Author Topic: direction lights all flash when turn signal is used  (Read 1096 times)
Offline Gregg
« on: April 05, 2018, 03:51:10 pm »
My 2010 Concours directions all flash when I either switch left or right?
Offline Jeff
  • COG#: 12267
Re: direction lights all flash when turn signal is used
« Reply #1 on: April 05, 2018, 04:33:27 pm »
My guess would be a bad ground somewhere, if not that switch could be bad?
« Reply #2 on: April 05, 2018, 08:03:39 pm »
Did someone replace the incandescent lamps with LED style?
Have you recently ridden the bike in extremely hard rain for a long period?
Have you washed the bike, and unknowingly subjected that switch pod or the lamp covers to high pressure water, during the process?
Have you added ANY aftermarket lighting devices or electrical devices to the bike?
Offline Just Cliff
  • COG#: 9547
« Reply #3 on: April 08, 2018, 11:27:35 am »
I find very doubtful this is a water problem.
I think it's a ground problem of some sort. Somewhat similar to the ground problem in my 08. That was one of the ground blocks in the harness. Not a hard problem to fix, just a bear to chase down.
Good luck!
Cliff   :beerchug:
Cliff
2014 1000 V Strom
Offline Derek
  • COG#: 11636
« Reply #4 on: April 08, 2018, 04:49:09 pm »
The ground problem they refer to could be a bad bulb.  I have found that if a incandescent bulb breaks its filament it can light through the other filament and travel through the circuit.  I'm betting all the bulbs that are flashing are really the parking filament flashing... thus not as bright.
Start by pulling the bulbs one at a time, with each bulb pulled if problem persist put bulb back and move to the next one.  If problem stops... replace that bulb!
Likely the easiest but maybe not the cheapest... bad ground wire could be hard to track down but $0 cost to fix, if its a bulb... it will cost you a new bulb.... $2 maybe!
2010 C14 Concours
1983 Honda V45 Sabre (sold)
Ottawa, Ontario
Offline gpd323
« Reply #5 on: April 08, 2018, 06:22:19 pm »
The signals are single filament. There are no parking or running lights in the signal housings
« Last Edit: April 08, 2018, 06:34:43 pm by gpd323 »
