Author Topic: Rear brake pedal engagement point  (Read 7762 times)
Offline Freddy
  • West Aus
Re: Rear brake pedal engagement point
« Reply #25 on: July 18, 2017, 04:16:37 am »
That's a less common fault these days so take it to the dealer for repair.  Kaw should rectify it without issue.
« Last Edit: July 19, 2017, 01:26:59 am by Freddy »
Offline Deepsea
« Reply #26 on: July 18, 2017, 09:12:08 pm »
Slow is smooth, smooth is fast. Don't grab anything, use slow smooth hand controls. Both throttle and brake. I trail brake most any corner above dead slow, it helps settle the chassis and keeps the forks compressed. If you try this be very careful learning as it's easy to over brake and lose the front end. Even letting off the front brake needs to be slow and easy.
Retired Navy Saturation Diver
Offline flashback50
« Reply #27 on: July 19, 2017, 02:25:12 pm »
Being thorough, as you say, would include flushing the blocked off circuit.    :beerchug:
I heard recently that if you turn key on when flushing the brakes that it allows fluid to flow thru the ABS circuits that are normally closed when bike is off. Don't know if it is true but would be nice.
Offline parttimer`
« Reply #28 on: July 19, 2017, 02:44:12 pm »
So, i am not sure if anyone has noticed after installing the AST lowering kit the rear pedal goes dead sometimes?  I will probably make a post about this on it's own so as to not thread jack.  After installing my AST lowering kit my rear brake works, sometimes, other times I too have to give it a press or two then the engages.  This is on a 17, and I have the aggressive setup for braking running, i don't have it set using the detuned setup in the 15+ models.  When applying the pedal it sinks all the way with very little slowing.  Let up on the pedal, press again and bam, braking.
Offline cyberswine
« Reply #29 on: July 19, 2017, 03:59:29 pm »
To the question raised about pulsing on the front brake of a new bike:  my '15 started that and I had the rotors replaced under warranty, a little hassle from the dealer but Ma Kawasaki straightened them out right smartly for me.  A search should reveal more on that issue.
Offline Freddy
  • West Aus
« Reply #30 on: July 19, 2017, 09:36:17 pm »
Why didn't I think of that?   >:(    It's true that the solenoids/valves are cycled at start-up but it's unknown whether that happens before or just after the bike is ridden those first 5 yards or so and light goes off if all is well - except for the gen 1 rear brake failure warning.
Whatever, it would be a good thing to do.   :beerchug:
Offline flashback50
« Reply #31 on: July 19, 2017, 11:47:45 pm »
This came from a service tech that has been in the Industry for many years so I'm hoping it does indeed work.. I will be trying it the next time I flush my brake and clutch fluids for sure. I guess it can't hurt to try  :beerchug:
Offline Freddy
  • West Aus
« Reply #32 on: July 20, 2017, 02:28:32 am »
Thinking..........thinking.........  :017:  :c029:  That hurts.   :'(   and we're   :offtopic:
There was an interesting discussion on this issue in the thread below starting at reply 112.
Still thinking about what I know of how the system works, it seems unlikely to me that bleeding while turning the key on and/or off would do anything extra.  My reasoning is that the solenoids & valves probably don't cycle until the bike begins to move - but doing a stationary experiment with a pint or so of fluid may indicate something, which I (and perhaps others) will try out of curiosity.  If the valves do cycle then, that would momentarily close the circuit from the m/cyl to the caliper, causing a hydraulic lock because the line to the caliper would then be open to the pump, therefore closed to the m/cyl.  (This is the rear brake failure some gen 1 owners have reported, due to stuck valve.)  Whether the speed at which this potentially happens would be discernible is an unknown, but perhaps the operator may feel a hydraulic pulse of some sort.   :??:
As you say, it can't hurt to try and I, for one, would be interested in what you discover, if anything.
http://forum.cog-online.org/concours-14-zg1400-general-chat-and-tech/abs-failure-due-to-fluid/100/
Matt makes an interesting point here about activating the ABS then rebleeding:
http://forum.cog-online.org/concours-14-zg1400-general-chat-and-tech/bleeding-brakes-on-an-abs-model/msg309502/#msg309502
« Last Edit: July 20, 2017, 07:54:03 am by Freddy »
Offline sfsokc
  • COG#: 10667
« Reply #33 on: July 20, 2017, 03:14:14 pm »
For the life of me, I just don't understand this selective and confusing approach to braking. As long as I can remember, from the MSF safety course, to books I've read from David Hough and Lee Parks, I believe I've always seen that you use BOTH BRAKES smoothly on a motorcycle.  Why upset the dynamics or otherwise lose braking power, especially on a bike with linked brakes where it's supposed to compensate?
