Author Topic: My Connie died! Need help diagnosing! I'm a chucklehead!  (Read 5351 times)
Offline Gixerhp
  • The Lighting Guy!
  • COG#: 12189
Re: My Connie died! Need help diagnosing!
« Reply #50 on: April 20, 2017, 09:46:43 pm »
Offline Rbourque77
  • COG#: 11915
Re: My Connie died! Need help diagnosing! I'm a chucklehead!!
« Reply #51 on: April 23, 2017, 03:15:26 pm »
Well, this was a great learning lesson for me.  I found out that the "main fuse" I was checking continuity for was actually the spare 30A fuse.  There is another fuse, the REAL main fuse kinda hidden underneath a rubber boot - when I finally found that fuse, I pulled it out saw that it was blown!
Thanks for everyone for posting comments and their helpful suggestions.  Special thanks to Gixerhp who was willing to come down from NH and lend a hand.
See you out there!!!
Bob
Offline Harry Martin
  • ☺ Cartoonist ☺
  • Fear is not boring
    • Harry Martin Cartoons
  • COG#: 4090
« Reply #52 on: April 23, 2017, 04:46:26 pm »
Bob,
I think we are all relieved it was something more basic. It is a sickening thought for sure that it could be fried electronics. In my experience, it is usually the opposite...that being, the electronics fries to protect the fuse.  :(
I have blown many fuses myself so don't feel bad. The fuse did it's job and you are back on the road.  :)
Safe travels.
Harry in Wild and Windy Casper, WY - 1986 Vintage "Silverdammit" - 2015 "Greendammit"
« Reply #53 on: April 23, 2017, 07:00:12 pm »
I'm so happy to hear it was something simple as noted, and really glad John took the time to assist you, and do the diligent trouble shooting.
As I also stated this bikes systems are extremely protected, so I could not fathom any of the extreme failures some folks eluded to, when that fuse takes a hit, juice is stopped cold from other components, so in this case, the protective device did its job...
Happy and safe riding, congrats...
 :great: :great: :beerchug:
Offline JTX
  • TEXAS 2015 ZG14
    • 2015
« Reply #54 on: April 23, 2017, 07:05:16 pm »
Always check twice!!
Glad to hear your ride is not toasted !!
Be careful next time
Offline Rbourque77
  • COG#: 11915
« Reply #55 on: April 23, 2017, 09:27:41 pm »
LOL!  Sad but kinda true.
Bob
Offline Rbourque77
  • COG#: 11915
« Reply #56 on: April 23, 2017, 09:28:46 pm »
Will do JTX!
Bob
Offline Rbourque77
  • COG#: 11915
« Reply #57 on: April 23, 2017, 09:31:53 pm »
Indeed the fuse did it's job!  Can't argue with a fix less than $1.00.
Bob
Offline Gixerhp
  • The Lighting Guy!
  • COG#: 12189
« Reply #58 on: April 24, 2017, 04:53:35 pm »
Im so glad you found it! ,, Sorry i was so bust this last weekend!
Offline Rbourque77
  • COG#: 11915
« Reply #59 on: April 24, 2017, 04:57:49 pm »
I would have felt extra stupid if you came down and found the blown fuse!
Bob
Offline Bruiser
  • Bruiser
  • COG#: 10410
« Reply #60 on: April 25, 2017, 12:42:21 am »
OH oh...I did that about 4 years ago...thought I had killed my almost new bike.  Check the ground wire from the battery, that goes behind and under.  If you fried that, which is what I did, you have to replace it.  It grounds out under the bike.  If you are lucky, you only killed the 30amp fuse, Matt mentioned. I also killed the battery, and had to replace it also.
Bruiser
2012 Kawasaki C14
93 Kawasaki C10
1982 Honda CX500 Turbo
1980 Kawasaki KZ1000ST
1978 Honda CB750F
1976 Kawasaki KZ400
1976 Honda 750K
1973 Honda CB500K
1973 Honda SL175
1972 Honda SL125
Offline Bruiser
  • Bruiser
  • COG#: 10410
« Reply #61 on: April 25, 2017, 12:48:51 am »
I just read up, and see you found the problem. So glad for you. I had heart failure when I did mine, and when I did cross -/+, it fried so quick, I couldnt believe it!  It even soldered the screw to the frame, which I had to rethread.  It was such an easy mistake.
Bruiser
2012 Kawasaki C14
93 Kawasaki C10
1978 Honda CB750F
1976 Kawasaki KZ400
1976 Honda 750K
1973 Honda CB500K
1973 Honda SL175
1972 Honda SL125
Offline C. Moore
  • COG#: 6662
« Reply #62 on: April 25, 2017, 10:04:38 am »
I've been following this thread with the hope the fix would be simple. I'm glad it worked out.  :great:
'10 C14  Dallas, Texas
CDA #523
COG# 6662
« Reply #63 on: April 25, 2017, 07:08:18 pm »
I guess I have to ask both you, and the original poster Bob, if both of these occurances were caused by purchasing and replacing the battery, with one that had the opposite pole configuration from the one that came in the bike???
I ask, because with the cables, and installation required, and the battery plastic shroud in place before insertion,, its virtually impossible to mis wire the "correct" battery
