Author Topic: windshield floppiness  (Read 5887 times)
Offline bbhzx12
Re: windshield floppiness
« Reply #25 on: September 02, 2014, 02:02:42 pm »
Put me at the top of the list!
What's the damage?   Maybe I should have asked first ;)
Thanks!
Offline runnerb0y
  • If you don't think too good, don't think too much.
  • COG#: 10517
« Reply #26 on: September 02, 2014, 03:54:31 pm »
Depending upon cost, I'd be interested in this.  I just moved to a much larger Cee-Bailey's windshield and at freeway speeds it's a bit spooky.
| COG#: 10517  |  2012 C14 - Candy Arabian Red  |
Offline Bruiser
  • Bruiser
« Reply #27 on: September 02, 2014, 06:47:05 pm »
The only problem I've had re: the windshield brackets is the cheesy plastic pieces that Kawasaki used for mounting the windshield.  Where the screws fit into the holes, then through the windshield itself, is a thin plastic hole.  This hole I found on mine, had enlarged itself, probably from vibration, so the screw heads just went all the way through the hole.  My cure was a 3/8" metal washer, that has a rubber grommet attached.  I placed the rubber side against the plastice bracket, and ran a screw through these, into their normal mounting holes. This basically holds the plastic bracket against the windshield in a similar fashion to stock.
Bruiser
2012 Kawasaki C14
93 Kawasaki C10
1982 Honda CX500 Turbo
1980 Kawasaki KZ1000ST
1978 Honda CB750F
1976 Kawasaki KZ400
1976 Honda 750K
1973 Honda CB500K
1973 Honda SL175
1972 Honda SL125
Offline Julianm
« Reply #28 on: June 23, 2015, 02:14:48 pm »
Ill make a few of these and see if they sell. Im working on a couple other projects right now. Plus September is a busy riding time. So itll be oct/nov. Its only the middle piece that connects the 2 sliding brackets that we're talking about.
Just suffered the fate of the broken bracket
Please advise how far this has progressed and are you in a position to offer for sale ?
Many thanks