I've always ridden this way, with my old bike w/o linked, and now with the Connie.  Only issue I ever had was on the old bike, going downhill in a curve, in the rain, and stopping at a light one time.  Back wheel tried to lock and come around a couple times, where each time I eased up on the back brake to settle it.
Even when practicing full-on panic stops, with BOTH brakes, I've not locked the rear wheel on this bike.  So my advice to anyone is simple, use BOTH brakes smoothly, only modifying this habit if conditions really warrant it.  Your "muscle memory" should be to use both brakes.
Online connie_rider
« Reply #34 on: July 20, 2017, 05:18:32 pm »
Steve, what year C-14 do you have?
Offline sfsokc
  • COG#: 10667
« Reply #35 on: July 20, 2017, 08:22:22 pm »
It's a 2011 Ted, combined 50K+ miles or so between the last two bikes.
Online connie_rider
« Reply #36 on: July 21, 2017, 04:08:27 pm »
Not sure you have the linked brakes on your 12?
If not, we all agree that using both brakes is best.
The problem is the Linked brakes on the C-14. {mine is a 2014}
ie; If you are using a brake (front or rear) and apply the other, the braking force suddenly multiplies.
       It does not do so as a smooth transition...
       For instance; (While using the front) If I touch the rear,, the change in braking force is "drastic".
What works best for me is to use the front brake lever only.
      The front does most of the braking and links in the rear. {so that it is doing it's part}
It was hard to teach myself to use front only. {as I've always used both on a non linked system}.
Offline old fart
  • I dabbled in pacifism once
  • COG#: 11585
« Reply #37 on: July 22, 2017, 04:58:08 am »
Hey Rock
This is Rick. Give me a holler and we can compare notes. I live right up the road from your mom.
09 Connie(totaled)
14 Connie with SiSF flash
Offline TNConnieRider
  • COG#: 12722
« Reply #38 on: January 05, 2018, 09:44:44 pm »
I use the rear brake at low speed like you and at high(er) speed when in a corner/bend and needing to drop some speed without the bike wanting to go off line by use of the front brake.  That's is/was the major complaint/trouble with the linked system until Kaw changed the ABS ECU linked calibration a coupla years back to minimise or eliminate this characteristic.  I haven't ridden a recalibrated model to find out but that's been reliably reported elsewhere.
Hmm.. not sure how to respond to that statement.
I  never touch the rear brake- I gear down of course and use engine braking and also practice Trail Braking when entering  a turn (I want the suspension to be compressed and remain compressed going into a turn- rear brakes cant do that---were talking about  hard  cornering )
Trail Braking is not really something to be used for  street riding but I still practice but I was taught on the track to never touch the rear brake... of course we did not have anti lock brakes  or linked brakes in those days so I maybe a throwback cuz  I am old
On the track, brakes into a turn, not in it. also, gear shift reversed- 1 up 5 down. Ahhh what memories
Honda MiniTrail 50, Yamaha GT 80, Suzuki TC 100, Yamaha DT 125, Kawasaki KZ 400 Ltd   Kawasaki KX 125, Suzuki RM250, Kawasaki ZX600,Kawasaki Concours C10 (#1) Suzuki Boulevard C50,Kawasaki Concours C10 (#2)
Offline Lee Ving
« Reply #39 on: January 07, 2018, 09:20:49 am »
Curt, not normal. Check for warped rotors.
Offline Lee Ving
« Reply #40 on: January 07, 2018, 09:48:55 am »
The GP guys absolutely use rear brake. The Concourse is a horrible example to test this on due to the rider aids, but rear brake has a stabilizing or settling effect on the chassis when applied at speed. Application of the rear produces a torque on the swing arm that tends to compress the rear suspension and lower the rear. It takes skill to use the rear in racing, but that lowering effect helps keep the rear down when braking hard.
