Author Topic: Stebel air horn install  (Read 431 times)
Offline flyboy3107
  • COG#: 11978
« on: May 04, 2018, 10:39:58 pm »
I hope someone can help, I installed the horn with the relay. Everything went OK, except when trying it. It works fine but when I push horn switch, the horn sounds and my my switchback LED lights go off for a second and then come back on. I should state I have power wire  from lights and horn and I tied them together to have just one lug to battery. Thought that might have been the issue so I separated them so now I have two wires attached to battery, with inline fuses. Switchbacks still go out and then back on when I press horn button. What am I missing? Can I tap somewhere else for lights? Any help is kindly appreciated. Just the switchbacks go out, none of the other lights go out.
Scott
Offline Old Steve
  • COG#: 10537
Re: Stebel air horn install
« Reply #1 on: May 05, 2018, 03:27:57 am »
Is the bike running during these tests?
Offline Deepsea
« Reply #2 on: May 05, 2018, 05:39:07 am »
Did you use a relay for the horn? Did you use a relay for the lights? Do they share the same ground? Did you ground the horn directly to the battery?  Does the relay have an internal diode?
Air horns have a very high initial amp draw and will often cause other things on the same circuit to be under powered during the inrush of power.
Retired Navy Saturation Diver
Offline flyboy3107
  • COG#: 11978
« Reply #3 on: May 05, 2018, 08:35:32 am »
Tried it both ways, same results
Offline flyboy3107
  • COG#: 11978
« Reply #4 on: May 05, 2018, 08:37:51 am »
Yes,No,NoNo, Don't know, it was supplied with horn.
Offline Deepsea
« Reply #5 on: May 05, 2018, 08:42:57 am »
Run one more wire, an independent ground wire directly to the battery for the horn should solve your problem.
Offline Deepsea
« Reply #6 on: May 05, 2018, 09:01:08 am »
As for the relay question of does it have an internal diode. Anything with a motor such as an air horn has the potential to "leak" voltage backward and can damage other components. This isn't a very good explanation but you can get the basic idea. Look at your relay where the connection numbers are. If there is a little funny looking line with an arrow between two or more of the connections it has a diode. The diode acts as a one way check valve in the circuit.
  Any electrical engineers jump in here.
