You can usually tell what your getting by the price. The TS Moly, 70%, is great. Its too expensive, for me, to use very often the motorcycle though, and its really not necessary as the Honda stuff works fine I use it in my spring piston powered airgun. The high powered, spring piston powered airguns need to be lubed, obviously, btu generate huge amounts of heat when the air in front of the piston gets compressed. If you lube with cheap moly lube, they are mostly made of carrier agents than BURN! This causes your pellets to go supersonic and makes a hell of a loud bang, and damages things.
The TS lube wont burn and works really, really well.
