Author Topic: Rear maintenance C14  (Read 797 times)
Offline Doc
  • COG#: 12697
« on: December 24, 2017, 02:12:45 pm »
Happy Holidays! I have the rear wheel off to do my wheel bearings and grease the splines - anything else I should consider doing while I have the rear wheel off?  Thanks.
Offline Just Cliff
  • 200,000 or Bust!
  • COG#: 9547
Re: Rear maintenance C14
« Reply #1 on: December 24, 2017, 02:25:21 pm »
What bike & how many miles?
Cliff   :beerchug:
Offline Doc
  • COG#: 12697
« Reply #2 on: December 24, 2017, 03:55:08 pm »
2012 C14 ABS at 45k
Offline oldnslo_MO
  • COG#: 9924
« Reply #3 on: December 25, 2017, 12:55:14 am »
are you replacing the wheel bearings? i'm surprised they are bad with that mileage, my 09 had over 85k and the wheel bearings will still smooth as glass.. :??:
Offline Conrad
« Reply #4 on: December 25, 2017, 11:56:15 am »
Grease the shaft splines while you're at it.
2008 C-14 ABS
Northern Illinois
Offline JTX
  • TEXAS 2015 ZG14
    • 2015
« Reply #5 on: December 27, 2017, 11:21:03 am »
This.  It's probably over-due to take apart the drive shaft sections and inspect those and replace them if worn.  If not, new grease and check the plastic covers for damage.
Offline 4Bikes
« Reply #6 on: December 27, 2017, 11:24:07 am »
If you have them, the entire the drive shaft maintenance procedure is covered in disk#10 on Fred’s videos.
Offline Just Cliff
  • 200,000 or Bust!
  • COG#: 9547
« Reply #7 on: December 27, 2017, 01:15:28 pm »
I'm a little late back to this, but it looks like you got your question got answered.
I'm kinda with oldnslo on this. I replaced mine at 189,500 just because it seemed like a good idea. They seemed perfectly fine though.
Cliff   :beerchug:
Offline 4Bikes
« Reply #8 on: December 27, 2017, 01:25:32 pm »
I was wondering the same thing. I know from talking with others that the wheel bearings can go bad after 60,000 miles or last forever. There is also a case of someone replacing them as a PM, and a new one went bad after a short time. So it’s a coin toss??  ::)
Offline oldnslo_MO
  • COG#: 9924
« Reply #9 on: December 28, 2017, 03:26:39 pm »
CAUTION... the rear o  ring on the driveshaft on 2015 and up is no longer just an o ring..there is a rareflon ring that goes on over the o ring.. this ring uses a special tool to instal it kaw part#57001-1718... my 2016 connie sprung a leak  around this oring, and the dealer found out this change.. apparently the installer is around 400$, and it's easy to get the rareflon ring cocked, thus allowing it to leak again..this procedure is covered on page 11-25 of the factory manual for my 2016,, i would suggest that if you disassemble the driveshaft, be careful not to damage the rareflon ring as this could lead to a trip to the dealer, who may or may not have the installer.. ;)
« Last Edit: December 28, 2017, 04:52:28 pm by oldnslo_MO »
Offline Jerdurr
« Reply #10 on: January 05, 2018, 01:54:16 pm »
And this, Ladies and Gentlemen, is why this forum ROCKS!  :goodpost: :08:
Best,
JD
« Reply #11 on: January 05, 2018, 07:41:22 pm »
rareflon?  I had to google that one.  Like Teflon but very rare.
Sort of like Un-obtanium which is made from the hulls of alien ships.. :) :)
2000 Red C10 1052 kit
