Author Topic: passenger peg  (Read 539 times)
Offline woodie
  • COG#: 10389
passenger peg
« on: September 28, 2018, 02:53:19 am »
One of my passenger pegs does not stay up. I haven't looked close but feels like there must be a small thin spring piece that gave out. I looked quick at Murph"s and did not see anything. Is that item something from a dealer only? Thanks
Offline CRocker
  • '02 C10 CDA # 416
Re: passenger peg
« Reply #1 on: September 28, 2018, 04:05:53 am »
Not knowing what year your bike is...on a 2012...the "Stopper" is PN 32085-0046...although, if this is the part, one might wonder how it became missing...or, not working.  They are cheap...not sure if it is available elsewhere...but, at $2.50 each through the dealer...one doesn't have to look long to eat up any savings.  Guess it could be the coil spring...as well.  Like I said, these part numbers and the link are for a 2012 model.
https://www.partzilla.com/catalog/kawasaki/motorcycle/2012/concours-14-abs-zg1400ccf/footrests
Good luck!
« Last Edit: September 28, 2018, 09:06:28 am by CRocker »
Re: passenger peg
« Reply #2 on: September 28, 2018, 02:16:49 pm »
If you've ever had the footpeg off, you may have lost the ball/spring.
Or, it just may be gummed up from roadfilm/etc and need's cleaning.
Could probably blast it out with WD-40 on the bike, but best to remove, check the parts, and clean....
« Last Edit: September 29, 2018, 12:38:34 pm by connie_rider »
Offline woodie
  • COG#: 10389
Re: passenger peg
« Reply #3 on: September 29, 2018, 02:45:31 am »
Thanks for the input. It's a 2011. I'll take a closer look at it.
Offline woodie
  • COG#: 10389
Re: passenger peg
« Reply #4 on: October 01, 2018, 03:11:24 am »
Finally took peg off. The ball is stuck in. Have it soaking with PB penetrating fluid. If not free tomorrow I might drill a small hole from the back and tap the ball out that way.
Offline woodie
  • COG#: 10389
Re: passenger peg
« Reply #5 on: October 01, 2018, 10:15:11 pm »
Got it taken care of. I drilled a hole from the back, the ball came out easy but the spring was very corroded in. When the spring finally came out, I cleaned things up and works like new now.  The bike has 125k+ miles and really has not had a passenger during that time. Not surprising that it got a little corroded during that time.
Offline CRocker
  • '02 C10 CDA # 416
Re: passenger peg
« Reply #6 on: October 02, 2018, 02:38:59 am »
Makes sense...cool beans!
