Author Topic: Oil Leak...what say the experts?  (Read 1237 times)
Offline ZXtasy
  • COG#: 12569
« on: August 01, 2017, 12:28:14 am »
My recently acquired 2013 with now 7K miles, I have put 600 miles on since May when I first changed the oil. Parked on my pristine garage concrete about 50/50 side stand/center stand. Have ridden and parked in same spot at work on hotter days than today's 96, and nothing different or unusual n today's ride in. Bike had been sitting on side stand for 3 days. Went I went to leave work today I immediately notices 2 spots of oil aft and to the low side of front tire. Seemed odd, so I reached to lower edge of lowers and had wet dirty oil on hand. Thought briefly I had obtained the infamous oil filter leak, but it was fairly clean and once  wiped as smooth as baby butt. Oil had  obviously been there for a little bit as it was windblown back. Cleaned it up, ran it and revved it, no new source. Rode it pretty hard for 5 miles to chiropractor. After appt., no new drip. Rode it another 10 miles on errands and parked on side stand....no drips after 2 hours. Will look at in the AM closer, but could this be residual from the infamous valve cover weepage?
I did park were a coworker usually parks his Harley, but it is too hot for him being out of the 75 to 85 degree range; could this be sympathy seepage? :))
Thanks for listening.
Re: Oil Leak...what say the experts?
« Reply #1 on: August 01, 2017, 06:06:47 am »
https://www.murphskits.com/product_info.php?products_id=528
I would suspect a leaky cam sensor which is well documented.  Murphskits is a great source for your C14 needs.
« Last Edit: August 01, 2017, 06:10:48 am by Goldfingers »
Offline JerBear
  • COG#: 12777
« Reply #2 on: August 01, 2017, 07:42:11 am »
One of two, fix them both.  Exhaust sensor o-ring and the valve cover gasket. Both are prone to leaking, both are fairly simple fixes.  Search is your friend but I had both and it is dry now.
2008 Silverdammit C14
Offline ZXtasy
  • COG#: 12569
« Reply #3 on: August 01, 2017, 11:14:17 am »
SOunds like fun, appreciate the leads.
Offline C. Moore
  • COG#: 6662
« Reply #4 on: August 02, 2017, 09:21:44 am »
My oil leak was from the exhaust cam sensor. I waited until the valve adjust and changed the o-ring at that time.
'10 C14  Dallas, Texas
CDA #523
COG# 6662
Offline jwh20
« Reply #5 on: August 02, 2017, 11:42:36 am »
The cam sensor o-ring is easy enough to replace once you remove the plastics from the LH side of the bike.  It's tight but you can get a wrench and your hand in there to pull and replace the sensor.
The valve cover gasket, however, is another story.  It's about 90% of the job of a valve check so either wait a bit longer until the valves are due or go ahead and check them now and replace the gasket while you're at it.
2012 Concours 14 Arabian Red
Offline ZXtasy
  • COG#: 12569
« Reply #6 on: August 02, 2017, 04:22:39 pm »
Thanks again for all the input. With only 7200 miles on the bike and not another drop since my first post, I think I can wait until winter to pull the plastics and fully access the source and then go from there.
Search will be my friend.
Offline landman
  • COG#: 11621
« Reply #7 on: August 07, 2017, 12:07:44 am »
i betting valve cover gasket.  >:(
2015 ninja 1000 abs
2014 concourse 14
2012 concourse 14- sold
Offline Zarticus
  • COG#: 10785
« Reply #8 on: August 07, 2017, 12:48:40 am »
There is no "infamous oil filter leak" , It's either the Cam sensor oring or valve cover gasket as others have mentioned. I had BOTH  :o
1986 Honda V65 Magna, Black
1984 Honda V65 Magna, Black
1983 Honda V45 Sabre, Red
Offline Bruiser
  • Bruiser
  • COG#: 10410
« Reply #9 on: August 07, 2017, 03:54:09 am »
I was a victim of the ghastly cam sensor leak a few years ago. It was fixed under warranty and hasn't leaked since in 35000 miles. Haven't heard of anyone experiencing a valve cover gasket leak but it could happen.
Bruiser
2012 Kawasaki C14
93 Kawasaki C10
1982 Honda CX500 Turbo
1980 Kawasaki KZ1000ST
1978 Honda CB750F
1976 Kawasaki KZ400
1976 Honda 750K
1973 Honda CB500K
1973 Honda SL175
1972 Honda SL125
Offline ZXtasy
  • COG#: 12569
« Reply #10 on: August 07, 2017, 11:52:45 am »
Well I wondered why folks sell and others buy an oil filter protector for these things, seemed to someone to be an issue.
My ZX-10 developed a valve cover leak and drip but that was after around 25K of hard riding. They just get tired and hard after all that heating.
Offline angelo
« Reply #11 on: August 14, 2017, 10:02:09 pm »
ZX, if you are comfortable waiting, wait.  My sensor o ring was a culprit and greasy and messy up top - but never led to a single drop on the floor.  So maybe valve cover gasket it is.
BUT - almost everyone who does their own valves finds them tight - the first time at least - then they migrate much less.  My amateur opinion is to put many miles on the bike this fall.  Enjoy. Do the valves this winter with a new over sized o ring, valve gasket, and spark plug well gaskets.  (Murphs has a kit).   Valves will be good for a long while and no more leaks will exist.  IMO and in my limited experience.
Offline old n slow
« Reply #12 on: August 14, 2017, 10:41:15 pm »
Maybe it was just some oil drool that may have dripped on the fairing lip when you removed the filter...just took it a few days to ooze itself to the drip stage.  You did mention it started right after an oil change?
Mike D.
old n slow...it's my way of life☺
Offline ZXtasy
  • COG#: 12569
« Reply #13 on: August 14, 2017, 11:38:08 pm »
Thank you all, Angelo, yes I will wait...it has not dropped any since.  O&S, I mentioned that it occurred 600 miles after my initial purchase oil change, so I still believe it is a mild leak that maybe pooled over those 2 months and finally gorped.
The real thing is I need to ride it more!!!
