Author Topic: Rear brake  (Read 17875 times)
Offline Smitty
Re: Rear brake
« Reply #75 on: February 19, 2017, 06:09:03 pm »
Freddy, I may have misheard him, I have been known to only half listen to people...my male genetics :)
Offline Smitty
Re: Rear brake
« Reply #76 on: March 10, 2017, 10:20:13 pm »
Got my bike back from the shop this afternoon w/the new to me ABS pump I got off eBay for $150.  As of now everything seems to be working normal.  Finally, my brakes are working as they are supposed to :great: :beerchug:
Offline Smitty
Re: Rear brake
« Reply #77 on: March 17, 2017, 02:35:35 pm »
I sent my old defective ABS pump to MOB for dissection.  We shall see what he comes up with >:D
Offline Freddy
  • West Aus
Re: Rear brake
« Reply #78 on: March 21, 2017, 11:39:14 pm »
Smitty, you said a coupla pages back that you reported the brake failure to NHTSA (as per page 232 of the Owner's Manual).  Please report back when you get a reply from them.
Thanks.
Offline Smitty
Re: Rear brake
« Reply #79 on: March 22, 2017, 03:50:42 pm »
Thanks.
Freddy,
I just looked an I reported the issue almost a year ago.  I have not received any response.  If they are like the rest of our government organizations, I will be dead before they respond :??:
Offline Freddy
  • West Aus
Re: Rear brake
« Reply #80 on: March 22, 2017, 10:01:13 pm »
Blame Donny's friend Vlad.   :D
Offline Old Sparky
  • COG#: 10514
Re: Rear brake
« Reply #81 on: December 05, 2017, 02:41:40 am »
My 08 been down for a while and have been watching the banter.  Rear brake locked.  Any new news.
Learned to listen to the skilled ones for a time.  Don't have 1300$ just laying around.
Thanks for any info.
Honda '70 QA50       Kaw '74 Z1 900  Keith Code
Kaw '72 F7 125        Kaw '94 ZX900A   WERA
Kaw '72 F3 175        Kaw '82 GPZ550   AMA
Kaw '72 S3 350        Kaw '83 GPZ550
Kaw '73 H2 750        Kaw '08 ZG1400ABS
Offline Gscott
  • 09 C14
  • COG#: 12413
Re: Rear brake
« Reply #82 on: December 05, 2017, 01:52:09 pm »
Try opening the bleeder valve see if that will let you spin the rear wheel or I kept on stomping on the brake pedal and it finally released.
Then ride using front brake only, that's how I got mine to the dealer.
Offline Smitty
Re: Rear brake
« Reply #83 on: December 05, 2017, 03:32:26 pm »
I had to find a new ABS unit on ebay.  Found one for $150 bucks and had it installed by a local non-dealer shop (Kawasaki shop in my area wouldn't touch it, said it was outside their skillset).  Cost me $150 to install.  You can also delete the ABS function to the rear and make it a regular brake.  I had the shop do that for me until I got the new ABS unit.
Offline Freddy
  • West Aus
Re: Rear brake
« Reply #84 on: December 05, 2017, 10:29:44 pm »
No doubt you've read this thread from the start, OS.  Here's some more reading for you.  There are others about it in the links too.
http://forum.cog-online.org/concours-14-zg1400-general-chat-and-tech/abs-failure-due-to-fluid/150/
« Last Edit: December 05, 2017, 11:02:20 pm by Freddy »
Offline Old Sparky
  • COG#: 10514
Re: Rear brake
« Reply #85 on: January 28, 2018, 07:02:32 pm »
After reading for a while I opened up everything cleaned replaced all of the fluids.  no luck.  Even rebuilt the rear master.  Cannot get any fluid past the ABS unit.  Been looking for a loose ABS unit on eBay or anywhere any leads?  If I am reading right a new set of stainless lines should be part of the plan?  MOB how hard is it to get the ABS apart??  Thank everyone for the interesting reading. Will keep an eye on the banter.
Offline Freddy
  • West Aus
Re: Rear brake
« Reply #86 on: January 28, 2018, 10:55:44 pm »
Offline 1warlock
Re: Rear brake
« Reply #87 on: January 30, 2018, 04:28:42 pm »
my rear brakes malfunctioned with the pedal stuck thus leaving me with no rear brakes :'(, plugged the lines from the master cyclinder to the abs pump and ran a hose from the m/c to the calipher, brakes are better than ever :), don't feel any need to replace pump. Had no problem with front brakes, other than shaking, replaced disc and solved that problem. Had the $1250.00 estimate for the pump+ labor and decided to look for alternative. Thought about the Ebay alternative with a used pump, but decided it could have the same problem.
Offline Freddy
  • West Aus
Re: Rear brake
« Reply #88 on: January 30, 2018, 11:16:15 pm »
Some folks have done that on the over-active series 2 linked system to de-link the rear from the front, which removes ABS function to the rear as you have.
Offline smokin
Re: Rear brake
« Reply #89 on: January 30, 2018, 11:57:43 pm »
I wonder if changing the brake fluid as per service schedule would solve the problem of sticking valves in the ABS system.?Ideas anyone?
Due to the cost of the ABS/PUMP unit I am flushing/changing brake fluid every 12 months to avoid what I suspect is a  moisture caused problem in the ABS system.
« Last Edit: January 31, 2018, 12:01:14 am by smokin »
Offline flashback50
Re: Rear brake
« Reply #90 on: January 31, 2018, 10:23:47 pm »
I would think that if you change the brake fluid every 12 months you will never have the problem some are experiencing.
Offline JDSCO
  • 2016 C14
Re: Rear brake
« Reply #91 on: January 31, 2018, 11:44:39 pm »
+1 and it's inexpensive and easy to do
Gen James Mattis
Offline smokin
Re: Rear brake
« Reply #92 on: February 02, 2018, 01:16:12 pm »
I use :
Motul DOT 5.1 Brake Fluid
Suitable For: DOT3, DOT4, & DOT5.1
Description
Brake fluid will gradually absorb moisture over time, and without you noticing -- up until the point when you first experience brake fade. Flushing your brake fluid is one of the most important preventative maintenance jobs you can do to your motor bike. Being non-silicone and 100% synthetic, Motul's DOT 5.1 is considered to be one of the highest quality brake fluids available on the market today. With a high dry boiling point of 272°c (wet boiling point 185°c), Motul DOT 5.1 is manufactured with a lower viscosity to work more effectively with modern ABS systems. Recommended for drivers who use their motor bike daily, but still need that peace-of-mind for spirited road driving and light track work. The perfect upgrade for vehicles with DOT 3 and DOT 4 brake fluid recommendations.
