Author Topic: What have your done to your C14 today  (Read 77862 times)
56taskforce
  • Guest
« Reply #150 on: November 27, 2017, 01:18:33 am »
Got down low and gave the exhaust a close look for space and routing then did some comparisons to pictures of ZX exhaust. Just compiling information and ideas for building a duel system for the C14. Got a few pretty good ideas between what info Ted has rounded up this forum and what I have researched.
Offline LURCH
  • COG#: 12329
« Reply #151 on: November 27, 2017, 01:39:53 am »
Here's my hanger I made that worked great. If you get time check out what I just did with my duals.
56taskforce
  • Guest
« Reply #152 on: November 27, 2017, 02:32:56 am »
I have checked your work out. Very nice. I am actually working on a prototype head pipe that is tuned better for the Concours than the ZX pipe. Paying close attention to what Ma. Kaw did.
Offline LURCH
  • COG#: 12329
« Reply #153 on: November 27, 2017, 03:27:16 am »
Like to see that.I don't care what everyone says that zx conversion is a pain and to many modification
Offline LURCH
  • COG#: 12329
« Reply #154 on: November 27, 2017, 03:42:09 am »
Tore the bike down to prepare for valve check/adjustment work tomorrow. Changed air filter in process and also plan to drain and refill coolant while I'm at it. Spark plugs changed out ~21K miles ago so no need to touch them
Just completed the valve check & adjustment (+ other items listed above) this Thanksgiving weekend. I was able to tear the bike down to get it to the valve check point, then called in technical help to have someone check them while I recorded results ... then we dove into the adjustment to correct those out of spec. That part was over my head (mechanically) ... knowing my limitations now). We got her done and I've almost got the bike all back together. Looking forward to taking her for a spin again ...
Installed a 2007 ZX14 header and twin two brothers pipes and cans.
Lurch, "really" anxious to hear how it worked out?
Power/sound/torque/etc etc etc??
Ride safe,Ted
Quote from: connie_rider
link=topic=71316.msg620130#msg620130 date=1511740559
Ride safe,Ted
Well I finally got the system installed. I'm really surprised by the power increase was not expecting that. I no longer have to downshift from o/d to keep from lugging the engine that's a big plus,but the system is loud and at 60-70 mph it's causing more vibration in the bars and it took some work and adapters to get it to fit perfect. I'm not thrilled about having to modify the kickstand and cut and reconfigure the center stand. It really looks much better and runs better as for the sound well I'm 61 but the juvenile delinquent in me likes it.
56taskforce
  • Guest
« Reply #155 on: November 27, 2017, 04:04:12 am »
Have you addressed the kick and center stand issues yet?
Offline LURCH
  • COG#: 12329
« Reply #156 on: November 27, 2017, 03:02:53 pm »
I ordered a ZX14 kickstand and I have yet to take the center stand to a welder to adapt it because I'm not going to do without a center stand as soon as I get that done I'll be happy with everything
« Reply #157 on: November 27, 2017, 03:04:18 pm »
I keep planning to install the ZX headers on mine, and {also} keep putting it off..
I'd like to know more about the stands as well??
  What mods are needed?
On your TB pipes, which did you use? (ie; what year ZX-14 were the mufflers supposed to fit?)
From your photo's it appears that the mid pipes were not long enough {or they were not the correct diameter} and you had to install adapter pipes?
Offline LURCH
  • COG#: 12329
« Reply #158 on: November 27, 2017, 09:07:18 pm »
The header was from a 2007 and supposedly the seller a different person said the mid pipe and two brothers mufflers we're also for a 2007. Now they would have fit with me taking them to a shop to have them re bent to get out away from the final drive and down away from the bag but having worked in my youth at Midas I thought if I could just extend them 3 in straight off the header that should fix the problem and it did the pipes went on without a hitch. As for the kickstand it had to be moved out 1/2 of an inch and could probably be bent a little more to clear the pipe the center stand as most people are doing has to have the foot that sticks out extended so that it goes out around the mid pipe right now it hits the bottom of the mid pipe not allowing the kickstand to go up far enough if you're not doing Twistys you probably would not have a problem with that but it most definitely will drag going around a corner so I'm going to take the kickstand to a welder on my bike show him what I need done have the factory arm cut off and a new gusset and arm put on just extending it should take care of the problem. Right side hanger had to be extended 2 inches so the pipe did not hit the bag and you just have to fabricate a hanger for the left side however you want to
Offline LURCH
  • COG#: 12329
« Reply #159 on: November 27, 2017, 09:13:35 pm »
With four back operations I don't bend too well so these are the best pictures I could take of the adapters you can't see them unless you get down under the bike and nothing is hanging any lower than the factory exhaust clamp
Offline LURCH
  • COG#: 12329
« Reply #160 on: November 27, 2017, 09:21:06 pm »
Get yourself 2- m10-1.25 x 2 1/2" long for the kickstand shim you'll have to make
Offline turbojoe78_MA
  • COG#: 8645
« Reply #161 on: November 29, 2017, 12:29:54 pm »
Rode it to work for probably the last time this year.
