Author Topic: Recommended adhesive for Techspec Skins  (Read 836 times)
Offline Jim
  • COG#: 12550
« on: April 08, 2017, 08:34:26 pm »
I purchased and installed the five piece skins from Techspec and one of the pieces has a section about 1 1/2" square at a corner that the backing did not adhere to the rubber.  Any suggestions what compound to use to fix this?  All the other pieces were completely secure to the rubber, just this one section.
Thanks.
Also, I'd post a photo, but I'm having issues with my phone pushing photos to email.
Iron Butt Association
2011 C14 - Black
Offline Jim
  • COG#: 12550
Re: Recommended adhesive for Techspec Skins
« Reply #1 on: April 08, 2017, 08:40:54 pm »
Here's the photo.
2011 C14 - Black
Offline FTB530
  • COG#: 12127
« Reply #2 on: April 08, 2017, 09:15:47 pm »
How old are they? New I would ask for replacement.
« Reply #3 on: April 08, 2017, 09:23:03 pm »
Ahhhh
Now I see, the adhesive stuck to the tank, but not the rubber...
They sell thin douple stick cello tape for mounting photos, that ought to work, between the existing stuck on film, and the rubber...
« Last Edit: April 08, 2017, 09:29:40 pm by MAN OF BLUES »
Offline jwh20
« Reply #4 on: April 08, 2017, 09:28:47 pm »
Have you contacted TechSpec Customer Service?  While these are really nice and they are fairly pricey, I'd expect them to work properly.
http://techspec-usa.com/contact-us.html
2012 Concours 14 Arabian Red
« Reply #5 on: April 08, 2017, 09:32:13 pm »
May be covered....
May.... be.....
http://techspec-usa.com/warranty.html
Offline Cigar Jay
  • born to be mild
  • COG#: 10822
« Reply #6 on: April 08, 2017, 09:43:13 pm »
I had an issue with a pad and tech spec was very supportive,
give then a call
 :great:
Offline Dirtwiz
  • COG#: 12372
« Reply #7 on: April 09, 2017, 02:54:15 am »
I bought mine 2 years ago and the tank pad separated from the adhesive when removing the backing. I called them and they asked which piece separated and sent me a new one immediately. They said they had a problem with them for a while. They have all stuck perfectly since then.
Offline ChrisD
  • COG#: 12153
« Reply #8 on: April 09, 2017, 09:50:18 am »
I had the same issues with one of the pieces, sent them an email with some pics and they promptly sent a replacement.  No need to screw around with it just contact them directly they will help.
Excellent customer support and service.
 :beerchug:
Online flyboy3107
  • COG#: 11978
« Reply #9 on: April 09, 2017, 12:19:31 pm »
If you don't want to take it off, maybe contact cement.
Offline ZG
  • COG#: 9735
« Reply #10 on: April 09, 2017, 01:20:38 pm »
Send pic to TechSpec, they will send you a new one for free.
Offline JimBob
  • Woman...WHOAAAA MAN!
« Reply #11 on: April 09, 2017, 06:46:42 pm »
I'd lean more to rubber cement. Pretty easy to remove later. Though contact works pretty good too, just harder to cleanup.
Goop would work too - it holds almost ANYTHING. But it's pretty thick stuff.
Offline MikeJ
  • COG#: 11581
« Reply #12 on: April 11, 2017, 03:43:47 pm »
I had same problem. Called TechSpec and they sent me free replacement. Be very careful using adhesives - you may regret it.
2014 Candy Cardinal Red
Offline jwh20
« Reply #13 on: April 11, 2017, 03:47:40 pm »
Correct!  Some adhesives will pull the paint off if you ever need to remove the pads.  Other adhesives will permanently mar the painted surface.
Offline flashback50
« Reply #14 on: April 11, 2017, 05:50:09 pm »
TechSpec customer service is A1.. Send them a pic and they will send you a new piece.  :great: :great: :beerchug:
Offline Jim
  • COG#: 12550
« Reply #15 on: April 11, 2017, 08:01:27 pm »
This is 100% true.  I contacted their online warranty request, attached a photo and they've already shipped the replacement pad today.   :)
2011 C14 - Black
