Author Topic: TPMS out, 90deg valve stem in  (Read 496 times)
Offline JDSCO
  • 2016 C14
« on: February 02, 2019, 12:22:36 am »
2016 C14
Some time ago I read a post(s) regarding replacing the TPMS sensors with Honda Goldwing 90deg valve stems
I intend to replace mine eventually and send my sensors to Harry Martin for his continued research
Pictured are 11.3mm MotoD's
Do these later model TPMS's and the Kaw inner wheel make a standard valve replacement difficult?
Other than 8.3mm or 11.3mm through rim?
Anybody out there with some input?
« Last Edit: February 02, 2019, 01:42:25 am by JDSCO »
Gen James Mattis
Offline JDSCO
  • 2016 C14
Re: TPMS out, 90deg valve stem in
« Reply #1 on: February 02, 2019, 04:31:14 pm »
This is what a Colorado Kaw dealer uses for TPMS replacement valve stems, $8.00 each (pic shows a 4-pak)
According to the spec's, it fits a .453" through-hole in the rim assuming the stepped o-rings fit in and around the rim through-hole
I read in the other forum that this elbow style tends to flex, to temporarily leak at the orings, when you push on the air chuck when filling a tire
I don't know! It sure would be nice to hear from someone who did this replacement
The Moto D looks quite stout, lower profile
And it looks kinda' cool
Gen James Mattis
Offline Harry Martin
  • ☺ Cartoonist ☺
  • Fear is not boring
    • Harry Martin Cartoons
  • COG#: 4090
« Reply #2 on: February 02, 2019, 04:41:49 pm »
From the website:
Size: 11.3mm (0.453in): Fits all Suzuki, Yamaha, Kawasaki, and Honda Motorcycles with an 11.3mm valve stem opening (except Honda GL1500, GL1800, BMW R1150RT 02-04, BMW R1200GS 04-12, BMW K1200LT 99-08 , BMW K1100RS/K1100LT 93-96). Fits KTM RC 390 (2015+).
So the question is, what is the valve stem opening on a 2016 C14?
Offline Staylo
  • COG#: 12548
« Reply #3 on: February 02, 2019, 04:53:45 pm »
It seems to me I had read that these will fit one of the TPMS styles we have, but not the other.  I'm thinking it was the early type TPMS, but not the new version.  Hopefully someone else will come along with something actually useful, unlike my post.   :D
Lancaster County, PA
'11 C14
Offline JDSCO
  • 2016 C14
« Reply #4 on: February 02, 2019, 05:23:51 pm »
^ I definitely read that also
I've looked, cant't find it
« Last Edit: February 02, 2019, 06:10:02 pm by JDSCO »
Gen James Mattis
Offline JDSCO
  • 2016 C14
« Reply #5 on: February 02, 2019, 06:09:29 pm »
From the website:
I'm guessing the 11.3mm,, as well
Could the tapered, conical seal be an issue, unique to this later model TPMS and the later model rims?
The older TPMS doesn't have that style seal and it appears to be 8.3mm
Hmmm!
« Last Edit: February 02, 2019, 06:32:57 pm by JDSCO »
Gen James Mattis
Offline CRocker
  • '02 C10 CDA # 416
« Reply #6 on: February 02, 2019, 07:21:58 pm »
Would guess the larger of the two...used to be that the smaller diameter hole was on most European bikes...and the larger diameter hole was on everything else...DAMHIK...let's just say a late night filing session got the larger diameter valves into my 1986 BMW K100RT rims... :beerchug:...
That tapered seal is interesting, though...
But, the fact is...on any C-14...I don't know...
« Reply #7 on: February 02, 2019, 09:48:42 pm »
From the website:
Hmmm!
well, seeing that the only Kaw OEM sensor in those pics, is the "old style" one,
and combined with the fact the rims themselves have not changed, other than Paint/color, and also the new style potted units are used to replace old style ones..
I would have to say the "flat washer type seals" will accomplish the task.
Offline JDSCO
  • 2016 C14
« Reply #8 on: February 02, 2019, 10:32:09 pm »
Here is my old 2008 C14 front rim (in silver) I forgot I had it sitting around
It's a .453 (11.5mm) through-hole, c'bore .75 (19mm) resulting in a .156 (4mm) wall
It accepted the "old TPMS", pictured with the spring in previous post
Then here's an internet pic of a 2016 C14 rear (in black)
A different inner wheel cross section but with a similar through-hole, counterbore and outer rim  feature, it appears
It accepts the newer "Kaw TPMS" as pictured
The two TPMS designs are different
So far, I don't see why a 11.3mm wouldn't work but I sure would like to find the old post where someone experienced something different
Gen James Mattis
« Reply #9 on: February 02, 2019, 11:12:02 pm »
 :rotflmao: :truce: ;) ;) ;)
as I noted, the physical dimensions are the same, it just throws you off doing a comparo of front and back rim innerds... the sensors are interchangeable... dimensionally  those "tapered" seals were "squishable", and I don't think they really are Kaw seals... nor were those sensors actual new style KAW OEM ones..
maybe they are, but unless there is a "K" and the p/n molded in the plastic I'd say no...I see both in your second photo, but the 433mh on the tag... well it ain't right.
21176-0125  old
21176-0748  new
when searching the net, or ebay...
somebody post a picture of the new style, with the real seal.... please..
I don't have one, sorry...
in the meantime, look here... O'l Buddy Murph wouldn't hose ya...
https://www.murphskits.com/product_info.php?cPath=167&products_id=486&osCsid=G8tm8p2uRJsUt7R9FI7dz2
I would assume this comes with a free bike attached...
https://www.amazon.com/Kawasaki-Concours-Pressure-Monitor-21176-0125/dp/B00MFDAYKQ
« Last Edit: February 03, 2019, 12:00:53 am by MAN OF BLUES »
Offline JDSCO
  • 2016 C14
« Reply #10 on: February 03, 2019, 01:02:54 am »
And they even offer an installment plan!
That Amazon listing has been that way for a while
Thanks for your input Rich
Gen James Mattis
« Reply #11 on: February 03, 2019, 10:38:03 am »
« Reply #12 on: February 03, 2019, 09:56:28 pm »
Thanks Bud
I can't disagree with your photo, a I did find that one, and a few others when I was looking..
Back to JDSCO's original question now, the 2 different "valve stems" he wanted to use in place of a TPS unit, will work, using the gaskets Murph has...
the "hat shaped/stepped" flat style.
