Author Topic: ABS question  (Read 978 times)
Offline flyboy3107
  • COG#: 11978
ABS question
« on: May 23, 2015, 01:10:28 pm »
I have a 2009 ABS and have a question about it. When braking from highway speeds, to enter an off ramp, when I apply the brakes I can hear my ABS operating. Almost sounds like a heat bug in the middle of July. When I release the brake lever and pedal I can still hear those damn heat bugs! Still hear the ABS. The bike rolls freely with no binding or anything. Was wondering if this is normal operating. Noise seems to go away after driving a little bit. Sometimes I wear a full face helmet, so I don't notice it as much, but when I wear my half helmet I can really hear it. Maybe I'll just wear the full face all the time. That way I can't hear it!
Offline Bandit
Re: ABS question
« Reply #1 on: May 23, 2015, 01:13:47 pm »
I hear that on my 2008 with ABS, only after I had  EBC pads installed . I read somewhere that it is a common noise with the EBC pads.
Offline Bigfoot_16
Re: ABS question
« Reply #2 on: May 23, 2015, 01:16:01 pm »
Have you checked your rotors with a dial indicator to see if they're out of flat (warped)?
Jim
2015 Concours 14
Offline Flat-spot
  • COG#: 11111
Re: ABS question
« Reply #3 on: May 23, 2015, 01:47:32 pm »
I don't think you're hearing the ABS.  When it's working, you'll feel it pulsating back through the lever/pedal.
Like Bandit said, EBC pads are famous for being noisy.  Some others might be as well.
Mine go quiet after release, though.  Don't know what that could be.  Might want to do a flush/bleed on the system.  Pistons might need a good cleaning so they will retract easily.
'08 C14
Offline Tinsailor
  • COG#: 7402
Re: ABS question
« Reply #4 on: May 23, 2015, 02:17:11 pm »
My 13 does it too, Ride on!