Got the stabilizer with me and will throw it in and top off the tank on the way home.
Valve adjust and lots of other maintenance over the winter to get ready for the spring.
Offline Rob9876
« Reply #162 on: November 29, 2017, 10:40:55 pm »
Today I rode to work and ended up taking a little 30 minute ride for fun during lunch.  :motonoises:
« Reply #163 on: November 30, 2017, 03:51:38 pm »
Took mine out for a quick ride yesterday {in Houston traffic}.
  Bad idea!!!!!
Spent more time at red lights and in traffic than riding.    :angry:
Offline LURCH
  • COG#: 12329
« Reply #164 on: December 05, 2017, 04:52:48 pm »
Got my European labels
Offline COGnosticator
  • SE AAD
  • COG 4478
  • COG#: 4478
« Reply #165 on: December 05, 2017, 09:43:00 pm »
Traded it for a Triumph Speed Triple   :great:
Jerry Holland  COG  4478
Offline flashback50
« Reply #166 on: December 06, 2017, 01:41:59 pm »
I'm wondering if the screws in the side case pucks will be strong enough to hold the weight of the exhaust with all the stress it will have on it going down rougher roads?  Looks great though   :great: :beerchug:
« Last Edit: December 06, 2017, 01:45:04 pm by flashback50 »
Offline freebird6
  • COG#: 11012
« Reply #167 on: December 08, 2017, 12:29:08 pm »
Put it away. Winter is finally here and I am having both knees replaced Monday :truce:
Offline Buzzard
« Reply #168 on: December 11, 2017, 09:06:24 pm »
I had a serious talk with Santa last week.
Just noticed a box w/a shinny new Delkavic exhaust system and another box from Project D w/a handle bar extension and oil filler cap setting on the front porch.
Santa was in a hurry, so he asked the wife to wrap the boxes nice and pretty for the 25th.
Merry Christmas to all !! :great:
Buzzard
2016 F6B
2016 C-14 "SOLD"
2002 C-10 "SOLD*
Offline Road Runner
  • Beep! Beep! ... YeeHa!
  • COG#: 12399
« Reply #169 on: December 11, 2017, 11:51:12 pm »
Thanks and Merry Christmas to you as well. Enjoy your presents ... know you will   :great:
David L. Hamil
Offline gpd323
« Reply #170 on: December 12, 2017, 12:21:01 am »
Looked at it in the garage as I went to drive a car (GASP!!!) into work today, damn ice and cold temps, but at least my driver is a Mazdaspeed 6 with some tasteful mods.
« Reply #171 on: December 12, 2017, 01:47:39 pm »
Checkin' on ya Tom.
How'd the surgery go?
Offline Nodesurfer
« Reply #172 on: December 14, 2017, 06:30:34 pm »
I just added a pair of Grip Puppies to my '09 C-14.
I like the thicker, grippier, more commanding feel in my hands. Particularly with leather gloves, the stock grips can be a little slippery. When I twist it open in 1st or 2nd, I feel like I have a lot better hold of it now. Plus, they're comfortable and I'm sure will reduce vibration on long trips.
AND, they look great. And I was able to put the "Go Cruise" cruise control back on with it's rubber grip ring and it all works nice. For $18 on Amazon, I feel they were a good add.
Pictures:
https://drive.google.com/file/d/1w5I3pshTSBMOc--BgTvGDqNPbarGJKlp/view?usp=drivesdk
https://drive.google.com/file/d/1AaBlKvwmeV1eYIXwyX-8215dxRR8YYWP/view
Offline ZXtasy
  • COG#: 12569
« Reply #173 on: December 14, 2017, 07:22:41 pm »
Pulled the battery out, as she just really is slow to start and throws the low battery error since the temps have dropped to the 20-30 range, (45-50 in my garage even it drags after all week on the tender!)  Rode it to work one day last week, 19 degrees in the AM and at 36 for the afternoon high I was almost afraid it was not going to fire! Pretty sure after looking closely it is the OEM battery for a 2013, so it is time. Do not think the PO bothered with a tender much, thought he leads were installed he had no idea what they were.
I have had good experiences with the WPS LI Featherweights in 4 or 5 other rides, so that is going in tonight.
Offline roy826
« Reply #174 on: December 18, 2017, 01:34:22 pm »
Started on my valve cover / cam sensor oring oil leak. Plus a coolant flush ,spark plugs and a valve check.
Friggin nightmare of a bike to work on  >:(
Had her down to the cams in sight in 2 1/2 hours though. Murphs kit ordered this morning and hope to button it all back up in the next week or so.
Hour or so in  >:D
oil leaker  :( be advised I degresed it a week ago in preparation for this so build up not quite as bad as it was before the cleaning.
2 1/2 hours in  :'(
« Last Edit: December 18, 2017, 01:38:49 pm by roy826 »
