Author Topic: Oil Drain Plug Nylon Crushers?  (Read 931 times)
Offline cyberswine
« on: November 10, 2017, 11:19:59 pm »
Had trouble finding new copper or aluminum crush washers just the right size for the engine oil drain plug.  Guy in an auto parts store sold me Nylon washers that fit perfectly and assured me that Nylon washers are fine to use.  Never came across them before,  just searched these forums and found no mention.  Any feedback or comments?
Offline JerBear
Re: Oil Drain Plug Nylon Crushers?
« Reply #1 on: November 10, 2017, 11:39:55 pm »
https://www.murphskits.com/product_info.php?cPath=130_136&products_id=240
Murphs ships them to you they work great
IDK a thing about nylon ones except they may not do well in hot environments depending on the type of nylon.
« Last Edit: November 22, 2017, 11:57:00 pm by JerBear »
2008 Silverdammit C14
« Reply #2 on: November 10, 2017, 11:45:34 pm »
WELL...
I wouldn't attempt to torque that plug down tightly on a nylon one... i hope it doesn't split, or the plug falls out due to lack of tightness..
parts store guy must have been lazy, every parts store has both copper, and aluminum crush washers sitting right next to thee nylon ones on the display...
Offline Bob H
  • COG#: 788
« Reply #3 on: November 10, 2017, 11:56:48 pm »
I have used nylon oil drain plug gaskets for years, on motorcycles, cars, and tractors.  Never had an issue with them.  They seal very well at low torque, I've never had one let the plug back out.  Just don't overtighten.
I prefer them over the aluminum ones.
 '88 one owner:
Offline khager01
« Reply #4 on: November 11, 2017, 01:45:10 am »
The OEM washers on my Honda car are aluminum,  and the OEM ones for my Toyota are nylon, never had a problem with either, and IIRC they both callout about the same torque.
2017 Concours 14
2012 V-Strom 650
Offline RWulf
  • COG#: 7122
« Reply #5 on: November 11, 2017, 03:07:29 pm »
At 15 cents at peace I'll stay with the ones from Kawasaki.
Offline khager01
« Reply #6 on: November 11, 2017, 06:16:56 pm »
Where do you find them for $0.15?
2017 Concours 14
2012 V-Strom 650
« Reply #7 on: November 11, 2017, 07:02:14 pm »
Kawasaki price is cheap also..
92065GASKET,12X22X2
92065-097
$0.95
 :rotflmao:
$0.15 seems a bit low, but i suppose some parts stores have a 5 pack for $2
https://tinyurl.com/y75rqody
I know I have a pack of them somewhere, that I bought 25 years ago..  :rotflmao: :rotflmao: :rotflmao:
when I lost one, and needed to replace it...
« Last Edit: November 11, 2017, 07:16:25 pm by MAN OF BLUES »
Offline gpd323
« Reply #8 on: November 11, 2017, 08:56:09 pm »
I use these
google search
Genuine Toyota - Oil Drain Plug Gaskets (QTY10) - 90430-12031
Offline RWulf
  • COG#: 7122
« Reply #9 on: November 13, 2017, 03:04:14 pm »
That's what my local Kawasaki dealer charged.
I was surprised, he usually has to order everything, not these.
Offline currenv
  • COG#: 11913
« Reply #10 on: November 21, 2017, 07:14:02 pm »
I bought a bag full of the Toyota nylon ones for my KLR.  They were cheap on Amazon.  (Did I say it was for a KLR?)  But then I haven't used them because I got to thinking about less torque and what if the drain bolt falls out, then it won't be so cheap...  so I've been using copper ones anyway.  I guess the conclusion is that I'm not only cheap dumb too!
Vinnie
Offline JTX
  • TEXAS 2015 ZG14
    • 2015
« Reply #11 on: November 22, 2017, 05:51:55 pm »
As was said, buy a bag of them from Murph.
Offline Road Runner
  • Beep! Beep! ... yeeHa!
  • COG#: 12399
« Reply #12 on: November 23, 2017, 03:34:00 am »
Partzilla.com ( also has both the washers for both the oil drain plug and the final gear oil plug.
David L. Hamil
