Author Topic: STOCK EXHAUST MODIFICATIONS  (Read 22844 times)
Offline thundermax
  • COG#: 11055
« on: December 15, 2012, 03:07:55 pm »
Surveying the membership and asking "Have you ever modified a stock exhaust? Have you ever taken off the end, taken out anything, put is back together, and had a slightly more muscle sound? >:D
Riding since 1966 at 13. Just purchased my tenth bike in my life. Now have two at same time. 2009 C14 and 2012 C14. Here are bike I have owned: 1958 Cushman model 721 Highlander, 1960 Cushman Super Eagle, 1971 Honda SL 100, 1974 Yamaha RD350, 1975 Honda 750 Four, 1971 Honda SL 175, 1998 Vmax, 2005 Vmax, 2009 C14, 2012 C14. COG#11056, South Central Area, Oklahoma.
Offline oldnslo_MO
  • COG#: 9924
Re: STOCK EXHAUST MODIFICATIONS
« Reply #1 on: December 15, 2012, 06:57:20 pm »
no... :)
Offline Larry
  • COG#: 9359
« Reply #2 on: December 15, 2012, 09:00:01 pm »
Don't do it Davie....replace it.  Don't bother.
10 Kawi Concours 14 ABS
Offline Glenn
  • COG#: 10332
  • Membership Level: Marketing Officer
« Reply #3 on: December 15, 2012, 09:23:50 pm »
I guess you try to make it sound better.  Doesn't help with the looks any.  ::)
Offline ZG
  • COG#: 9735
« Reply #4 on: December 16, 2012, 12:25:10 am »
 :iagree:
Offline Fred_Harmon_TX
  • COG Technical Editor
    • Angel Ride Videos
  • COG#: 2170
  • Membership Level: Tech Editor
« Reply #5 on: December 16, 2012, 12:54:01 am »
There have been several folks who have taken the stock muffler apart and shortened it significantly. All the reports I've seen have indicated that it didn't change the sound at all, but made it look a lot better. I think they cut about 6 inches or more off it. There were several threads about this on the old board back in 2008/09 before it "crashed". Haven't seen any recently.  I believe they were taking it apart and cutting out the flame arrestor and removing a section from the front of the muffler and then TIG welding it back together.
Fred H.
Offline thundermax
  • COG#: 11055
« Reply #6 on: December 16, 2012, 01:33:43 am »
Ok mod it does not work. What are the alternatives and costs?
Offline mehush
  • COG#: 11038
« Reply #7 on: December 16, 2012, 02:06:41 am »
There was a recent thread about a Delkevic (sp?) slip-on that was reasonably priced and got favorable feedback.
I'm not a fan of the stock exhaust as far as looks or sound goes. But you know what they say.........it's hard to shine a turd. If I had plenty of expendable cash I would replace it. As it sits(stock), the bike performsjust fine..........and I guess I'm OK with that.
Offline nando
  • Transport C-14
  • COG#: 10454
« Reply #8 on: December 16, 2012, 05:38:42 am »
If it don't change the sound it might be worth getting rid of a couple pounds. I was surprise how heavy that thing is.
Offline PaleRider
« Reply #9 on: December 16, 2012, 11:40:10 pm »
I took some bad advice from ST-Owners and drilled out the mufflers on my ST1300!!!
Worst sound ever >:(  like a scooter with a hole in the muffler!!  Had to ebay a used set of factory mufflers.
Leave it till you can afford what you want.
BTW I have also heard good things about Delvic.
« Last Edit: December 17, 2012, 03:01:18 am by PaleRider »
Have Owned 2004 Honda VFR, 2004 Honda ST1300, 2000 Triumph Sprint ST.
Now 2012 ZG1400 in Pearl Arabian Red
Offline Pistole
« Reply #10 on: December 17, 2012, 01:16:13 am »
- not my pictures
Offline nando
  • Transport C-14
  • COG#: 10454
« Reply #11 on: December 17, 2012, 02:22:49 am »
Wow! that is some hearty work there...I 'll be sending you my muffler shortly here Dog!!!  :)
If it does'nt change the sound it should be worth it..."quiet" is my friend...
between the bikes, jets, and guns, my ears have had all they can handle...I can't even hear myself think these days.
Offline Bruiser
  • Bruiser
  • COG#: 10410
« Reply #12 on: December 17, 2012, 04:17:52 am »
That looks good! I'm saving my nickels for a new exhaust, so in the meantime, all I've done is paint the silver ends black.
Bruiser
2012 Kawasaki C14
93 Kawasaki C10
1982 Honda CX500 Turbo
1980 Kawasaki KZ1000ST
1978 Honda CB750F
1976 Kawasaki KZ400
1976 Honda 750K
1973 Honda CB500K
1973 Honda SL175
1972 Honda SL125
    • Angel Ride Videos
  • COG#: 2170
« Reply #13 on: December 17, 2012, 01:04:18 pm »
Thanks for reposting those photos. I believe several folks have successfully shortened the muffler by cutting it like that, and it does make it look a whole lot better. Reports I read indicated it didn't change the sound, just made it smaller so it didn't stick out the back end so far.
