Author Topic: Shim map pdf.  (Read 1863 times)
Offline Jet Fixer
Shim map pdf.
« on: December 23, 2015, 03:14:35 am »
Does anyone have a down loadable pdf file of a shim map?
I thought I remembered seeing one about a year ago but can't remember
 who offered it.
My search showed one from x9rider but the link no longer works.
I've sent a pm but haven't heard back yet.
If anyone has something available, it would be greatly appreciated.
Thank you.          John
Offline JPavlis_CA
  • San Jose CA
  • COG#: 2293
Re: Shim map pdf.
« Reply #1 on: December 23, 2015, 04:13:36 am »
Don't have the pdf, most of us use an Excel file. Use this link to download the file.
http://forum.cog-online.org/index.php?action=dlattach;topic=34643.0;attach=5952
Offline Jet Fixer
Re: Shim map pdf.
« Reply #2 on: December 23, 2015, 04:24:33 am »
That will work.   Thanks JP.    :great:
Offline 4Bikes
Re: Shim map pdf.
« Reply #3 on: December 23, 2015, 01:59:55 pm »
Here is a PDF of my map filled out.  I embellished it a bit to help me figured out the shim swaps.  Hope it helps.
Offline Jet Fixer
Re: Shim map pdf.
« Reply #4 on: December 23, 2015, 02:18:57 pm »
Thanks 4Bikes.   That looks like the Excel file JPavlis gave me the link to.
Thanks for the help Guys.        :great:
Offline gPink
  • MMVIII C XIV
Re: Shim map pdf.
« Reply #5 on: December 23, 2015, 02:21:41 pm »
I have not used this.... http://vicdzen.narod.ru/index/0-2
Offline JPavlis_CA
  • San Jose CA
  • COG#: 2293
Re: Shim map pdf.
« Reply #6 on: December 23, 2015, 02:34:45 pm »
I used it back in 2012 and posted it back then. Some people had trouble with the .exe version, but the .zip worked fine (Personally, I had no problem with the .exe, so...)
Butt... I think the spreadsheet version (from Fred?) is easier for most to figure out.
Offline gPink
  • MMVIII C XIV
Re: Shim map pdf.
« Reply #7 on: December 23, 2015, 02:36:45 pm »
Jim, your posting is probably where I got it.
Offline JPavlis_CA
  • San Jose CA
  • COG#: 2293
Re: Shim map pdf.
« Reply #8 on: December 23, 2015, 04:53:44 pm »
Oh, I know you did. I mean, who else besides me surfs random Russian web sites?   :))  ;)
Offline Flat-spot
  • COG#: 11111
Re: Shim map pdf.
« Reply #9 on: December 23, 2015, 05:14:40 pm »
JP,  downloaded the file in your 1st reply above.  Is there one available that's blank, not already used and filled in?  To print out.
'08 C14
Offline JPavlis_CA
  • San Jose CA
  • COG#: 2293
Re: Shim map pdf.
« Reply #10 on: December 23, 2015, 05:21:58 pm »
Just open it in a spreadsheet program like MS Excel, or Libre Office, or even MS Works and delete the info you don't want before printing. That's basically what I did, and then went back into the original unedited file, substituted my measurements and the formula's spit out the shim sizes. At least that's sort of what I recall doing.
Offline Flat-spot
  • COG#: 11111
Re: Shim map pdf.
« Reply #11 on: December 23, 2015, 05:25:57 pm »
 :great:
'08 C14
