I have push started fuel injected Gold Wings. It works just fine, but the battery has to have enough juice to power on the ECM and fuel pump and associated relays. If the voltage drops below around 10 volts, you may not be able to push start it. If the battery is low, remove the fuses for the tail lights and headlights to reduce the load on the battery, and then try to push start it.
