Author Topic: Push-starting a fuel-injected bike  (Read 3041 times)
Offline Jaxrider
« on: June 24, 2008, 11:50:00 am »
A friend of mine was traveling out of state and had starter problems on his BMW R1150S. He went through a flooded stretch of road and the water got into his starter, which made it fail the next morning when he went to fire up his bike.     He said you could not push-start or bump-start fuel-injected bikes, which seemed odd to me. I don't have one to try it hence this post.     Can you bump-start or push-start a fuel-injected bike?     thanks
2002 Kawasaki ZZR1200 for riding with the wife
2004 SV650S for riding solo and on the track
2007 DRZ400SM for riding solo and on the track (lots of fun in 38hp)
Responsible for wrenching on all those plus my daughters' 2007 ZZR 600
US Review http://www.motorcyclistonline.com/ro...200/index.html
EU Review http://www.motorbikestoday.com/revie...es/ZZR1200.html
« Reply #1 on: June 24, 2008, 02:01:00 pm »
My guess is no if the battery is DEAD but maybe yes if the battery is just a bit to low to turn the starter.  But I am guessing.  ----------------------------------  I will answer any question.  It is up to you to figure out if I should have.    <p align="left">My Photos<br
Offline Jaxrider
« Reply #2 on: June 24, 2008, 02:20:00 pm »
At first they thought it was the battery, and tried to jump-start it with a car using jumper cables. When that didn't work they bought a new BMW battery from a dealer and it still didn't work.     So... can you push-start a fuel-injected bike with a new fully charged battery?
Offline Paul_Murray_IL
« Reply #3 on: June 24, 2008, 04:25:00 pm »
I found this on the R6 forum.  http://www.r6.com/forums/showthread.php?p=2919    Just as long as the battery is good then give it a push. Might have to figure out what gear start in because the rear wheel will lock up because of the engine compression.
06' Concours  85' Honda Nighthawk 450 (Sold)  96' Yamaha Virago 535 (Wifes)  COG# 7131  Round Lake Beach, IL.  KB Steppers, Tank Bra, Givi E52 Maxia w/ back rest and rack, Tammy's Fuel Gauge Adj
Offline Jaxrider
« Reply #4 on: June 24, 2008, 05:04:00 pm »
That is what I thought... the only other point would be the shaft drive but that should be ok too, at least for an occasional push-start.     Instead my friend has to drive a 500+ mile round trip to pick up the bike in his truck. He was traveling with a friend and they could have pushed it then rode back home. I figure let it idle and have the other watch it when you're in the head or getting a bite to eat. What do I know though.
Offline Fred_Harmon_TX
  • COG Technical Editor
    • Angel Ride Videos
  • COG#: 2170
« Reply #5 on: June 29, 2008, 10:09:00 am »
I have push started fuel injected Gold Wings. It works just fine, but the battery has to have enough juice to power on the ECM and fuel pump and associated relays. If the voltage drops below around 10 volts, you may not be able to push start it.    If the battery is low, remove the fuses for the tail lights and headlights to reduce the load on the battery, and then try to push start it.
Fred H.
Offline Jaxrider
« Reply #6 on: June 29, 2008, 01:18:00 pm »
Great advice Fred!
Offline JEM
  • COG#: 8269
« Reply #7 on: August 15, 2008, 09:43:00 pm »
This is correct. My battery was too low to start my Concours 14 last   winter, so I pushed it down my steep driveway and jumped on. It fired   right up!      Jeff  '08 Kawasaki Concours 14  '92 H-D FXRS Low Rider  '90 Honda Rebel  '79 Kawasaki KE 125  '78 Kawasaki KM 100
Jeff
COG #8269
'90 Honda Rebel
'79 Kawasaki KE 125
'78 Kawasaki KM 100
Offline Patrick_Whitehead_VA
« Reply #8 on: August 24, 2008, 05:03:00 pm »
WOW that was kinda tempting the CDA gods wasn't it?
