Author Topic: Windshield Quit Working  (Read 357 times)
Offline Shizzle
« on: June 30, 2020, 12:50:55 am »
Damn it, worked fine last time I rode. Get on it tonight and nothing. Fuse is good and I hear a relay clicking when I press the up and down but it does nothing. Any ideas? 2011 C14
Online robertv
  • Go Hawks!
Re: Windshield Quit Working
« Reply #1 on: June 30, 2020, 01:21:19 am »
Found these YT videos not too long ago. Here's some copy/paste text...
removal ->
https://youtu.be/n0zK9axWuzc
install ->
https://youtu.be/Zcp33wXzITU
watch the re assembly sequence FIRST; it will give you the reasoning, and what really it takes to pull the assembly out in a simpler manner
Basically assembly/motor needs cleaning and greasing. Hope this helps!
2008 C14, silver [current]
2000 C10, red [sold]
Offline C. Moore
  • COG#: 6662
« Reply #2 on: June 30, 2020, 09:38:00 am »
Mine got balky a few months back so I pulled up on it at start up and got it to move. It started working so I didn't mess with it anymore.
'10 C14  Dallas, Texas
CDA #523
COG# 6662
Offline jas
  • COG#: 10108
« Reply #3 on: June 30, 2020, 10:54:01 am »
I was having problems with the windshield not moving on my 2011. I cleaned and re-lubed the tracks where the components slide and it has been fine ever since.  To clean and re-lube you only need to remove the front cover. I remember going out of my way to find grease that is compatible with the plastic tracks. I believe I used synthetic grease from Super Lube.  I probably need to do this again!
Offline Shizzle
« Reply #4 on: June 30, 2020, 03:06:07 pm »
Thanks for the input guys, I will dig into it tonight   :beerchug:
Offline gsun
  • CDA #560
  • COG#: 9127
« Reply #5 on: July 01, 2020, 12:11:46 am »
i believe the proper lube on the plastic track is silicone paste. There is another grease point that uses actual grease. Been a long time since I did it I can't remember where that is but it is in the manual.
Offline Shizzle
« Reply #6 on: July 01, 2020, 12:43:48 am »
Took windshield and cover off tonight. One of the windshield bolt heads stripped so I had to drill it out. After I got everything off the mechanism worked fine. Ordered 2 new bolts and washers. Will grease mechanism probably with lithium grease. On another note, I sold it tonight.
Offline 2andBlue
« Reply #7 on: July 01, 2020, 12:49:50 am »
The windshield or the C14?  Either case what’s next?
Offline RoadKillHeaven
  • How hard can it be? 。◕‿◕。
« Reply #8 on: July 01, 2020, 09:27:42 am »
The windscreen on my 16MY had covid19 for about a week. Then it cleared and worked fine ever since. I haven't tested it for antibodies, though.
Offline Shizzle
« Reply #9 on: July 01, 2020, 11:13:57 am »
Yes, to both. Sold the bike and the windshield together.   :)  Not sure what's next. The Concours is a great bike and I will probably regret selling it.
Offline sfsokc
  • COG#: 10667
« Reply #10 on: July 01, 2020, 09:51:37 pm »
Search is your friend.....   :)  I wrote a how-to on fixing this not too long ago.  See below:
forum.cog-online.org/concours-14-zg1400-general-chat-and-tech/finally-got-my-windscreen-working-again!
Cheers,
