Author Topic: What have your done to your C14 today  (Read 87238 times)
Offline Tundra
  • 2012 Candy Arabian Red
  • "SPORT" tourer
« Reply #525 on: February 05, 2019, 10:26:22 am »
What was your knob source? Looks like an electronics control knob of some sort? Perfect size, looks great and functional!
Online Bud
Re: Key Knobs
« Reply #526 on: February 05, 2019, 05:16:27 pm »
I know this has been done many times before however here is my interpretation of the Saddlebag Key Knobs.
Craig
Nice pics.  Care to tell the rest of the story as Paul would say?
Offline Craigmri
« Reply #527 on: February 07, 2019, 02:49:26 am »
Sorry for the delay guys....Moms in ICU and been at the Hospital like crazy...
Got the knobs on Amazon:
https://www.amazon.com/Uxcell-a15091400ux0842-Control-Rotary-Diamter/dp/B01FCUYWPQ/ref=sr_1_1?ie=UTF8&qid=1549510834&sr=8-1&keywords=Uxcell+a15091400ux0842+Bulb+Light+Lamp+Di+mmer+Control+Rotary+Knob+Cap%2C+2+Piece%2C+5+mm+Diamter%2C+Black
Basically got the KW14R blank keys online and brought them to my local hardware store to be cut to match the bikes key.  I then cut off the head of the key then made a slot in the underside of the knob by heating up a flatblade screwdriver then inserting the key to the desired depth in the knob...Once I was happy with the depth and the perfect perpendicular angle of the key, I then filled the hollow knob back with epoxy then let set up.
Works like a champ!
Quote plagiarized from Cap 'n Bob:  Key Blank - ILCO KW14R  Note: Double check your keys and this information. There seems to be two types of keys, beginning with either an "A" or "B". If you have an "A" key it should be a "KW14R" key-blank.  If you have a "B"  key, it should be an "KW14" key-blank.
Craig
Offline Tundra
  • "SPORT" tourer
« Reply #528 on: February 07, 2019, 09:55:31 am »
No worries Craig and thanks for sharing, nice little inexpensive addition.
Sorry about your Mom, wish you and yours the best in this situation. I'm going through the same.
Offline Craigmri
« Reply #529 on: February 07, 2019, 10:51:58 am »
Thanks brother.....Wishing you the best as well!!
Craig
Offline Mikecon
  • COG#: 10155
« Reply #530 on: February 07, 2019, 08:03:53 pm »
Installed Madstad windshield brackets on my Vstream.  Went for a ride at freeway speeds and they work as advertised!  No back pressure pushing me forward. I should have done this long ago.
Offline ZXtasy
  • COG#: 12569
« Reply #531 on: February 08, 2019, 02:13:16 am »
Plugged battery tender on, LI battery so it always shows charged but left it on for a tad. Looked at the forecast 6-8 inches of snow for the next 48 hours. Sighed. Checked snowblower for readiness, at least it makes vroom vroom noises.
Offline konehead
  • COG#: 9065
« Reply #532 on: February 08, 2019, 05:55:09 pm »
Tpms battery replacement, oil/filter change, drain and flush radiator. Omg clean the rad, its SOOO.... grimmie,  replace cooling hoses, and on to a valve check/adjust.  Gotta love the southwestern Georgia weather.....no more freezing my tookus off doing winter maintenance anymore... ;)
« Reply #533 on: February 11, 2019, 11:09:19 pm »
Took it to the track day at Jennings and ran the heck out of it!!
Offline gilbysan
  • The Fat Ninja Rides Again!
  • COG#: 12764
« Reply #534 on: February 13, 2019, 06:20:57 pm »
Removed the fairing pieces to get at the headlight nacelle so that I could take it apart and clean the inside which had become hazy on the reflector and inside the lens.  Bought a roll of butyl rubber for headlights and figure it all out.  Now not so concerned about taking the headlight apart again.  Took the opportunity to run some wires more efficiently around the chassis that I should have done before...
Thinking about doing a paper on how best to take off the front end pieces, headlight, etc.
Cheers!
Gilbysan
gilbysan
Offline Eric
« Reply #535 on: April 01, 2019, 04:04:47 pm »
I flushed the clutch fluid using a home made vacuum system.  The bike only has 3,600 miles on it, and I've owned it for less than a year, but it was a left over new 2012.  Let me tell you, that fluid was nasty looking!  No chunks or visible water, but it was the color of weak coffee.  The biggest pita was getting the rubber piece slid back onto the lower fairing panel, and what a pain it was!  I'll be doing the brakes this weekend, but did the clutch first since the fluid in the reservoir was noticeably darker than the other 2.