To the original topic, in the original mode my bike is real grabby on the brakes if I use the rear indiscriminately. If I ignore the rear brake pedal all is well. I have noticed that in the original mode that the rear does not engage at the same point at all times and seems to be unpredictable. It even seems to vary day by day and with warmup. At higher speeds and 2 up the brakes feel better in original mode, but I use the second newer mode 100%. Even so, I still have to respect the rear pedal.
Rider aids make my blood boil.
Offline Freddy
  • West Aus
« Reply #41 on: January 07, 2018, 12:38:43 pm »
<snip
What you're describing is the Kaw linked system operating, is it not?
Online connie_rider
« Reply #42 on: January 07, 2018, 05:04:00 pm »
After I got my C-14 I hated the linked brakes.
Others told me to stop using the rear pedal.. (Post #14)
So, I forced myself to learn to use only the front brake lever.
   The bike stops fine if you only use the front brake lever.
I'm so used to it that I had completely forgot that you have 2 modes on this bike.
  {as I recall they are for normal/1-up and for 2-up riding?}
Guess I need to go look how mine is set...   :-[
In February, some of us are going to attend the Sport Touring School in Florida.
I'm sure they will instruct us on proper brake use.
     One of my questions will be about using the Linked Brakes on these bikes.
Offline Freddy
  • West Aus
« Reply #43 on: January 07, 2018, 10:47:10 pm »
Earlier in this thread I posted a link to what I did to the linked system.  That may, or may not, interest you.   :beerchug:
Online connie_rider
« Reply #44 on: January 07, 2018, 11:46:53 pm »
Thanks Freddy.
I was aware of your post, and considered it..
Opted to keep it stock
  Part of why I didn't opt to go that way was laziness.
  Part was the concern that the ABS wouldn't function properly.
At this stage, I'm pretty happy with the way I'm using it.
   {Just took me some time to learn to use only the front lever}..
      If I need the back pedal for a panic stop... I'm sure I'll use it too!!
I posted my last comment; for those that are now aware of using only the front,
                                        to let ya'll know we will ask their opinion at the school.
« Last Edit: January 08, 2018, 01:34:08 pm by connie_rider »
Offline Lee Ving
« Reply #45 on: January 08, 2018, 12:54:00 am »
<snip
Yes.
Offline barberman
« Reply #46 on: January 21, 2018, 06:34:04 pm »
Gotta' chime in here,  the brakes on my 2012 were strange feeling at first, especially the rear. I could feel the pulse"  OH that's normal? And it felt dangerously weak.  Might as well drag yer feet.  BUT after several (6) total bleed outs, new pads, and 90% alcohol rub down on the rotors, the brakes work beautifully. No pulsing rear pedal. And firm consistent braking.  Not that i use them much. (Just letting of the gas a tad lets me blow through corners at twice the suggested "retail" speed. ha ha) KJ
Offline Jason Haynes
« Reply #47 on: May 29, 2020, 06:50:57 am »
Hi All,
I know this tread is long in the tooth but I feel the OP's original question was never answered and I wanted to clear up some points in case others stumble on this thread.
  • The issue of the breaks pulsing. The pulsing is the K-ACT working to balance the front and back brakes. It might also be the ABS. Both cause the breaks to pulse. See owner's manual page 149, also attached. The aggressiveness of K-ACT will depend on breaking pressure applied and traveling speed.
  • The issue of the back breaks feeling soft causing the want/belief to pump them. If you rule out air in the lines, I believe this is still the result of the K-ACT. The computer is calculating the best break pressure to use for both brakes. So, if you hit the back breaks hard at a high speed, the computer is like, "Slow your roll cowboy, you don't need that much pressure", and adjusts accordingly. The softness will vary depending on breaking required on each wheel based on traveling speed and breaking pressure applied.
  • Also, if you pump them, you are engaging and re-engaging K-ACT over and over again causing the computer to re-calibrate each time causing the breaks to have a different touch each time. The feel will be different each time depending on again, traveling speed and breaking pressure applied.