The weld under the rear cap has to be ground off so the muffler core can then be pulled out of the outer casing. The section that gets cut off is the flame arrestor section off the FRONT end of the muffler core, and then the same length has to be cut off the REAR section of the outer casing, being careful to match the original cut angle, and the muffler internal core is then slid back in the outer casing and it has to be TIG welded back together at the rear when you're done.
« Last Edit: December 17, 2012, 01:20:11 pm by Fred_Harmon_TX »
Fred H.
Offline Glenn
  • COG#: 10332
« Reply #14 on: December 17, 2012, 01:41:59 pm »
If you are patient, you can sometimes find deals here on the COG Emporium.  I found a little used Two Bros. slip on for $250 plus shipping, and a friend of mine got a CS ONE shipped for $325, so good deals are out there, if you look for them.
Offline Stlheadake
  • COG#: 9142
« Reply #15 on: December 17, 2012, 01:52:46 pm »
I replaced my stock exhaust with an Area P.  No regrets.  It's not too loud for all day riding, but when you get in it you KNOW you're in it!  My question is, WHY IS THE STOCK CANNON SO DAMNED BIG?  It looks like someone hacked a car exhaust on the side of the bike!  I understand there regulations, but look at other 'big' bikes and their exhausts aren't so ugly!  Heck, look at the new FJR.  It's exhausts are big, but they at least made them look decent.
« Reply #16 on: December 17, 2012, 02:02:26 pm »
You know the really weird part. The ZX14 had a beautiful dual exhaust, where as they went with the single Howitzer look on the C14. Over the years you have heard little in the line of how folks liked the C14 exhaust, but you heard how they really didn't. We also have heard many times how the ZX14 exhaust looked good and folks installed them on their C14's. But rather than Kawasaki taking that nice look of the ZX14 for the C14. The went the other way and took the (IMO) less than aesthetically pleasing look of the C14 exhaust and gave the ZX14 that look. You really gotta wonder sometimes.   ???
Offline Stlheadake
  • COG#: 9142
« Reply #17 on: December 17, 2012, 02:42:15 pm »
+1 cap'n Bob!     :iagree:
The potato launcher, cannon, bazooka, whatever you call it is U G L Y!! regardless of how you look at it!
Offline nando
  • Transport C-14
  • COG#: 10454
« Reply #18 on: December 17, 2012, 04:40:48 pm »
does the ZX dual fit on the C14?....if it does, what does it take to make the switch?...
Offline Glenn
  • COG#: 10332
« Reply #19 on: December 17, 2012, 05:18:59 pm »
+2  :iagree:
I just don't get what they saw in that huge exhaust.
Offline Phil
  • COG#: 9813
« Reply #20 on: December 17, 2012, 06:12:28 pm »
Two Words is all U need to know:
Two Brothers!
    • Angel Ride Videos
  • COG#: 2170
« Reply #21 on: December 17, 2012, 07:14:34 pm »
I have a full ZX-14 exhaust setup sitting in the corner of my garage. I was intending to put it on, but after I got it, I started doing some measurements, and the ZX-14 setup is significantly heavier, since it has two cans. I also noticed how long the ZX14 mufflers are. They are easily as long as the single can on the C14. So while it may look a bit nicer, it weighs almost twice as much, and if you remove the saddlebags, you'll now have two really long pipes sticking out instead of one. This is why it continues to sit in the corner of my garage unused.
I suspect they went with the single can on the ZX14 for the same reason, weight reduction.
Fred H.
Offline johnnyc14
« Reply #22 on: December 17, 2012, 10:50:18 pm »
That modified muffler is mine. I had the bike dyno'd after I did it and there was no difference in power output until after I removed the flies and installed the PC3. Here's a link to the original thread on another site. I still have the bike, now with 40,000 km on it.
http://www.zxforums.com/forums/gtr-1400-forum/9977-exhaust-cut-down-2.html
Offline nando
  • Transport C-14
  • COG#: 10454
« Reply #23 on: December 17, 2012, 11:22:30 pm »
There is a dude in that forum reference that is a Darksider...literally! I felt the presence of Vedar there for a minute...in between muffler readings....
Offline runnerb0y
  • If you don't think too good, don't think too much.
  • COG#: 10517
« Reply #24 on: December 18, 2012, 03:24:44 pm »
Initially I thought "ehh, cutting 4" off that cannon wouldn't make that much difference".  Boy was I wrong.  That looks much better.  I think Kawi should hire that guy to design their exhausts.  I'd still rather see a symmetrical dual exhaust on nearly every bike, but shaving some off the Connie's launcher certainly does help aesthetically speaking.
| COG#: 10517  |  2012 C14 - Candy Arabian Red  |