2012 Concours - My new baby!
1981 KL250 - ridden to death
Offline bezier kid
« Reply #536 on: April 01, 2019, 04:11:44 pm »
I put a Murph o ring on the exhaust cam position sensor, Valve clearance check and throttle body sync. Took a few days but it is fresh in my mind today.  Then it snowed.
Online Bud
« Reply #537 on: April 01, 2019, 04:20:12 pm »
Would be interesting to many to know the miles on the bike and what the clearances were.
Offline bezier kid
« Reply #538 on: April 02, 2019, 02:08:01 am »
2008.  I'm just over 80K.  I believe this is the 4th valve adjustment I've done. I've had it since 30K.
All the intake valves were within spec this time from .0055" in to .0065".
All the exhaust valves were slightly tight except 1 at .008".  Most of the valves were between .007 and .0075.
I can give you the exact numbers if you need them, I just don't have them with me.  It was a lot less adjusting this time compared to previous jobs.
« Last Edit: April 02, 2019, 01:15:45 pm by bezier kid »
Offline AmphibSailor
  • Cibolo, TX Hooligan
  • COG#: 12210
« Reply #539 on: April 03, 2019, 03:14:56 pm »
Re-installed my re-flashed (updated to Steve's latest Full Area P MR flash) ECU.  Started the bike up for the first time since leaving Germany last fall.  Got temporary registration plates (paper tags).  Been pretty busy since moving into the new house and being on the road (work) so much.
 :motonoises:
Offline Christopher
« Reply #540 on: April 03, 2019, 04:00:45 pm »
Replaced Air filter (15k), Took off the bolts holding the grounds and put some dielectric grease on the eyelets.. Still need to put the fairings back on. This is the 1st time I've had em all off, Is there a trick to the sequence? I was thinking start front the top and working my way down.
Offline bezier kid
« Reply #541 on: April 03, 2019, 05:27:45 pm »
The bottom up works best for me. I have an 08.
Offline mirage
  • Walking stick
« Reply #542 on: April 04, 2019, 12:43:40 am »
Have speed bleeders (not installed). Installed tank protector and ordered Canyon Cages. Installed Ram mount for cell phone. Looking forward to seeing how accurate the speedo is.
Dan
2004 ZRX
2006 KLR
2014 Concours
Offline ron203
  • COG#: 9847
« Reply #543 on: April 04, 2019, 01:10:32 am »
Rode it! 72 and sunny!!
2014 C-14
2008 Goldwing
Offline Eric
« Reply #544 on: April 04, 2019, 11:44:15 am »
On my 2012 it's way off.  Like 4 mph off at an indicated 65 mph.
Offline rogracer
  • COG#: 11346
« Reply #546 on: April 05, 2019, 02:13:20 pm »
Just finished my first valve check at about 26K on the clock.  I guess I don't bounce off the rev limiter enough because everything was within spec (if the dealer told me that, I would NOT  have believed him   :??:).  But here is a question for the group...the second intake valve on cylinder 3 was the tightest...measuring at 0.13mm...just above spec min.  Would you guys pull the cam and adjust it anyway or just leave it alone and check again in another 15K miles or so?   Feedback much appreciated.   :beerchug:
Offline bezier kid
« Reply #547 on: April 05, 2019, 08:41:05 pm »
Personally, I would leave it.
Offline rogracer
  • COG#: 11346
« Reply #548 on: April 06, 2019, 02:45:06 pm »
Thanks Bezier I will likely follow that route and button her back up, but I'll wait a day or two and see if I have a change of heart. Im still curious what the others might do in this situation. I guess pro shops would just go by the manual and if its "within range" that means "no adjustment". That would imply there must be a little safety margin outside the spec range, but I have no idea what that margin might be on this motor. In my case I would likely just use a shim 0.001 in thinner and that dosen't seem worth it.
Offline gilbysan
  • COG#: 12764
« Reply #549 on: April 06, 2019, 03:23:10 pm »
Eric,
Yeah my '12 is off by 4MPH as well. For example, If I am going 60 those friendly radar signs we have in WA State show a consistent 56. I have looked at speedo correction devices but instead, just got used to it.
Cheers!
Gilbysan
gilbysan
