Author Topic: Need an engine mount bolt. Fell out...  (Read 2431 times)
Offline rcannon409
  • COG#: 9616
Re: Need an engine mount bolt. Fell out...
« Reply #25 on: September 07, 2017, 10:49:34 am »
I end up needing metric fasteners, for work.  Even in a town like Salt Lake, I have at least 5 bolt and nut supply companies.  Any of them would have this bolt. The head is never the correct wrench size, but it would get you by until you could order the correct one.
Do you have anything like that, near you?  Often times if you need just (1), they wont even charge.
PM me if you cant find the correct size.  I'll stop in to one of the places, grab one,  and send it to you. If we do this quickly, we could probably have it to you by Tuesday.
Offline WANDRNG
  • SouthWest AAD
    • Wandering Back Roads
  • COG#: 12077
« Reply #26 on: September 07, 2017, 03:03:59 pm »
Thanks. Found a cogger with an OEM locally - I'll be picking it up tonight at the Sac Meet & Greet.  I appreciate the effort and thought!
Life is too short to live the same day twice.
2015 Concours 14 -- 2007 Kawasaki KLR650 -- 2003 Honda Magna 750 -- 2 V65 Magnas
Wandering Back Roads: RRs -- Wandering the Northwest -- Heading East Out West
Offline Old Man on a Connie
  • South West Area Director
  • COG#: 9932
« Reply #27 on: September 07, 2017, 10:59:09 pm »
I know I can hear it in my head. Stoopid Bolt.  :)) :))
"I don't always ride street bikes, but when I do, It's a Concours. A C14 '11 silver to be precise." OTP 2017 Traveler. It was a Blast Baby.
Offline rcannon409
  • COG#: 9616
« Reply #28 on: September 07, 2017, 11:22:04 pm »
Be careful as it threads in.  The thread pitch you are looking for is 1.25mm   Right between the normal choices you often times find at the hardware store. You will feel it.  If the pitch is off, it tries to start, but won't quite do so.
I watch ebay.  In the winter, I'll search for someone parting whatever bike I have.  A person can usually work out a deal for the pile of bolts, clips,and misc hardware they have laying around after the part out.
Of course, I've never needed any of the big bolts, just because I have them.
Online Syxxphive
  • COG#: 12672
« Reply #29 on: September 07, 2017, 11:55:28 pm »
Should be 1.5mm. On any drawing with metric fasteners and the thread pitch is not given, it's always coarse thread. Coarse thread on m10 is 1.5. As per the machinery handbook. Which has been industry standard for 100 years.
Online AmphibSailor
  • Hooligan
  • COG#: 12210
« Reply #30 on: September 08, 2017, 08:54:05 am »
This thread on the other forum says the pitch is 1.25.
Online Syxxphive
  • COG#: 12672
« Reply #31 on: September 08, 2017, 09:51:34 am »
Leave it to a heavy industries manufacturer to just throw the book out. I HATE engineers.
Offline jwh20
« Reply #32 on: September 08, 2017, 10:49:46 am »
It's moot at this point.  The OP said:
I assume that "Sac" really means "Sat" but the OEM part is going to be the right one.  But an M10 could be either 1.0 or 1.25 thread pitch and I'm not sure which it is.  If you're in a pinch to figure it out, there is an identical bolt on the other side in the same place.  Pull it out and count the threads.
2012 Concours 14 Arabian Red
Offline Gscott
  • 09 C14
  • COG#: 12413
« Reply #33 on: September 08, 2017, 10:55:29 am »
If this is the bolt you replace when putting on canyon cages it is 1.25 pitch, at least on my 09 it was.
Offline rcannon409
  • COG#: 9616
« Reply #34 on: September 08, 2017, 10:59:08 am »
I know your rule is correct if it were one of my German made air compressors.  I wonder if there is a different "motorcycle" standard?   Maybe not even a "motorcycle"standard. I know ktm uses some bolts that need a 13mm wrench.  We won't find that on our Japanese bikes, unless it's an accessory.
Maybe this rule goes out the window when it gets an official part number, and an 8.00 price?
Online Syxxphive
  • COG#: 12672
« Reply #35 on: September 08, 2017, 11:09:30 am »
I think it's more likely that we're just looking at an exploded diagram, and not an actual machine print and parts list.
Offline FTB530
  • COG#: 12127
« Reply #36 on: September 08, 2017, 12:30:09 pm »
Sac= Sacramento.
Offline rcannon409
  • COG#: 9616
« Reply #37 on: September 08, 2017, 12:45:09 pm »
There appears to be a JIS standard?   https://www.nutsandbolts.com/jis.html
Offline WANDRNG
  • SouthWest AAD
  • COG#: 12077
« Reply #38 on: September 08, 2017, 05:48:34 pm »
To everyone posting above - THANKS!!!!!  I appreciate your input, thoughts and assistance.
Here's the skinny:
The bolt is M10-1.25x45mm
The only way to get this bolt, from anyone, is to order it.  I found a M10-1.25x50mm Grade 8 Zinc plated locally and finger threaded it in most of the way just to confirm 1.25.
Kawasaki  never refers to it in any other way than M10x45 - parts diagram and service manual (I'm told) show only this spec. And leave us to guess what they consider standard (just read rcannon's JIS article)
Discussed taking out the other bolt so we could check it - didn't want to if we didn't have to. So finding a $1 overlong test bolt saved us that. (cause with the way things are going, the engine would have fallen out and I would have had to do the 6 bolt mount&bracket re-install torquing pattern)
All cause I didn't want to  pay Mama Kawa's $40 rush charge to get the OEM part here in time for my trip. I've spent double that in mine and other peoples time. Sorry and thanks.
  • COG#: 9932
« Reply #39 on: September 08, 2017, 10:06:19 pm »
Stoopid bolt.
Offline Deepsea
  • COG#: 10376
« Reply #40 on: September 09, 2017, 01:23:35 am »
I have a m10x1.25x45 bolt. It's the one you didn't take home last night. Let me know if you need it.
Mike
Retired Navy Saturation Diver
Offline WANDRNG
  • SouthWest AAD
  • COG#: 12077
« Reply #41 on: September 09, 2017, 01:49:47 am »
Stoopid bolt.
Let's be honest - 50% stoopid bolt and 50% stoopid cheap Wandrng
Offline WANDRNG
  • SouthWest AAD
  • COG#: 12077
« Reply #42 on: September 09, 2017, 01:51:58 am »
PM'd
« Reply #43 on: September 09, 2017, 01:55:38 am »
One COGger to another:
  If you need it quick {and if I were closer}, I'd just let you use mine...
     Wish I had thought of it sooner.
When do you need it?
Offline WANDRNG
  • SouthWest AAD
  • COG#: 12077
« Reply #44 on: September 09, 2017, 02:02:22 am »
Leaving Wednesday for Wild Wasatch.
But it's covered now thanks. A number of awesome folks stepped up with offers and bolts, one of the best things about COG. The people.
The real problem is I just like to make things extra complicated, you know build extra stress and stuff. And I'm darn good at it.
Thanks Ted.
« Reply #45 on: September 09, 2017, 01:40:47 pm »
Ok, enjoy your ride.