  • To add on to the last point, if you are coming to a complete stop and you pump your brakes, you will most likely be taken off guard by the huge difference with the touch of the breaks as your speed goes under 12 mph. Here's what I'm getting at, If you approach a stop sign at say 40 mph and you pump your brakes, as previously mentioned, you will feel a different touch of the brakes because that's what K-ACT does. However, if you then again pump after your speed is under 12 mph, the K-ACT doesn't engage because 12 mph is the cut-off and you feel a huge difference in the touch of the breaks. Someone mentioned it felt like breaking was multiplied. This is because in my scenario above, K-ACT didn't activate on that last go and the difference between assisted and un-assisted breaking is felt. Kawasaki recommends you should use both breaks simultaneously to stop, even with K-ACT. This allows the smoothest, fastest and safest stop. This will also eliminate the feeling of the breaks being "multiplied" if you are one to apply the rear breaks first, then both, and finally just the rear when approaching 3~5 mph to stabilize your bike when coming to a stop.
  • The issue of relying on K-ACT and not using the back break. This sounds like an ideal approach on the surface because it's lazy, and I love lazy! It's the mother of invention after all! The only draw-back would be dependency on the K-ACT, and you are technically not driving the bike as Kawasaki intended. However, I would strongly recommend to NOT use the back break solely by itself to stop at higher speeds, even though K-ACT apply's the front breaks too when the back is solely engaged. The reason, K-ACT only applies breaks to the right front caliper in addition to the rear caliper and will cause unbalanced wear on your front breaks. Also, I could see this pulling the bike to the right and possibly pulling your bike down to the ground on an aggressive stop. So, this is a dumb feature and I don't recommend using it in that way. They should have only linked breaks when you apply pressure to the front breaks.
  • With the above being said, you can dumb down the aggressiveness of the K-ACT by using standard mode, mode 1, the icon without the breaks on the two circles, which was already mentioned. However, beware, it doesn't de-link the brakes. They are still linked. In fact, applying pressure to the front brake still links and applies about the same amount of pressure in both modes! The main difference between the modes is the link to the front break when pressure is applied to the back break. It takes mid to high pressure to activate the front. See excerpts from the service manual, attached.
« Last Edit: May 29, 2020, 07:22:47 am by Jason Haynes »
Offline Boomer
  • Wickford, UK
    • Boomers GTR Site
« Reply #48 on: May 29, 2020, 07:53:14 am »
Jasons post ^^^ makes sense, but I'll stick with my un-linked (but with ABS) 2008 model thanks.
Having ridden several later model C14s I am not keen on the linked brakes at all.
I already use front brake only 95% of the time and only use the rear brake for stabilisation, mid-corner line tightening, and emergency stops.
If you do an emergency stop on dry grippy asphalt and your rear tyre is still in contact with the road, trust me, you ain't nowhere near the maximum braking capability of the C14.
The ultimate braking force available on an ABS C14 on dry clean roads is nothing short of brutal!
In my dry road practice emergency stops the rear of the bike lifts enough that the rear tyre has no effect on braking force.
In the wet is quite different as the front ABS kicks in much sooner so it's worth applying the rear brake as it does have an effect.
I apply the rear brake in ALL practice emergency stops as it's a trained reflex action that I want to keep.
I do my emergency stop practices from 70Mph so it may be that if you test from lower speeds the rear doesn't lift.
I've never noticed any difference in the engagement point of the rear brake on my 2008, but then without Traction control or linked brakes I guess it wouldn't change.
The rear brake on the C14 uses a smaller disk and only a 2 piston caliper because you get most of your braking force from the front brake.
Those coming from cruisers may struggle to understand this. Go test it for yourself, but please build up to it.
If you just grab a fistful of front brake at 70mph without knowing what is coming you may lose control and come off.
If you REALLY want to scare yourself, find somewhere that has a bit of a bump midway through your braking zone. I did that once, and for a fraction of a second, as it passes over the bump, the ABS releases the brakes (presumably because the tyre loses grip) and it feels like you are accelerating. Then it re-applies the brakes and continues decelerating. Proper brown trouser moment!!
George "Boomer" Garratt
Wickford, UK
CDA-007
Offline Shizzle
« Reply #49 on: May 29, 2020, 11:54:57 am »
I bled the brakes and replaced all the fluid in my 2011 when I bought it last August. Did it the old fashioned way and had no issues accomplishing this.
