Author Topic: Tightening Fairing Screws  (Read 1661 times)
Offline 4Bikes
« on: April 18, 2013, 09:44:04 pm »
I had the fairings off for maintenance.  I was surprised to see that a few screws were very loose after a few months of riding.  My inch pound tongue wrench only goes as low as 25 inch lbs, so I tightened them by feel.  Fred tightens his on his videos with "give it a twist"  Obviously too tight is bad, but so is too loose. Does anybody have a tip for what can be considered "good and tight" or some way to be consistent?  Is thread locker an option?
« Last Edit: April 18, 2013, 10:33:09 pm by 4Bikes »
Offline JerBear
  • COG#: 12777
Re: Tightening Fairing Screws
« Reply #1 on: April 19, 2013, 12:24:16 am »
I use the two finger and a little push method, mostly a "feel" thing.  Thread locker, I think, would be a bad idea the nut may spin in place when you try to remove it later.
2008 Silverdammit C14
Offline David
  • COG#: 10605
« Reply #2 on: April 19, 2013, 12:30:51 am »
Before you do the work purchase a few extras (screws),  they are very soft. The plastic pins as well.
"Speed is fine but accuracy is final"
1976 BMW R90 RS
1992 BMW K100 RS
2000 BMW K1200 RS
2011 Kawasaki C 14
Offline Sharp Charge
  • COG#: 10848
« Reply #3 on: April 19, 2013, 01:33:54 am »
Soft isn't the word!  I had my fairings off last week to find a coolant leak and the lowest screw on the right side near the oil sight glass rounded right out.  I had to drill it and buy another online.   :-[
Offline 4Bikes
« Reply #4 on: April 19, 2013, 11:08:02 am »
Anybody want to venture a guess as to how many inch pounds the fairing screw torque spec would be?  It’s not listed in the manual, and I know it is definitely less than 25 Inch pounds.  Trying to be consistent with the screws (and avoid cracking the fairing or rounding a screw), I’m thinking of devising a homemade torque wrench. Perhaps a spring-scale on the end of an Allen wrench.   If I had to guess, 12 inch pounds?
Offline cablebandit
« Reply #5 on: April 19, 2013, 11:55:18 am »
Who the hell tightens those little things with a torque wrench?!  Just snug them up and go bout your day.  They have a good inch of thread to back out before they fall out.
Oh...if you are rounding the larger ones out odds are your hex wrench isn't seated all the way down in the bolt head.
« Reply #6 on: April 19, 2013, 12:05:12 pm »
The first time I took my 09 in for service they had to easy a screw out and I knew it was tight from the get go. It even came back with an extra Phillips head screw.
After the first time I took my fairing off a order for screws and nylon washers was sent off. I have plenty of those on hand now but this time its the well nuts I'm waiting on.
I check screws and the bolts I can get to tightness bi monthly during the riding season.
Offline 4Bikes
« Reply #7 on: April 19, 2013, 01:03:09 pm »
Not me (yet) but I’m thinking of trying it.  Snugging them up failed me, and I had two that were just about ready to fall out, and most others were loose.
Offline Quickwilly
  • Meh
  • COG#: 9846
« Reply #8 on: April 19, 2013, 07:31:40 pm »
tighten till you hear a "squeak" then back out a 1/4 turn
Kidding
Offline Fred_Harmon_TX
  • COG Technical Editor
    • Angel Ride Videos
  • COG#: 2170
« Reply #9 on: April 19, 2013, 07:36:12 pm »
Many of those screws go into a rubber backed nut plate. You can feel the rubber expand as you tighten them if you pay attention. They weren't meant to have much torque applied.
Fred H.
« Reply #10 on: April 20, 2013, 04:07:58 am »
I agree. Snug might be a better description, not gorilla tight.
