material  (Read 464 times)
Offline strum
  • COG#: 12307
mirror material
« on: February 25, 2019, 07:15:37 pm »
 Can anyone tell me what material the black part of the mirror is? I cant find any markings on mine with out removing it first .  The little loop that holds the rubber well nut is broken and i want to try to glue it .
2016 C-14
Online MAN OF BLUES
Re: mirror material
« Reply #1 on: February 25, 2019, 07:36:53 pm »
I looked at your "other" post, also; like I said, if it's soft plastic, and BLACK, it's likely HDPE, if it's hard plastic/painted/ and resists being "scratched" by a "sharp pin". it's likely ABS...
http://forum.cog-online.org/concours-c10-zg1000-general-chat-and-tech/she-went-down/msg661446/#msg661446
Please, anyone that knows for sure, post up, so the right adhesive can be used.  :truce: :truce:
Offline strum
  • COG#: 12307
Re: mirror material
« Reply #2 on: February 25, 2019, 10:01:12 pm »
Thanks MOB  I just figured this was better discussed here. hoping someone had a mirror off that could find a code.  As you know this is the black part of the mirror assembly . you can't see the loom/loop unless you take off the top fairing cover(s) . Don't know what to call them but directly above the air cleaner.
2016 C-14
Re: mirror material
« Reply #3 on: February 26, 2019, 08:49:26 pm »
It is ABS. When I tipped over last year and busted the right mirror, I glued it back together while waiting for the new mirror to arrive. Worked good too.
Offline strum
  • COG#: 12307
Re: mirror material
« Reply #4 on: February 26, 2019, 09:19:35 pm »
Thanks Tim that's the, answer I was looking for.
2016 C-14
Offline strum
  • COG#: 12307
Re: mirror material
« Reply #5 on: March 02, 2019, 01:04:41 am »
just to follow up on this . I found the ABS cement at lowes today and it worked perfectly. Thanks guys
2016 C-14
